| DIY Subwoofers Exodus Audio Maelstrom-X(XJ-18) new high excursion 18" driverDiscuss Exodus Audio Maelstrom-X(XJ-18) new high excursion 18" driver in the DIY Speakers and Subwoofers forum; Exodus Audio Maelstrom-X(XJ-18) new high excursion 18" driver It seems that Exodus Audio XJ18 final engineering sample parameters are ready. : Finally something very promising against mighty LMS-5400. ... |
| | #1 (Link) | |||
| Exodus Audio Maelstrom-X(XJ-18) new high excursion 18" driver It seems that Exodus Audio XJ18 final engineering sample parameters are ready. : Finally something very promising against mighty LMS-5400. It doubt it will beat LMS, but I think it will be the next best thing, and you will actually be able to buy it some day. The price is supposed to land around 350$. Not bad compared to LMS. Looking forward to see this thing at Ilkkas sobwoofer shootout. Production should start sometime during april, so it seems that there will not be XJ18 for spring subwoofer shootout. Anyway, it models great in both enclosures, sealed and vented. Here are my quick examples: Sealed ![]() ![]() Vented ![]() ![]() ![]() Anyone else ready for experience some serious bass? ![]() Here are the parameters: Re: 3.1 Le: 0.87mH Fs: 17.7 Hz Qms: 7.8 Qes: .38 Qts: .36 Mms: 494g Cms: .170 mm m/N Vas: 324L Sd: 1182 cm^2 BL: 21.17 Xmax: 33mm Xmech: 42mm Source The whole XJ18 thread Last edited by anidabi; 03-07-08 at 01:36 PM. Reason: Title was a bit off | |||
| | #2 (Link) | |||
| Re: Exodus Audio XJ18(Maelstrom-X) high output 18" driver That looks good, any pics of the actual driver? Samsung 24" LCD Widescreen 245BW X-Fi Elite Pro Soundcard B&W 685 AA hAvoc 18" with 2 PR1816 in 7.3cu.ft@18.5hz Crown XTi1000 Crown XTi2000 the big summer upgrade(new big sized bookshelves with new sub setup)**Soon to be a new MTM DIY project** | |||
| | #3 (Link) | ||||
| Re: Exodus Audio XJ18(Maelstrom-X) high output 18" driver Quote:
| | #4 (Link) | ||||||
| Re: Exodus Audio XJ18(Maelstrom-X) high output 18" driver Kevin Haskins at Audiocircle: Quote:
When simulating it comes very close to LSM in every aspect. Except LSM is not ideal for ported solution and XJ-18 seems to be a lot better for that. I doubt XJ-18 has as low distortion levels than LMS. Still it sure should have low distortion levels too, so says Kevin at audiocircle:Quote:
| | #5 (Link) | |||
| Re: Exodus Audio XJ18(Maelstrom-X) high output 18" driver I am very interested in this driver, it looks great in WinIsd, with a small sealed enclosure! Kevin says that they are still going to build the super duper 18" model, but it will be a while. | |||
| | #6 (Link) | |||
| Re: Exodus Audio XJ18(Maelstrom-X) high output 18" driver The Sicko-18 from Exodus is on the design table. It looks like it might be at the LMS level. Of course it will be ~$1000 per driver. The Maelstrom-X should be a cool driver. There are certainly a lot of reasonably priced 18" solutions coming out. $350 for an 18" with XBL^2, 33 mm Xmax and 42 mm Xmech? To me that is quite a deal. | |||
| | #7 (Link) | ||||
| | #8 (Link) | ||||
If you don't have a BFD for your sub, get one fast! If you don't have REW, get it now! | ||||
| | #9 (Link) | |||||
![]() Here is a snippet from AVS forum: Quote:
| | #10 (Link) | |||
| Re: Exodus Audio XJ18(Maelstrom-X) high output 18" driver Yeah, I think Kevin has since bumped the Xmax to around 55mm and the Xmech to around 70mm (he talks about it later in that thread). He may also have discussed using a 14" spider. There's a model of the motor at the end of that thread now and it seems to use a triple split gap (three gaps). Needless to say it's gonna be nuts. | |||
| | #11 (Link) | |||
| Re: Exodus Audio Maelstrom-X(XJ-18) new high excursion 18" driver In case you shacksters havn't heard the maelstrom-x pre-order has started. 299$ for one, when the normal price should be 350$. Pre-order special ends april 10th. http://www.diycable.com/main/product...roducts_id=681Note that the picture is not from the final product. That is only modified engineering sample picture. | |||
| | #12 (Link) | ||||
| Re: Exodus Audio Maelstrom-X(XJ-18) new high excursion 18" driver Good Afternoon All, I pre-ordered four Maelstroms this week; they will be driven by a pair of Face Audio F1200 amps (already in hand). I'm still deciding on alignments though... Regards, Larry Quote:
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Exodus Audio Keplers | jr1414 | DIY Speakers | 8 | 04-01-08 01:14 PM |
| Sneak a peak new Ascendant Audio driver lineup | anidabi | DIY Subwoofers | 5 | 07-17-07 07:45 PM |
| Measuring driver excursion | Chrisbee | DIY Subwoofers | 24 | 06-03-07 02:10 AM |
| New Book - High-Performance Audio Systems | geekwithfamily | Home Theater, Audio and Video News | 0 | 03-26-07 11:40 AM |
| Porcupine Tree in High Resolution Audio | MrPorterhouse | Music and DVD Concerts | 29 | 01-27-07 07:16 PM |
