| Exodus Audio Project Affinity - Triple maelstrom-x BuildDiscuss Project Affinity - Triple maelstrom-x Build in the DIY Speakers and Subwoofers forum; Project Affinity - Triple maelstrom-x Build So the scope of the project has change and I will be building one Maelstrom-x and 2 more after this ... |
Views: 920 - Replies: 41
| Project Affinity --> Project epiphany So the scope of the project has change and I will be building one Maelstrom-x and 2 more after this one is done. So the new box design is going to go into the built in area where the TV is now. Should be good for total of 12.5 CU Ft of space. ![]() This the design. Port on the right side is a fake one, doing this for looks. Here are some pics of the process. I have so far got all the cuts I need to get the box going which begins tomorrow. I have a jig or two I will need to assemble as well for some of the bracing. Should be fun .![]() ![]() ![]() ![]() more sawdust, splinters, and pics to follow. Last edited by aduljr; 10-14-09 at 03:55 AM.. Reason: Scope of project changed | ||||
| | #2 | ||||
| Re: Project Affinity - Tiple maelstrom-x Build Nice design. What is the net volume of the cabinet? | ||||
| | #4 | |||||
| Re: Project Affinity - Tiple maelstrom-x Build Quote:
Kevin Haskins Exodus Audio | |||||
| | #5 | ||||
| Re: Project Affinity - Tiple maelstrom-x Build I wish I did. I will be cutting them all out myself and using a variety of tools and techniques. I should be picking up the wood I need today. 16 sheets of Baltic birch. | ||||
| | #7 | |||||
| | #8 | |||||
| | #9 | |||||
so when do we get to see the final stats on them ![]() I would to ![]() | |||||
| | #10 | ||||
| Re: Project Affinity - Tiple maelstrom-x Build :-O unload all of those palets there and bring them here. when youre done, take a 21" on your way out. thanks. | ||||
| | #11 | |||||
The container comes stuffed with boxes, no pallets. So the work is that you have to handle every box, palletize them, wrap them and find a place for them in the warehouse. I think it was a little over 12,000lbs of boxes so that is a lot of lifting, moving and wrapping. Kevin Haskins Exodus Audio | |||||
| | #12 | |||||
sounds like a good work out :P | |||||
| | #13 | ||||
| Re: Project Affinity - Triple maelstrom-x Build Subscribed. Looks like a challenging enclosure project. Make sure you post lots of pics along the way. | ||||
| | #14 | ||||
| Re: Project Affinity - Triple maelstrom-x Build I will, I have a habbit of making it more difficult for myself, but I got a couple of extra tools to make it easier this time around. | ||||
| | #16 | |||||
| | #17 | ||||
| Re: Project Affinity - Triple maelstrom-x Build Neo = less weight, higher cost. | ||||
| | #18 | ||||
| Re: Project Affinity - Triple maelstrom-x Build I assume the reason for using it in extremis and FR125Ss and the like were stray flux for TV friendliness? sorry to go OT | ||||
| | #19 | ||||
| Re: Project Affinity - Triple maelstrom-x Build I am thinking I can be over meticulous checking measurements so many times. I am going to be routing the inside walls to counter sink some of the bracing. I need to get make a brace to hold things in line to make sure its exactly the same tract all the way around. Fun times .![]() For now I must run off to attend a wedding. Maybe I will get some of it down when I return if not tomorrow for sure. | ||||
| | #20 | ||||
| Re: Project Affinity - Triple maelstrom-x Build I got a lot more pictures of the build in progress. I order to get the nice groves I needed, I decided to build a guide into my table saw. Nice and simple solution to make sure everything remains straight. The guide additions to my table saw are two extensions and an aluminum straight edge. ![]() ![]() ![]() So the front baffle has 2 rectangular ports in it. Instead of routing out or using a jig saw to cut the ports out I opted for plan c. As you can see from the stack of small pieces of wood I will assemble the port for a nice and perfect rectangle. ![]() ![]() With a stop put in place, I routed some more of my grooves to be used for the bracing. ![]() ![]() Time to route the inner back piece. ![]() Had to clamp my fence down since I was outside the track ![]() ![]() End result ![]() Now for the side pieces. This will be the vertical groove. But first, testing on some scrap piece of wood. ![]() 8 7/8" was my target. I think I nailed that one pretty close. ![]() ![]() yup, on target. ![]() ![]() Next on my list to do. I have the bottom of the box to time the edges off tomorrow. Angle cut the parts that are going to join up on the front part at a nice 22.5 so I can use my Pocket hole joiner. Start assembly of the innerbox. | ||||
| | #21 | ||||
| Re: Project Affinity - Triple maelstrom-x Build Nice work danny. When do you need me to stop by to drop off supplys? Any luck on finding someone to put a piano black finish on the box? Would you like to do it? Thanks a million Scott | ||||
| | #25 | ||||
| Re: Project Affinity - Triple maelstrom-x Build I been busy and I haven't upload photos I taken. after my quick trip to cali, I am working on the port for the sub, maybe the curve join is a bit of a pain, but should look good. | ||||
