Can a high pass subsonic filter be setup in a BFD? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
DIY Subwoofers
Discuss Can a high pass subsonic filter be setup in a BFD? in the DIY Speakers and Subwoofers forum; Can a high pass subsonic filter be setup in a BFD? If not, anyone ever measured the low-end response of the BFD? It's advertised as 20Hz-20kHz at -3 dB, does it ...
Old 01-08-08, 10:23 PM   #1 (Link)
Alias: deromax
Loc: Shawinigan-sud, PQ, Canad
User: #13218
Since: Nov 2007
deromax is offline
If not, anyone ever measured the low-end response of the BFD? It's advertised as 20Hz-20kHz at -3 dB, does it roll off significantly below 20 Hz?
Thanks!
Old 01-08-08, 10:34 PM   #2 (Link)
Alias: Jerm357
Loc: Detroit
Jerm357's Avatar
User: #717
Jerm357 is offline
Re: Can a high pass subsonic filter be setup in a BFD?
Here you go.
Old 01-10-08, 10:53 AM   #3 (Link)
Alias: OJ
Loc: Toronto, Ontario
Owen Bartley's Avatar
User: #3144
Since: Oct 2006
Owen Bartley is offline
Wow, that's pretty impressive actually! Thanks for putting that into perspective Jerm.
deromax, you can't really do a proper subsonic filter with the 1124, because it doesn't support shelf filters. I can't remember if the 2496 does or not, and a quick Google didn't help much. What you CAN do is construct a pseudo shelf with a couple of very sharp cuts below the frequency you'd like to cut off at, maybe even one that isn't so sharp to start the roll off a little below the cuttof frequency. It's a bit of a hack job, but it should help to protect your driver a bit.
Old 01-10-08, 11:01 AM   #4 (Link)
Alias: brucek
User: #6
brucek is online now
Not really possible, since the lowest programmable filter is 20Hz. To affect below 20Hz, you'd require a bandwidth that would affect an equal amount above 20Hz, which wouldn't be desireable...
The BFD can approximate an LPF, but not an HPF......
Old 01-10-08, 06:41 PM   #5 (Link)
Alias: deromax
User: #13218
Since: Nov 2007
deromax is offline
Hello! The 2496 allows a high pass at a minimum of 20 Hz. I'm doing exactly this, with excellent results. But I may decide to reclaim two output channels on the 2496 to bi-amp my upcoming center channel speaker project. So the sub processing would have to migrate to some other processor for P-EQ and subsonic filter. My subs being vented, the subsonic filter is requiered.
Also, thanks Jerm357 for the graphs!
Old 01-10-08, 09:03 PM   #6 (Link)
Alias: Jerm357
Loc: Detroit
Jerm357's Avatar
User: #717
Jerm357 is offline
Your welcome, but all the measurements were done by Ilkka so all the credit goes to him. I figured these graphs would come in handy some time ago, so I saved it.
Old 01-11-08, 08:32 PM   #7 (Link)
Alias: OJ
User: #3144
Since: Oct 2006
brucek wrote: View Post
Ah, . I figured I'd get something wrong if I went and ran my mouth off on theory alone. Thanks for the correction Bruce, I probably should have dug out my manual, or at least looked it up online. For some reason I thought I remembered putting in some low boost on my sub, but it must have been at or just above 20Hz.
Similar Threads
BFD as a low pass sil180sr BFD Forum 19 01-07-08 04:58 PM
Defeating a High-Pass Filter Josuah Home Audio Subwoofers 14 11-03-07 10:21 PM
Add On Subsonic Filter Mike P. DIY Subwoofers 17 10-08-07 11:52 AM
High Pass Filter / Low Pass Filter bnw DIY Subwoofers 16 09-30-07 07:41 PM
Does an (S)LLT require a subsonic filter? brucek SoundSplinter 40 04-07-07 05:53 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202
