Fusion NV-15 sub for HT? Win-ISD struggles - Home Theater Systems - Electronics and Forum - HomeTheaterShack
DIY Subwoofers
Discuss Fusion NV-15 sub for HT? Win-ISD struggles in the DIY Speakers and Subwoofers forum; Fusion NV-15 sub for HT? Win-ISD struggles I'm very new to the idea of DIY subs/speakers, but am interested in executing my 1st build in the near ...
Old 03-08-08, 10:56 AM   #1 (Link)
Alias: Jim
Loc: Cincinnati
User: #10263
Since: Jul 2007
cynical2 is offline
I'm very new to the idea of DIY subs/speakers, but am interested in executing my 1st build in the near future.
I came across this sub for $100 new (compared to $350 in stores), so I thought it would be worth looking at in Win-ISD. But, the parameters don't seem consistent when I go to create the model. No matter what order I enter the parameters, something ends up way out of whack. I've done the methods recommended by Collo and others, but I can't get things to jive. And, I don't understand the fundamentals behind the model enough that I know which params are most important for a reasonably accurate model.
Basically, I'm trying to find out (1) how it models, and (2) based on the model results, does it look like it is a "deal" for a HT DIY build (or is this good for cars only). BTW, my options for a DIY build are wide open...not particularly limited by space, etc.
Thanks to anyone who can help!
Parameters from Fusion website:
Old 03-08-08, 12:15 PM   #2 (Link)
Alias: Mike
User: #8033
Since: Apr 2007
Mike P. is online now
Re: Fusion NV-15 sub for HT? Win-ISD struggles
Have you tried unchecking the "auto calculate unknowns" box before you enter any parameters into the WinISD "driver editor"?
We're all in this together!
Old 03-08-08, 12:19 PM   #3 (Link)
Alias: Jim
Loc: Cincinnati
User: #10263
Since: Jul 2007
cynical2 is offline
Mike P. wrote: View Post
Thanks, Mike. No, I haven't tried unchecking the box. I can try that though. Won't that create "inconsistent formulas" or something like that, and block me from saving it out?
Anyway, I'll try it and see what happens.
Old 03-08-08, 12:26 PM   #4 (Link)
Alias: Mike
User: #8033
Since: Apr 2007
Unchecking the box will force WinISD to accept the parameters you enter without causing a conflict. There will be no problem saving the file.
Old 03-08-08, 12:39 PM   #5 (Link)
Alias: Jim
Loc: Cincinnati
User: #10263
Since: Jul 2007
cynical2 is offline
Yep, that worked Mike. Thanks!
How should I think of the maximum port velocity? Do I need to worry about it going too high at any possible frequency, or do I only care about a certain frequency range?
Old 03-08-08, 01:47 PM   #6 (Link)
Alias: Jim
Loc: Cincinnati
User: #10263
Since: Jul 2007
cynical2 is offline
Also, how do I know if I should use 40mm or 20mm for Xmax?
Every place that I looked that was selling them, and on Fusion's website, it just said "Xmax: 40mm". But I downloaded the manual (a piece of which is in the first post), and it has "Xmax total: 40mm"...the word "total" being added makes me think of peak-to-peak instead of 1-way.
20mm each way seems more reasonable (based on other subs I've looked at, which seem to max out around 28mm), but if I get anywhere near the rated wattage of the driver, it would bottom out (at least using my newbie modeling skills).
I've attached the driver file I made, in case anyone is willing to play with this driver and see if they find any workable setup...
File Type: zip fusion_nv15_no_autocalculate.zip (559 Bytes, 3 views)
Old 03-08-08, 03:40 PM   #7 (Link)
Alias: Steve
Loc: Shoreview Minnesota
User: #5693
Since: Jan 2007
ccdoggy is offline
Yes that looks to be peak to peak, you should use one way distance (90% sure).
I tried using that file in WinISD alpha and couldent get the numbers to work out to allow me to use it.
Old 03-08-08, 04:38 PM   #8 (Link)
Alias: Mike
User: #8033
Since: Apr 2007
The file you posted works for me. The problem with this sub is the little amount of power it takes to reach maximum xmax. In 8 cubic feet tuned to 17 hz xmax is reaches with 115 watts. SPL at 20 hz would be 109db plus room gain which isn't too bad.
