| Exodus Audio Shiva-X build.....Discuss Shiva-X build..... in the DIY Speakers and Subwoofers forum; Shiva-X build..... Mike P. wrote:
That would be close. The displacement has already been taken into account in the sonosub pic I ... |
Views: 406 - Replies: 35
| | #26 | ||||
| Re: Shiva-X build..... Excellent. And would we be smart to get some foam padding or dampening material for the sides and around the port? Or is that a waste of time? | ||||
| | #27 | ||||
| Re: Shiva-X build..... Gone past the point of theoretical....now we have the build thread: http://www.hometheatershack.com/foru...ld-thread.html | ||||
| | #28 | |||||
| Re: Shiva-X build..... Quote:
Looks good.... you can use a little fill or egg-crate. I typically just use polyfill, 10-15% in these types of builds. (16oz. per cubic foot = 100% fill) A lot of people like to use the egg-crate foam because they can glue it to all the enclosure surfaces. Nothing wrong with either approach. Kevin Haskins Exodus Audio | |||||
| | #29 | |||||
| | #30 | ||||
| Re: Shiva-X build..... Yes, a lot of people use that. | ||||
| | #31 | |||||
| Re: Shiva-X build..... Quote: | |||||
| | #32 | ||||
| Re: Shiva-X build..... It's fine where it is for a 12 inch sub. You'll be impressed. | ||||
| | #33 | ||||
| Re: Shiva-X build..... Cool, thanks. As long as I'm not missing anything I could "potentially" have, then I am usually happy with the limitations of the build. Thanks Mike! | ||||
| | #34 | |||||
| | #35 | ||||
| Re: Shiva-X build..... I modeled it without the boost. | ||||
| Bookmarks |
| Tags |
| build....., shiva-x |
| Thread Tools | |
