Trouble getting best performance from DVC subwoofers - Home Theater Systems - Electronics and Forum - HomeTheaterShack
DIY Subwoofers
Discuss Trouble getting best performance from DVC subwoofers in the DIY Speakers and Subwoofers forum; Trouble getting best performance from DVC subwoofers I need a little advice on how to handle DVC woofers. For instance, when I use the posted parameters for ...
Old 03-04-08, 09:04 PM   #1 (Link)
Alias: HB
Loc: Dietrich, Idaho
User: #13514
Since: Nov 2007
Brian Hinther is offline
I need a little advice on how to handle DVC woofers. For instance, when I use the posted parameters for the Tempest-X and tell BassBox Pro I want to feed the voice coils individually, I get a recommendation for an 18 cu. ft. box and a beautiful curve like the top one in my attachment.
However, if I tell it I want to run the voice coils in parallel and ask it to suggest a box size, it cuts the box volume, Qes, Re, Le and Qts values all in half and generates a much less inspired curve like the bottom one. The curve for a series hookup is much the same.
Am I doing something wrong? Is this just the nature of some dual voice coil woofers? Or is BassBox Pro totally messed up? Thanks for any feedback you can give me.
Old 03-05-08, 07:16 PM   #2 (Link)
Alias: Warmon
Loc: Chester VA USA
Warmon's Avatar
User: #11066
Since: Aug 2007
Warmon is offline
Re: Trouble getting best performance from DVC subwoofers
I'd ask Kevin directly, but the site says Re: 3.65 Ohms (Voice Coils wired in parallel) - could that be it? When you tell it to wire in parallel it should say 3.65, not half that.
Warmon - "know what I mean Vern"
Old 03-05-08, 09:41 PM   #3 (Link)
Alias: HB
User: #13514
Since: Nov 2007
Oh, my! Thanks for pointing that out. I don't know how I missed it, but life just started to make more sense.
Similar Threads
Torrent Audio Mistral 12 DVC jwh7399 DIY Subwoofers - Sealed and Ported 7 03-03-08 02:18 PM
DSP1124P performance??? vince BFD Forum 11 11-09-07 09:48 AM
SVC or DVC ... again fiksdal DIY Subwoofers 1 07-29-07 08:14 PM
SVC or DVC tgoode DIY Subwoofers 4 07-03-07 09:39 AM
buttkicker performance rhino2 DIY Subwoofers 11 11-30-06 07:25 AM
Mach 5 Audio