Old 03-08-08, 04:53 PM   #9 (Link)
Alias: Jim
Loc: Cincinnati
User: #10263
Since: Jul 2007
cynical2 is offline
Yeah, looks like you're seeing the same thing as me. Why in the heck they would rate a speaker at 1100W RMS that bottoms out at 115W doesn't make sense to me.
Anyway, thanks for your help. At least now I know that I can override the Win-ISD issues I was having.
And the driver search continues...
Old 03-08-08, 05:28 PM   #10 (Link)
Alias: eyekode
Loc: Apex, NC
eyekode's Avatar
User: #15723
Since: Jan 2008
eyekode is offline
I didn't run the numbers to verify, but 109db @ 20hz with 115 watts sounds amazingly good to me. Need more then 109db? Add a second sub. I would love to be able to run such low power with such high SPL. But honestly that sensitivity is insane, I wonder if these drivers live up to the parameters...
Old 03-08-08, 05:54 PM   #11 (Link)
Alias: Mike
User: #8033
Since: Apr 2007
eyekode wrote: View Post
That's the 100 dollar question. Do they perform as stated.
Old 03-08-08, 06:07 PM   #12 (Link)
Alias: Jim
Loc: Cincinnati
User: #10263
Since: Jul 2007
cynical2 is offline
Hey, that's what y'all are supposed to tell me.
Oh, and no...I'm not into blowing out my eardrums (after all, I'm old). OK, truth be told, the problem isn't that I'm old. It's that my wife and kids would slap me.
Does anyone even know anything about the manufacturer's reputation?
Old 03-08-08, 09:02 PM   #13 (Link)
Alias: Mike
User: #8033
Since: Apr 2007
I'm not to familiar with car audio. I've never heard of Fusion until you posted it.
Old 03-08-08, 09:49 PM   #14 (Link)
Alias: Jim
Loc: Cincinnati
User: #10263
Since: Jul 2007
cynical2 is offline
Does the Sd look right? It gives a Dd of < 10" for a 15" sub.
I changed the Sd value to 132in^2 and the Dd to 12.9", and the behavior starts to look much more "normal". Is it possible to have an Sd of 78in^2 for a 15"?
Old 03-08-08, 09:51 PM   #15 (Link)
Alias: anthony
User: #16309
Since: Feb 2008
mayhem13 is offline
I guess the big question is can you trust the numbers? Thats a leap of faith IMO. Take a look at some of the drivers others are using on the forums where actual performance and design parameters are close. That driver claims monsterous efficiency in Unibox models.
Old 03-08-08, 10:03 PM   #16 (Link)
Alias: anthony
User: #16309
Since: Feb 2008
mayhem13 is offline
Oh by the way, in 200L at 1100w-118db flat from 100hz down to 23hz tuned at 19hz dual 6" ports 56" long. Xmax used 25mm which was 40mm-15mm mechanical xmax given meaning xmax?-xmech not sure what they mean there? Anyhoose pretty impressive but $345.00. Reaches xmax25mm at 25-28hz at 1100w but doesn't overexcurse until below tune around 16.5hz.
Old 03-10-08, 06:48 PM   #17 (Link)
Alias: Geoff
Loc: Winnipeg, Canada
Geoff St. Germain's Avatar
User: #4919
Since: Dec 2006
Geoff St. Germain is offline
Unless you can find someone that's used it I'd be a bit wary. I've never run across this driver before on any car audio forum.
Old 03-10-08, 07:50 PM   #18 (Link)
Alias: Jim
Loc: Cincinnati
User: #10263
Since: Jul 2007
cynical2 is offline
Yeah, that's kind of the same conclusion I'm coming to after looking around. You would think at the price they're trying to sell them that they'd be a nice driver...but I don't want to find out that it's not in my HT.
Similar Threads
Win a DIY Theatre Screen Kit! Sonnie Forum Announcements | News 0 01-31-08 01:53 PM
What is it going to take to win the format war? HDBeat Home Theater, Audio and Video News 0 09-08-06 03:20 PM
Win Big! Win SVS! Sonnie SVSound 0 06-12-06 12:58 AM
Win Big! Win SVS! Sonnie Home Audio Speakers 0 06-12-06 12:57 AM
PB10-ISD on Clearance JCD SVSound 0 06-01-06 02:06 PM
Mach 5 Audio
