| Exodus Audio Tempest X * 2 in 300L BR@17hzDiscuss Tempest X * 2 in 300L BR@17hz in the DIY Speakers and Subwoofers forum; Tempest X * 2 in 300L BR@17hz At last, at last
Having read this forum for the last year or more, getting so much help one any ... |
Views: 1072 - Replies: 19
| Tempest X * 2 in 300L BR@17hz At last, at last ![]() Having read this forum for the last year or more, getting so much help one any ?, and getting inspired be all the buildthreads with pic's. I think it should be me turn to show some stuff for all of you. This suBprojekt is one off many speakers/amps/acustics stuff, to go into our HT. I'am building 2 boxes, each one with 325L net vol, roughly gives 300L with all contractions, and they are tune to 17 hz with a 8" port. Just som few pic's to look at : ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() More to come Can't wait until they are done ![]() | ||||
| | #2 | ||||
| Re: Tempest X * 2 in 300L BR@17hz Nice bracing! ![]() | ||||
| | #3 | ||||
| Re: Tempest X * 2 in 300L BR@17hz Very sweet design. What speakers are you using? keep us posted with more pics. ![]() | ||||
| | #4 | ||||
| Re: Tempest X * 2 in 300L BR@17hz Nice work! Are you going to flare the ports? It does look like to me, that the internal port might be a bit close to the wall... perhaps? | ||||
| | #5 | ||||
| Re: Tempest X * 2 in 300L BR@17hz The driver is 2008 Tempest X 15". ![]() Regarding the port, the picture is cheating. It was only a testfit for the tube. Distance from the endpoint of the port, to nearest wall is larger than the dia of the port, roughly 22 cm. Yes I do flare the ports inside the box, and later perhaps also the outside. Need at testrun first, so i can see if it is needed. Just some more pic's | ||||
| | #6 | ||||
| Re: Tempest X * 2 in 300L BR@17hz Nice! That's some big boxes ![]() I notice we have the same speakers ![]() | ||||
| | #8 | ||||
| Re: Tempest X * 2 in 300L BR@17hz I like the 2031A much better...enough to buy 10. ![]() | ||||
| | #9 | ||||
| Re: Tempest X * 2 in 300L BR@17hz I've the 2030A - good value for the money in my opinion. ![]() | ||||
| | #10 | ||||
| Re: Tempest X * 2 in 300L BR@17hz 2031A and 2030A are good value for money, but they are not good enought in the theater ![]() I am also building and aktive LCR - more one that later. So far the 60w my cambrigde p500 delivers, makes me wonder if i really need 4 of these boxes ![]() | ||||
| | #11 | ||||
| Re: Tempest X * 2 in 300L BR@17hz I do wish that the B2031A had a bit more headroom at times but overall great bang for the buck. That's what the Klipsch's and EV pa speakers are for... | ||||
| | #12 | ||||
| Re: Tempest X * 2 in 300L BR@17hz Very nicely built, looks solid! Regarding the joints, you have carved in a ledge? so not using screws? only glue and that neat "lock"? Post measurements as soon as possible =) | ||||
| | #13 | |||||
| Re: Tempest X * 2 in 300L BR@17hz Quote:
Thats all.....almost. I did use 3 -4 skrews, just so i couldt keep pressure even over the entire surface. | |||||
| | #14 | ||||
| Re: Tempest X * 2 in 300L BR@17hz a little update.I desided not to veneer the cab's, and go with roundover egdes and a perle white finish. So far cab nr. 2 are almost done, and ready for painting. I will finish this box first, and then make the working one done last. But it is hard work![]() Pic's uploading tomorrow. | ||||
| | #15 | ||||
| Re: Tempest X * 2 in 300L BR@17hz I desided to use epoxy for coting and the finel finish. Normaly used to work with polyester/fiber, so this i going to be something new, but still in the same balllane i hope![]() Here is some pic's, where I apply the first testcoat of epoxy. It should be able to hold down the joint off the mdf boards, so they wont show over time ![]() ![]() ![]() ![]() ![]() More will come. | ||||
| | #17 | ||||
| Re: Tempest X * 2 in 300L BR@17hz I don't know but he did a fantastic job on that enclosure. Tempest will be back in stock in another month or so. Kevin Haskins Exodus Audio | ||||
| | #18 | ||||
| Re: Tempest X * 2 in 300L BR@17hz - Brandonnash - So far both cab's are up and running. Havent done the finish yet, as i have to more them around to find the best spot of placement - It cost some marks once in a while. When test and mesuremenst are as good is I can get, I will paint them. ![]() The sound is very good indeed, but I'm glad a second genII is out now. I do like to have more headroom, both thermal and mech. The original plan was 4 pcs, but in the initial test, one set seam enough. Now I have to rethink that statement ![]() although the house is![]() I will soon upload some more pic's of my HT room, and the placement of the sub's. Kevin - thanks for the nice words one the cab's Your drivers are and for a reasonable price indeed.![]() | ||||
| | #19 | ||||
| Re: Tempest X * 2 in 300L BR@17hz Small update - just bought the last 2 tempest X gen I.......... New plan for sub's in the HT.... 4 in total - smaller caps, just around 240 L @ 19 hz tune. Hope this will give some headroom in the 15 - 40 hz area.......at this point the 2 first 325 L don't Until i'am able to get my hand on 2-4 21" mal's, I wont go for the <15 hz area........tempest X gen I just can't do this area well![]() ![]() Will be back with pic's before christmas - i hope...have another buildprojekt that's very important - 50 kvm wood- and elektronic workplace ![]() ![]() | ||||
| | #20 | ||||
| Re: Tempest X * 2 in 300L BR@17hz Great! Post pics of your build progress. I enjoy watching your builds progress. I also like your use of the biscuits for the joints (I think you called them fish). | ||||
