Sub crossover with proamp - Home Theater Systems - Electronics and Forum - HomeTheaterShack
DIY Subwoofers
Discuss Sub crossover with proamp in the DIY Speakers and Subwoofers forum; Sub crossover with proamp Making a passive sub crossover is expensive due to the high mH rating needed on the inductor, and buying a ...
Old 12-27-07, 12:32 PM   #1 (Link)
Alias: Mike
Loc: Chattanooga, TN
User: #5740
Since: Jan 2007
mgboy is online now
Making a passive sub crossover is expensive due to the high mH rating needed on the inductor, and buying a active crossover isn't an option just yet, and even if it was, I'd only be using the sub out portion, so it would be a waste of money anyway. My 'receiver' doesn't have a sub out, as I'm using the Dayton amp150 (or whatever it's called) to power my speakers.
I was thinking of using this as my sub crossover, but I was trying to think of a way to power it. Could I just use a ac-dc adapter to power it? It can't take too much power to get that subcrossover working can it?
Any other options you guys have in mind would be very helpful.
- Mike.
Old 12-29-07, 11:43 AM   #2 (Link)
Alias: Robin Hood
Loc: Sherwood Forest
User: #11451
Since: Sep 2007
stephenb1 is offline
Re: Sub crossover with proamp
Hi i used one similar many moons ago,
its a simple 12-15 vdc adaptor needed powered of the mains supply as you mention. It should have no problem powering it , it probably only consumes 1 or 2 amps.
Perhaps when your ready you could buy a behringer cx-3400 or cx 2310crossover, great value for money, cheap and last.
Hope this helps.
Old 12-30-07, 12:37 AM   #3 (Link)
Alias: Brian
Loc: Oklahoma City
User: #5872
Since: Jan 2007
bonehead848 is offline
Have you considered using this money to upgrade to a receiver that does have a sub out? You should be able to pick up a used one pretty cheap one off of craigslist or ebay.
Old 12-30-07, 12:51 PM   #4 (Link)
Alias: The Dave
Loc: Nor^Cal
Avus_M3's Avatar
User: #13004
Since: Nov 2007
Avus_M3 is offline
bonehead848 wrote: View Post
X2
- The Dave
Check out my QUAD 18" Fi IB Build Thread (DONE) King of the 400lb Gorilla
Similar Threads
Active crossover / sub out Q BoomieMCT DIY Speakers 19 12-18-07 11:33 AM
Do I need a crossover For my SONO SUB? ramchip007 DIY Subwoofers - Sealed and Ported 3 09-03-07 12:50 PM
EV crossover (ACTIVE) Danny Classifieds - Equalization and Calibration Equipment 1 08-11-07 05:09 AM
Crossover program? Xterra DIY Speakers 8 06-19-07 09:16 PM
Crossover question(s) BoomieMCT DIY Speakers 11 02-10-07 07:38 AM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200
