| DIY Subwoofers Adire TempestDiscuss Adire Tempest in the DIY Speakers and Subwoofers forum; Adire Tempest Notice some are using Tempest subs.
I just google'd Adire Tempest and it shows they are out of business.
Now ... |
| | #2 (Link) | |||
| Re: Adire Tempest You can't get the Adire Tempest anymore unless you can find a used one. DIYCable has the Exodus Tempest-X which is an XBL^2 driver which people have started using. I'm not sure how similar it is to the Adire Tempest, but from all reports it is a great driver at a great price. http://www.diycable.com/main/product...d1a13aad8708bf | |||
| | #3 (Link) | |||
| Re: Adire Tempest Geoff - Ok, I figure there was an alternative As for subs, recently I got a Cadence (2 days ago) and I am enjoying it, but at times I get some baffle sound, which from when I talked to Cadence he said "Muddy" sound. The tech @ Cadence told me that the driver that in the CSX-15 is basically a Dayton Classic 15", but did not comment if it was the "Dayton". However it does look like it (at least from the picture off parts express).Anyways - the tech told me that if I wanted to, I can replace the sub w/ either the Dayton RSS390HO or RSS390HF. He said both of these driver w/ that box and amp would be a better choice for improving sound and get rid of the muddy sound I kind of hear (at times). He said by what I want, he recommend that I get the RSS390HF. Since I been looking at Tempest and this one you mentioned above (that link), How would this Tempest-X 15 be comparable to either one of the two Daytons that I was recommended. I don't understand these specs , lol? ![]() | |||
| | #4 (Link) | |||
| | Re: Adire Tempest There is a big difference between the RSS390HF and the Tempest-X. The tempest-X has twice the Xmax. Either sub needs a specifc size box to get the most out of them. Whether the Tempest is right for your application depends on what size box you have. More info is needed to determine a recommendation. How big is the Cadence sub? What is the model number? | |||
| | #5 (Link) | ||||
| Re: Adire Tempest Quote:
here: http://www.cadencestore.com/ProductC...&idproduct=398 Cabinet Size: 18.5"(w) x 17.75"(d) x 21"(h). 3/4" High Density MDF Fiber Construction. | ||||
| | #6 (Link) | |||
| Re: Adire Tempest I do want to mention that the Cadence rep is very proud of is there AMPs on these cabinets. He told me a secret and not to mention his name if I put it out; which I didn't. ~ But he said this AMP can go down to a 1.5 ohm load, but do admit it will for sure accept 2ohm and did not hesitate w/ the response. Not sure if this really matters.... but.....I just wanted to let you know | |||
| | #8 (Link) | ||||
Suggestions? Would you say just go w/ the Dayton? ![]() | ||||
| | #11 (Link) | ||||
I have the sub in the right front corner(now). Maybe putting the sub at near field and behind me maybe right rear corner? Last edited by Picture_Shooter; 01-23-08 at 02:31 PM. | ||||
| | #13 (Link) | ||||
,, but sure, I guess I need a work-out. Anyways here is where its at right now: ![]() | ||||
| | #14 (Link) | |||
| Re: Adire Tempest Mike - ok, need a beer right about now ![]() So anyways. I found that keeping the sub where it was, but moved it up forward away from wall 10" and moved the sub 7" away from right side of the wall, then lowered the amp level, turned the bass boost to +3 and now this sub is clean!! This amp is by far as Cadence told me has more power then the sub can handle. What I did was borrow this kids BASS cd from work (young kid , around 19 yrs old and has 4- 10" XXX's in a Mitsu Eclipse and recommend me tuned my sub w/ this BASS BOY and Tech-Master PEB cd's. Let me say.. [Wow!]!!!!! Talk about BOOM []!! Well, here is my happy settings: ![]() Oh I know the HZ is little high and these cds probably won't hit that range, but dang!! Love'in it!!Thanks for all your help Last edited by brent_s; 01-23-08 at 09:25 PM. Reason: language rules | |||
| | #16 (Link) | |||
| Re: Adire Tempest Mike, glad you're happy. Just a thought though, since you were considering upgrading drivers. That cabinet is ported, which makes picking a suitable driver a little more complex unless you seal the port. Otherwise, you'll need to determine the exact net air volume of the cabinet. Using the volume and the port width, height and length, you can calculate the tuning frequency to use when running models for potential replacements. -Brent | |||
| | #17 (Link) | |||
| Re: Adire Tempest I guess that just goes to show you how important placement is with all speakers. I should really think about moving my (original) Tempest around, since it's in the corner now, and a little boomier than I'd like. The only problem is I don't have too many options or open areas... but your success with a small movement has inspired me to try little shifts! | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Shiva-X and Tempest-X | jagman | DIY Subwoofers | 8 | Today 01:57 AM |
| Tempest-X 15" on order! | pappaj | DIY Subwoofers | 69 | 02-26-08 03:17 PM |
| Adire Tumult info needed | BlkTS02 | DIY Subwoofers | 5 | 11-22-07 12:00 AM |
| Shivas/tempest/ADIRE | ImprezaSQ | DIY Subwoofers | 0 | 01-31-07 09:08 AM |
| help whit adire | håkan | DIY Subwoofers | 4 | 10-09-06 12:42 PM |
