Hello,
I was wondering if the only difference between the Bheringer1124P and the FBQ2496 is the number of filers that are selectable? Is one unit perhaps quiter than the other? After using R+D software to measure my room that was designed using the Bolt perameters in mind to space out the modes as best or evenly as possible, I still have a couple of peaks I would like to remedy. I have built in bass traps in every corner and have treated the ceiling with suspended 2.5 inch floating panels, also heavily dampend my first reflections. The peaks I am left with are centered at 150hz and with quite a large bandwidth, also one around 3.5k, couple db. So I have done all I can do for now treatment wise. So if in fact there is no diff. between the two parametric EQ's other than filter count, than could the is the 1124p ok for full range or is there a better parametric out there that isn't in the millions, that would help tame these couple critical freaquency problems??????? I used the 1124p on my sub and with R+D was able to get the bass region beautiful!, but had to use cheater adapter to kill noise!
Sorry for the long post:nerd:
Vince
Vince
