Is my subwoofer broken ? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
DIY Subwoofers
Discuss Is my subwoofer broken ? in the DIY Speakers and Subwoofers forum; Is my subwoofer broken ? I just bought a M&K MX100 subwoofer. The problem is when I try to increase the volume via the min/max ...
Old 12-31-07, 06:26 PM   #1 (Link)
New Member
Alias: David
Loc: Mansfield, TX
User: #14919
Since: Dec 2007
Newbiedave is offline
I just bought a M&K MX100 subwoofer. The problem is when I try to increase the volume via the min/max knob on the back, the speakers rattle or shake enough to move the furniture. It stops when I quite turning the knob and seems to operate fine, but since I really don't know anything about subs, I thought someone may know if there's a problem with it.
Any advice:help will be appreciated.
newbiedave
Old 12-31-07, 07:56 PM   #2 (Link)
Alias: Brent
Loc: Wilmington, NC
brent_s's Avatar
User: #7037
brent_s is offline
Re: Is my subwoofer broken ?
Patient: Doctor, my neck hurts when I hold my head like this.
Doctor: Then don't do that.
Seriously, if it works fine once you quit playing with the knob, it's probably just a dirty volume control. Subwoofer plate amps are generaly set-it-and-forget-it devices. Once you get it calibrated, you should have no reason to play with it...you can make smalll "season to taste" adjustments using the trim controls in your receiver/processor.
You can attempt to clean it. Disconnect from power and simply turn the knob from min to max repeatedly...no magic number of times. If you're really determined, you can pull the amp from the cabinet and go at the volume pot with some compressed air.
-Brent
Old 01-01-08, 09:35 AM   #3 (Link)
New Member
Alias: David
Loc: Mansfield, TX
User: #14919
Since: Dec 2007
Thanks Brent.. I'll take your advice and "set it and forget it" .
Happy New Year
David
Similar Threads
first subwoofer foamfan DIY Subwoofers 8 04-03-07 11:27 AM
Broken BFD Blue Dude BFD Forum 1 11-20-06 10:41 PM
Broken T-nuts? derekbannatyne DIY Subwoofers 3 10-09-06 11:14 AM
My SPL meter might be broken... :( Exocer REW Forum 13 09-06-06 02:19 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202
