| DIY Subwoofers Cabling - LFE to Multiple Plate AmpsDiscuss Cabling - LFE to Multiple Plate Amps in the DIY Speakers and Subwoofers forum; Cabling - LFE to Multiple Plate Amps Hi guys,
Working on a little project here and have a question about cabling four active / powered subs to ... |
| | #1 (Link) | |||
| Cabling - LFE to Multiple Plate Amps Hi guys, Working on a little project here and have a question about cabling four active / powered subs to a single LFE / Sub out on a AV receiver. The subs don't have a pass thru RCA for daisy chaining. I have all the tools and such to make RCA cables using RG-6 Quad Shield...rca, bnc, F/coax, etc. Can I use 2way splitters / diplexers with in this connection with no probs?..call em diy "Y" adapters. Warmon - "know what I mean Vern" | |||
| | #2 (Link) | |||
| Re: Cabling - LFE to Multiple Plate Amps It should work. Some people find that if you split the signal too much it can weaken to the point it won't wake up auto-on subs. Mileage may vary. Also unless these are all stacked on top of each other I hope they have some sort of phase adjustment! | |||
| | #4 (Link) | |||
| Re: Cabling - LFE to Multiple Plate Amps Thanks guys! We are rehabbing a small public theater here at work and putting 4 new Infinity PS-212's on a 10' wall right under the screen. Strange room - was round, but now sorta fat crescent shaped. We added two small rooms in the space - one for the AV equipment and one for chair storage. They'll be front firing right at the audience of about 30 people with a short 12 minute video. The subs main role is to give low end impact to civil war artillery / cannon fire in the video. Do you see any phasing problems with this setup?...choices are 0 & 180. Warmon - "know what I mean Vern" | |||
| | #5 (Link) | |||
| Re: Cabling - LFE to Multiple Plate Amps well the phase could be fine, could be bad. you wont really know till you get them in there and playing. But you can always move them and try and fix the phase issues since you have a large area to play with. | |||
| | #6 (Link) | ||||
| Re: Cabling - LFE to Multiple Plate Amps Quote:
![]() Try it. If you hear headroom issues, but have enough gain available, you may add resistors in your splitter to up the impedance value, then add gain to regain level. Or even better, you could use an audio distribution amplifier. You could probably build one with a few OP amp for cheap. | ||||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| 2 subs, 2 plate amps, 1 enclosure? | matt98svt | DIY Subwoofers | 3 | 01-29-08 01:04 AM |
| Plate amps for active speakers | judahben | DIY Speakers | 7 | 11-04-07 11:50 AM |
| Cheap plate amps? | mgboy | Classifieds - Audio Equipment | 7 | 09-23-07 08:54 PM |
| Pro amps replacing plate amps for most people? | Owen Bartley | DIY Subwoofers | 6 | 06-05-07 10:11 AM |
| Do I have my cabling correct? | lovingdvd | REW Forum | 5 | 01-24-07 01:00 PM |
