Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > Exodus Audio
Exodus Audio
24'' Sealed Mal-X Modification Ideas
Discuss 24'' Sealed Mal-X Modification Ideas in the DIY Speakers and Subwoofers forum; 24'' Sealed Mal-X Modification Ideas Quite a few views and no reply so I'm guess this place isn't probably the best place to ask about ...
Views: 1180 - Replies: 51
Old 10-19-09, 01:02 PM   #51
Alias: Nate
User: #13967
Since: Dec 2007
  NateTTU is offline
Re: 24'' Sealed Mal-X Modification Ideas
Quite a few views and no reply so I'm guess this place isn't probably the best place to ask about that. Thats fine, in any case I think Kevin should have all the business and I shouldn't take away from that.
However, maybe one of you guys can help me with this thought:
My room is pretty small, but I find having currently one Mal-X in a 24'' sealed cube is just not quite enough for me. Since size is a big factor I have considering using 2 Mal-Xs in two 22'' boxes instead. However, for the same price and perhaps in an even smaller package I could get 2 Tempest drivers and 4 PRs. How would this setup stack up? Am I just better off sticking with two Mal-X drivers or is there an equal alternative that might not take up as much room? BTW, IB is not an option. I do like the idea of having a couple of subs placed in opposite corners of the room as I think it would help out with any room nodes and 2 subs are always better than 1.
Sound quality is very important, but I'm not even sure there would be that much of a difference between the Tempest and Mal-X besides just the displacement.
Old 10-19-09, 01:54 PM   #52
Exodus Audio
Alias: Kevin
Loc: Port Angeles, WA
User: #13393
Since: Nov 2007
  Kevin Haskins is offline
NateTTU wrote: View Post
I'm sorry... I don't always stay on top of the forum on the weekend. Drop me an email if you have a specific question. You can chase your tail around a long time trying to find the "optimal" setup. Give me a call and I'd be happy to walk through the trade-offs and give you some general advice. The forum isn't always the most efficient way of getting a good answer. ;-)
These A or B type of questions don't always have a simple answer. It depends on what you value.
Kevin Haskins
Exodus Audio
« Home Theater Shack > DIY Speakers and Subwoofers > Exodus Audio »
24'', ideas, mal-x, modification, sealed
