| Exodus Audio DPL-10" Closeout Discuss DPL-10" Closeout in the DIY Speakers and Subwoofers forum; DPL-10" Closeout I have a half pallet of these left. Once again, an item that just doesn't move in high enough quantity ... |
Views: 548 - Replies: 7
| DPL-10" Closeout I have a half pallet of these left. Once again, an item that just doesn't move in high enough quantity to continue stocking. Limited Quantities $45 each http://www.diycable.com/main/product_info.php?cPath=24&products_id=674 Kevin Haskins Exodus Audio | ||||
| | #2 | ||||
| Re: DPL-10" Closeout Awww, I want to buy one and put it in the rear deck of my car. Unfortunately you can't fit one there without ditching the torsion bars that pop the trunk open Such a bummer. | ||||
| | #3 | ||||
| Re: DPL-10" Closeout For a car, you can put them in 1-2 cubic foot boxes with 100% fill and they will work great. You get a hump in the response, which is undesirable for home audio but the cabin gain of a vehicle and your typical 80Hz LP actually works just fine for these in sealed boxes for automotive use. Kevin Haskins Exodus Audio | ||||
| | #6 | ||||
| Re: DPL-10" Closeout I would like to see this as well. | ||||
| | #7 | ||||
| Re: DPL-10" Closeout Ahh....sorry.... I don't have any. Let me change that. These are a close-out item. I'll put up some response graphs of what I consider gives usable designs for car audio. The diople/open-baffle stuff is way more work than I have time to document. By the time I finished, I'd be sold out of product and these are not getting replaced in inventory so get them while they are hot. Kevin Haskins Exodus Audio | ||||
