Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > Exodus Audio
Exodus Audio
Questions on new Maelstrom-X 18" Build
Discuss Questions on new Maelstrom-X 18" Build in the DIY Speakers and Subwoofers forum; Questions on new Maelstrom-X 18" Build It took a little convincing of my wife - but I finally will get to upgrade my sub woofer. I ...
Views: 176 - Replies: 12
Old 11-02-09, 02:08 PM   #1
Alias: Fresh Meat
Loc: Eagle Mountain, UT
User: #28087
Since: Nov 2008
  Fresh Meat is offline
It took a little convincing of my wife - but I finally will get to upgrade my sub woofer. I will be ordering my Gen II Mal 18" very soon (by the end of this week) and would like to nail down all of the build details.
Sub Woofer Parts:
Driver - Maelstrom-X 18"
5 way binding post (parts-express part #260-309)
I prefer a sealed sub and was planning on utilizing one of Neo Dan's cut-sheets unless there is something new and improved that I should know about. http://www.hometheatershack.com/foru...m-x-build.html
Now to the questions.
1) I have several small children so I will need to figure out a way to add a speaker grill to help protect the driver.
2) I would like the finish to match my speakers - which are piano black - would this be difficult?
3) Please point out anything obvious that I have missed
I will be powering this beast with a Behringer EP2500 which I will be picking up for my birthday in Feb. So I should have plenty of time to build it right.
Old 11-02-09, 02:27 PM   #2
Exodus Audio
Alias: Kevin
Loc: Port Angeles, WA
User: #13393
Since: Nov 2007
  Kevin Haskins is offline
Re: Questions on new Maelstrom-X 18" Build
Fresh Meat wrote: View Post
Sub Woofer Parts:
1) You could always down-fire the driver. You need feet, about 3" tall but that might be easier than building a grill.
2) Good luck with that. Piano black finishes take a LOT of work. You spray, sand, spray, sand, spray, sand, spray, sand, spray, sand etc.. etc... I prefer veneer simply because it is easy and you don't have to breath paint fumes. Of course if you have a paint booth, or take it to an auto shop where they do paint work on a regular basis, they can do a pretty good job.
3) Nothing obvious. I'd budget for the ability to measure the room and equalize. Same advice I give everyone.
Kevin Haskins
Exodus Audio
Old 11-02-09, 02:40 PM   #3
Alias: Raven
Loc: Bolingbrook, IL
User: #24916
Since: Aug 2008
  Lonely Raven is offline
The other option to piano black *paint* is piano black laminate.
A sheet of high quality piano black laminate goes for about $150, and can typically be shipped directly to your door (it comes rolled up). You'll need quality contact cement, roller to apply the cement, and a hard rubber roller to roll out any air bubbles. Then you'll need a laminate trimmer bit for your router, or a mini-router that's made for laminate trimming.
Once your done, you'll have a solid, scratch resistant piano black finish, but you'll have black plastic looking corners (from trimming the laminate with the router). I've done this a few times over the years, and it's always floored everyone how nice it looked.
Old 11-02-09, 02:40 PM   #4
Alias: Fresh Meat
User: #28087
Since: Nov 2008
Kevin Haskins wrote: View Post
Kevin Haskins
Exodus Audio
Thanks!
1) If I down-fire the driver, do I need to be concerned about speaker sag, given the size and mass of this driver?
2) I have not had great luck in getting veneer to adheir - but then it is possible that I am not prepping the surface properly. Or possibly it is my kids peeling it back
3) Will do - I will cross that bridge when I get there.
Old 11-02-09, 02:43 PM   #5
Alias: Fresh Meat
User: #28087
Since: Nov 2008
Lonely Raven wrote: View Post
I will look into this - can you provide me a link to your laminate source that you have used in the past?
Old 11-02-09, 02:49 PM   #6
Alias: Raven
User: #24916
Since: Aug 2008
It's been 10+ years since I've done this, and most of the companies I've used probably don't exist anymore (especially after this economic down-turn).
I would check with your local Home Depot or Lowes, and see if they can order some Piano Black laminate. If you do it right, your kids would be hard pressed to peed it up. I had a piano black 1cu box rattling around the hatch area of a SAAB Turbo for a few years, and the laminate (and MDF underneath) cracked long before it would ever peel up.
If you're patient, and have the funds, laminate is the way to go. Painting is a whole 'nother art/skill, and unless you have someone that knows how to do it, it's not something you want to jump into as fresh meat.
Old 11-02-09, 02:52 PM   #7
Alias: Fresh Meat
User: #28087
Since: Nov 2008
Hehe - thanks for the advise - I will start asking around then
Old 11-02-09, 02:54 PM   #8
Alias: Raven
User: #24916
Since: Aug 2008
Very few people have done piano black laminate here. If you build it, show photos and expect a LOT of people asking how you did it. If i wasn't so broke, I'd be doing it myself...cause I like the fame.
Old 11-02-09, 06:11 PM   #9
Alias: Fresh Meat
User: #28087
Since: Nov 2008
I just thought of a couple more questions - what hardware do you recommend for mounting the speaker? Is there any need for a gasket?
Old 11-04-09, 02:13 PM   #10
Alias: Fresh Meat
User: #28087
Since: Nov 2008
Well I have jumped in... I just placed the order for my Maelstrom-X 18"
Old 11-04-09, 02:44 PM   #11
Alias: Raven
User: #24916
Since: Aug 2008
Cool! Post a build log!!
I just ordered my 21" and picked up some plywood last night. So I'm right there with ya!
Old 11-04-09, 02:49 PM   #12
Alias: Fresh Meat
User: #28087
Since: Nov 2008
Yeah - my wife doesn't understand why I am so excited - but she is very understanding Maybe she will get it once I fire it up
Old 11-04-09, 02:51 PM   #13
Alias: Mike
User: #8033
Since: Apr 2007
  Mike P. is online now
You won't regret it! Post lots of build pics when you get started.
We're all in this together!
Members DIY Subwoofer Database
« Home Theater Shack > DIY Speakers and Subwoofers > Exodus Audio »
18", build, maelstrom-x, questions
