| DIY Subwoofers non-linear shaped room bass problemsDiscuss non-linear shaped room bass problems in the DIY Speakers and Subwoofers forum; non-linear shaped room bass problems I have had a lot of trouble getting the sub-bass to sound right in my listening position. I have an ... |
| | #1 (Link) | |||
| non-linear shaped room bass problems I have had a lot of trouble getting the sub-bass to sound right in my listening position. I have an O-Audio 500W amp that has nice tuning features. I am also using Harmon-Kardon AVR 146 with DIY front speakers w HiVi Research 8" and Morel MD20T dome tweeter. On the right side the nearest wall is 7'. On Left side there is an open space leading into another room. When I stand 3 feet away and centered between from the front speakers it sounds great. But, when I move back to my recliner, I don't hear as much punch. I have moved the subwoofer many times and tuning it is not really the problem. I seem to be losing the mid-bass. I am considering rearanging the entire system. I am trying to figure out how to uplaod a Visio drawing so forum members can see the layout of the room. Maybe I have posted this in the wrong area. If so forgive me. I will move it. Have to get back to work now. Peace | |||
| | #3 (Link) | |||
| Re: non-linear shaped room bass problems Crossover is set at 80Hz. The room is 'sort-of' L-shaped. Sub is next to TV stand along one wall and recliner is along opposite wall. If the room were an upside-down L, the entrance of my apt. would be at the bottom of the long vertical line and listening area the short horizontal line. Does make any sense? I made an MS Visio drawing but have to figure out some way to upload it or link to URL. I moved the front speakers away from the wall some, changed sub amp's parametric EQ setting to High Q around 40Hz and -8db. It was set to lowest Q at 70Hz -6db. The new setting brought back the punch and smoothness. I don't have a spectrum analyzer right now and am going by ear alone. Also, since I mostly watch TV programming and the mix on each channel differs, that makes things even tougher to judge. I can listen to 'Dark Side of the Moon' and get the system set where I think it is great. Then, when I change back to TV sound, one channel sounds boomy and another sounds thin. It would be nice if there were more consistency. I used the room modes calculator found at http://www.marktaw.com/recording/Aco...WaveCalcu.html I agree with you about room mode problem. THANKS Peace:-) | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Low bass - small room | Wayde | Home Audio Subwoofers | 6 | 01-16-08 10:49 AM |
| Do you treat a room to increase bass | jwhite8086 | Home Audio Acoustics | 22 | 12-01-07 03:47 PM |
| Calculating Room Modes - Odd Shaped Room | Bob in St. Louis | Home Theater Design and Construction | 25 | 02-20-07 12:15 PM |
| Treatment of an L shaped room | letzleta | Home Audio Acoustics | 1 | 02-13-07 12:13 PM |
| My Graph..Help with room speaker problems | SDA10 | REW Forum | 3 | 09-04-06 06:15 PM |
