Audio General, Inc.: Great deals on projectors, screens and electronics. Epik Subwoofers manufactures world-leading high performance subwoofers for die-hard home theater and music enthusiasts who won't settle for anything less than the best. Power Sound Audio designs, develops, and assembles high quality loudspeakers and subwoofers for home theater environments. Visual Apex: The most competitive pricing for home theater projectors... and built on customer satisfaction! OPPO Digital - Universal Network 3D Blu-ray Players - Buy Direct from the Manufacturer KEN KREISEL Sound & Design Genelec: Active Speakers and Speaker Systems Creative Sound Solutions: Loudspeaker kits and components for subwoofers, midwoofers, woofers and full range speakers! Emotiva is your Home Theater Component Source for Audiophile Quality Home Theater Equipment at Factory Direct Prices RAM Electronics: Audio, Video, Home Theater and Computer Cables. GIK Acoustics: Home audio acoustics at its best... especially when you have help from the owners right here at the Shack!  Check out their very affordable acoustic panels! Ultimate Home Entertainment: Providing home theater seating and accessories such as popcorn machines and signage... at very affordable prices! Check out the Woot product for today! Parts Express: Excellent Source for DIY Speaker and Subwoofer Projects! DIY Parts and Accessories as well as custom built cables. Fast worldwide shipping. Madisound Marantz Value Electronics: A trusted retailer and custom installer that specializes in whole-house audio, home theater, Plasma, LCD, LED, HDTVs, Blu-ray and more. Discount Merchant:  If you need a replacement bulb for your video device... look no further... save big! SVSound GR Research - Offering audiophile quality loudspeakerkits, high quality crossover components, drivers and accessories. Also providing a wide range of design services from complete commercial product line design to assistance with individual custom products and upgrades.
Home Rules Register Gallery Glossary FAQ
Room EQ Wizard
Go Back   Home Theater Forum and Systems - HomeTheaterShack.com > Equalization | Calibration > Electronic Processing/Equalization Devices
Donations Reviews Vendors
Views: 486 - Replies: 4
Old 11-05-10, 08:54 PM   #1
Silver Supporter
Since: Sep 2010
  mrderrick is offline
I started this thread.
1124P Stuck In Bypass?
Let me first say that this site has been a indispensable resource for me in setting up my 1124P.
All was pure musical bliss, then I decided to re-work my seating position.
I got rid of an overstuffed leather love seat and placed a row of low cabinets along my back wall.
My seating position moved about 6 more inches out into the room.
Pure listening hell was the overall result.
So I set up my RTA to see what the response was.
The 1124Ps output was active with filters (I think) and the curve was way off.
I thought that all I would have to do was reset my filter settings to get my curve back.
No go, no matter what level settings I enter for a frequency, there is no change in response.
The In/Out yellow light is on.
The settings are set in Hz, not KHz.
The freq points are all set to PA.
The settings are saved after I set them.
I just can not get the frequencies to adjust.
I have a bizarre 10dB peak that covers 25 - 40 Hz.
I did remove the 1124P to recheck the response with the RTA.
Is it possible that I positioned myself in a room node that can't be corrected by EQ?
Could the 1124P be stuck in bypass and not processing the signal?
The 1124P is connected between my Atmasphere MP3 pre and active Avantgarde Sub 225 bass units up to 140Hz.
The main Avantgarde Duo Omega horns are driven full range by the MP3 through Atmasphere M60s.
Any input on this issue will be greatly appreciated!
Old 11-06-10, 10:10 AM   #2
REW Author
Owner
JohnM's Avatar
John
UK
My Photo Gallery
  JohnM is online now
Re: 1124P Stuck In Bypass?
Did you disconnect the signal in the path to the main horns to make sure it is the sub bass units you are measuring?
Old 11-06-10, 01:18 PM   #3
Since: Aug 2010
  shinksma is offline
A couple of quick things to check:
Do you use just the left or right of the 1124? Did you accidentally swap the sides of the filters and/or connections? (That's the kind of silly thing I do...)
