New to the game, a few quick questions. - Home Theater Systems - Electronics and Forum - HomeTheaterShack
DIY Subwoofers
Discuss New to the game, a few quick questions. in the DIY Speakers and Subwoofers forum; New to the game, a few quick questions. Hi, I am in the middle of designing a dual 12" coffee table sub, and I am in the midst ...
Old 01-04-08, 01:45 AM   #1 (Link)
New Member
Alias: Steve
User: #15068
Since: Jan 2008
hsv2kk is offline
Hi,
I am in the middle of designing a dual 12" coffee table sub, and I am in the midst of selecting an amplifier.
The Behringer Europower 1500 looks like a solid enough amp for my needs.
What else is required to make sure this amp does not play full range through the subwoofers? The Behringer will be hooked up to my HT via the subwoofer out.
Thanks!
Old 01-04-08, 01:52 AM   #2 (Link)
Alias: Mike
User: #8033
Since: Apr 2007
Mike P. is online now
Re: New to the game, a few quick questions.
Your reciever will have a crossover built in for the sub frequencies. Depending on the design of the dual 12" coffee table sub you may need a subsonic filter.
Old 01-04-08, 02:02 AM   #3 (Link)
New Member
Alias: Steve
User: #15068
Since: Jan 2008
hsv2kk is offline
Hi Mike,
Thanks for the quick reply!
I have a Highpass Linkwitz-Riley filter 4th order 18hz cutoff modeled in WinISD to control excursion. Will this do the job of the subsonic filter?
Old 01-04-08, 02:11 AM   #4 (Link)
Alias: Mike
User: #8033
Since: Apr 2007
hsv2kk wrote: View Post
Hi Mike,
Yes, that would do it.
Old 01-04-08, 02:12 AM   #5 (Link)
New Member
Alias: Steve
User: #15068
Since: Jan 2008
hsv2kk is offline
Excellent! Thanks again.
Old 01-04-08, 04:58 AM   #6 (Link)
Alias: Mike
User: #8033
Since: Apr 2007
Which 12 inch subs are you thinking of using?
Old 01-04-08, 07:00 AM   #7 (Link)
New Member
Alias: Steve
User: #15068
Since: Jan 2008
hsv2kk is offline
I have 2 car audio subwoofers from my old boot install that I will be using.
They are Alpine Type-R's. Model 1221D.
Both are dual 2ohm subwoofers, so one sub per channel on the amp with each sub showing a 4ohm load.
Not ideal, but they work pretty nicely in WinISD in the 7-8 cu^ft enclosure tuned @ 20hz.
Specs:
Qts: 0.382
Qms: 8.680
Vas: 58L
Qes: 0.400
Fs: 27Hz
SPL: 86.59dB
Xmax: 13.3mm
Xdamage: 27.5mm
Sd: 0.0467 m^2
Thanks for showing interest.
Any advice would be greatly appreciated, as this is a first build for me.
Old 01-05-08, 03:06 AM   #8 (Link)
Alias: Mike
User: #8033
Since: Apr 2007
They model surprisingly well in 7 cubic feet tuned to 20hz. Good luck with your build. Post some pics if you can!
Old 01-07-08, 08:29 PM   #9 (Link)
Alias: Warmon
Loc: Chester VA USA
Warmon's Avatar
User: #11066
Since: Aug 2007
Warmon is offline
I have also heard that these Alpine Type R's make very decent home subs. Good luck with your build and I too will look forward to the pics.
Warmon - "know what I mean Vern"
Old 01-08-08, 12:18 PM   #10 (Link)
Alias: Funky Waves
User: #9943
Since: Jul 2007
funky_waves is offline
A reckhorn B-1 is perfect for that aplication, it gives you, variable subsonic, variable highpass and variable boost. And its not expensive or very big.
Nathan Funk
Funky Waves Audio
www.funkywaves.net
Old 01-08-08, 03:59 PM   #11 (Link)
New Member
Alias: Steve
User: #15068
Since: Jan 2008
hsv2kk is offline
Nathan,
Do you have a 240v B1 that you could ship to Australia?
Old 01-09-08, 02:01 AM   #12 (Link)
New Member
Alias: Steve
User: #15068
Since: Jan 2008
hsv2kk is offline
Has anyone seen, or used glass or plexiglass on there installs?
I would love to have the bottom of the coffee table glass black with a timber top with a glass window set inside of it, to see inside of the enclosure.
Any ideas on what thickness glass would be required, etc?
Thanks guys!
Old 01-10-08, 10:58 AM   #13 (Link)
Alias: OJ
Loc: Toronto, Ontario
Owen Bartley's Avatar
User: #3144
Since: Oct 2006
Owen Bartley is offline
I think you'd want pretty thick plexiglass, and wouldn't want to make the window very big, since it is a pretty flexible material, and you won't be able to brace the enclosure where you put your window. You'd also want to make sure it is very tightly sealed so you don't get any air leakage around it. I'm not sure if you could use multiple layers of thinner plexi, but I suppose that could work.
Old 01-10-08, 12:11 PM   #14 (Link)
Alias: Mike
User: #8033
Since: Apr 2007
I saw a pic of a Decware sub that had a plexiglass top. I beleive it was 3/4 inch thick plexiglass.
Similar Threads
What's the best game store franchise? Sonnie Computers | Games | HTPC | Digital Devices 12 09-28-07 07:17 PM
Adventure Game Recommendations Tiddler Computers | Games | HTPC | Digital Devices 14 09-12-07 09:14 AM
College Game Day JCD Chat Box 12 09-18-06 11:09 PM
BFD Questions! House Curve Questions! RyanJNielson BFD Forum 5 09-05-06 09:34 AM
A quick hello Danny Welcome | Member Introduction 1 05-11-06 11:54 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189
