red (clip LED) on DSP1124p
2K views 6 replies 4 participants last post by  Nuance
#1 ·
Hi, I went to bypass mode (flashing in/out button) and checked the levels before EQing. The Level bar was satisfactory only hit yellow mostly. But after EQ, sometimes the louder bass section in movies will hit the red region and I didn't even go loudest yet.
Is this bad, If I went to bypass mode again the bar is reading lower
For EQ filters I have a 4db gain at 22 hz and 5 db gain in 29 hz. is the only gain I have there
#5 ·
I lowered the input by half dB and then re-equalized from scratch, this time I raised the volume of the sub knob from 11'o clock to 1-2 o clock to reach the top of the curve (about 81ish db). That way no need to use +5 filters and no surprises. I just use filters to bring down the curve, took 1 less filter too this time.
I noticed it doesn't take much to go between the yellow and red LEDs, it is about 1 DB or so. The BFD has seem to a bit of narrow operating range!? Does anyone know much beyond red before it clips?
If I turn the receiver trim way down I would need to turn way up on the sub amp, it's a no win.
so the 4db setting doesn't change the volume at all, it's just internal operating level? Why does the guide not recommend this setting?
#6 ·
According to brucek’s bench test review, once the meter hits red the BFD clips with only 1/10 v additional signal in the 10 dBV setting. IOW, headroom above the clip LED is little to none. IMO, it’s better to leave some headroom in the signal input, maxing out at the top green LED, if that.
Not sure why you would feel that way? As long as you can ultimately achieve the in-room sub levels you need, there’s no harm in reducing the signal downstream and turning up the sub gain.
so the +4db setting doesn't change the volume at all, it's just internal operating level? Why does the guide not recommend this setting?
Because the 4 dBu setting increases the BFD’s noise levels dramatically. That’s not a big deal with subs, fortunately. Most home equipment doesn’t have enough output for the +4 dBu setting, which is about 20 dB higher than what home gear typically puts out. So, the -10 dBV setting is typically the most appropriate for home equipment.