Can you try loading up really goofy EQ to the 1124, do a near-field measurement (not from the LP, but right next to the SW) - if nothing is changing response-wise with near-field measurements then indeed your 1124 is not impacting the signal.
Can you do a complete reset on the 1124 and start from scratch? See pg 16 of the manual (press filter select and store keys while powering up - keep pressed for one second after power-up).
Dunno what else to suggest...
shinksma
Old 11-06-10, 06:51 PM   #4
Silver Supporter
Since: Sep 2010
Re: 1124P Stuck In Bypass? SUCCESS!
I take measurements with the subs alone and with the horns.
Using 1/6 octave sine wave test tones and a 20 - 20 Khz sine wave sweep.
The Mic at about 80 degrees for the bass and on axis for the horns.
I tried some really wild settings and still had the same response.
So I started over from scratch after letting the 1124P sit for 24 hours disconnected from everything.
I re-took measurements for each channel and re-loaded the filter settings in channel 4, then transferring them to channel 10.
Everything is now back as it should be.
My only guess is that the 1124P may have had a "static" attack since the air is starting to dry out here in Pennsyltucky.
If the problem surfaces again I will try the reset.
Thanks for the suggestions.
All is right once again!
Old 11-07-10, 08:15 AM   #5
Since: Aug 2010
  shinksma is offline
Heh, yeah, electronics does weird things when affected by static (either local from you and the carpet or the big stuff between cloud and ground )
I discovered yesterday that my KVM switch was no longer happy (I'd not used it in a while, but it had been plugged in). In the past couple months my clothes dryer and washer were misbehaving. I suspect all of this is due to a nearby lightning strike about 2 months ago.
Hope it keeps working for you!
shinksma
 Reply     Post New Thread     Back to Top of Page
« Home Theater Shack > Equalization | Calibration > Electronic Processing/Equalization Devices »
1124p, bypass?, stuck
Bookmark and Share
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright ©2006 - 2013, Home Theater Shack, LLC.
OUR SPONSORS
Accessories4less
Audio General Inc
Chase Home Theater
Discount-Merchant
Emotiva
Epik Subwoofers
Exteris Audio
Genelec
GIK Acoustics
GR Research
HTD: Home Theater Direct
KEN KREISEL
Madisound
Marantz
MiniDSP
OPPO Digital
Power Sound Audio
RAM Electronics
Stereo Integrity
SVSound
Take Five Audio
The Audio Insider
Value Electronics
Visual Apex
The Sub Zone
OUR AFFILIATES
Abe's of Maine
Boston Acoustics A Series Speakers
Cables.com
Denon - Buy Direct. Free Shipping.
Electronics Express
Fluance
GamersGate
Harman
J&R.com
Shop for Harmony Remotes at Logitech
Shop MCM Electronics for Your Home Theater Needs
Musician's Friend Stupid Deal of the Day
Once You Know, You Newegg
Overstock.com
Parts Express: Your #1 Speaker Building Resource
Roku + Netflix = Instant Movies on your TV
Solid Signal Antenna Superstore
Sonos Wireless Music Player
SquareTrade Warranties
Vann's
vudu.com
Woot!
Zzounds
Abt Electronics
Best Buy
Butterfly Photo
Circuit City
DIRECTV
emusic.com
GameFly
HDtracks High Resolution Music Downloads
HP Computers
Klipsch
MarvelStore.com
Monoprice.com! Best quality products at the lowest price, Always!
Instantly watch from thousands of TV episodes & movies streaming from Netflix. Try Netflix for FREE!
OneCall
Buy Televisions at Panasonic.com
Paul's TV
SMS Audio
503327_Get Free Shipping At Sonic Electronix!
Sony
Super Media Store!
Velodyne
Official Shop of Warner Bros
World Wide Stereo
Epic 80 Home Theater Speakers
Search Engine Friendly URLs by vBSEO
