| DIY Subwoofers Using an "IB" driver in a Sealed Enclosure?Discuss Using an "IB" driver in a Sealed Enclosure? in the DIY Speakers and Subwoofers forum; Using an "IB" driver in a Sealed Enclosure? I ran across an AE IB15 setup the other day and that got me cheching into those drivers. The T/S ... |
| | #1 (Link) | |||
| Using an "IB" driver in a Sealed Enclosure? ![]() I ran across an AE IB15 setup the other day and that got me cheching into those drivers. The T/S parameters look good and that thing has the lowest Fs I have ever seen in a 15"er. The price is rather attractive too. I don't think I would ever have enough space to do an actual IB setup. However, I could probably swing some really large sealed boxes. I was thinking on the order of 16.5 cu.ft. and completely stuffed with dampening material. It models up reasonably well and the sealed boxes help to limit excursion in the sub-20Hz region. I just don't know if there is anything out of the ordinary about using an "IB" driver in this sort of situation. I think four of these and a little EQ would rock!! What are your opinions? Also...any suggestions on an appropriate two channel pro amp? They don't need much...probably 300W per channel into 4ohms. Here is a link to the drivers: http://www.aespeakers.com/phpbb2/vie....php?f=3&t=536 | |||
| | #3 (Link) | |||
| Re: Using an "IB" driver in a Sealed Enclosure? Actually, I'm not interested unless I can produce a response down to 10 Hz. I realize that using a sealed box rather than an IB will restrict my low end some, but it models up only a few dB lower at 10Hz. Am I missing something? Sealed 470L box. ![]() 4000L IB ![]() | |||
| Thread Tools | |
Similar Threads | ||||
| 15" vs 18", 1 driver vs 2 vs 4, 1 enclosure vs 2 | atledreier | DIY Subwoofers - Sealed and Ported | 1 | 02-08-08 11:48 AM |
| ported sub using "pro sound" driver | oddness | DIY Subwoofers - Sealed and Ported | 8 | 01-23-08 11:44 PM |
| Episode 21 - $99 the end of the War?, "The Contract", They Might Be Giants "Factory" | eugovector | Real HT Info Podcast | 10 | 11-13-07 06:07 PM |
| Ported enclosure size for the 18" beast! | Mongrel714 | SoundSplinter | 54 | 07-24-07 09:38 PM |
| 12" Sub for sealed enclosure | Pupton | DIY Subwoofers - Sealed and Ported | 8 | 01-31-07 08:57 PM |
