Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > Fi Audio
Fi Audio
Q18 Dual Sono Build
Discuss Q18 Dual Sono Build in the DIY Speakers and Subwoofers forum; Q18 Dual Sono Build Dual Q18's in 700l Sonotubes tuned to 12.8Hz 30" Sonotubes cut to 67" and 8.4" ports cut to 31.25". Well, ...
Fi Audio
Views: 1293 - Replies: 12
Old 03-27-08, 08:48 PM   #1
Alias: Bill
Loc: Missouri
User: #15949
Since: Jan 2008
  Bill 3 is offline
Q18 Dual Sono Build
Well, it all started innocently enough. I found that moving my living room HT stuff to a more dedicated basement HT enviroment lost a lot of bass. Research brought me here. I enjoy doing DIY and find the results rewarding (usually). The LLT write-up caught my attention (D@mn you Steve Callas ). So, I decided I had space to go big and started researching drivers. End result was that I decided that the FiCarAudio Q18 would give me the most bang for the buck for what my requirements/limitations were. AND well, since I could only aquire a 12' section of sonotube, why not build two???
Let me stop here and thank Mattlock for being the one who I gained real world experience from. Also, many thanks for all of you who have posted in my noobie questions threads.
My thought that the cost of adding a second wouldn't be all that much in materials, well, it all adds up - especially with 30" tubes.
Some starting pics
Be back with more soon.
Bill
Old 03-28-08, 07:19 PM   #2
Alias: The Dave
Avus_M3's Avatar
Loc: Nor^Cal
User: #13004
Since: Nov 2007
  Avus_M3 is offline
Re: Q18 Dual Sono Build
It does start to add up! Good luck on the build!
- The Dave
Check out my QUAD 18" Fi IB Build Thread (DONE) King of the 400lb Gorilla
Old 03-29-08, 03:04 PM   #3
Alias: Bill
Loc: Missouri
User: #15949
Since: Jan 2008
  Bill 3 is offline
Endless cutting of circles with the router.
Old 03-29-08, 03:10 PM   #4
Alias: Bill
Loc: Missouri
User: #15949
Since: Jan 2008
  Bill 3 is offline
Gluing of endcaps
Port hole ready for port
After gluing in the port tubes and a rounderover, I am in the priming mode.
Old 03-29-08, 03:14 PM   #5
Alias: Bill
Loc: Missouri
User: #15949
Since: Jan 2008
  Bill 3 is offline
Subs in and ready for tube. Had a hard time deciding on final volume and tuning. I decided to stay big as I can always cut shorter.
Old 03-29-08, 03:29 PM   #6
Alias: thxgoon
thxgoon's Avatar
User: #6924
  thxgoon is offline
Awesome! That picture of the tube in the back of your truck is great. Can't wait to hear your impressions
Old 03-29-08, 03:40 PM   #7
Alias: Bill
Loc: Missouri
User: #15949
Since: Jan 2008
  Bill 3 is offline
I didn't get pics of the final cutting of the tubes or my "doughnuts" I made for the internal port end flare. Only 3/4" roundover inside and out, but I figure better than nothing. I finally got the subs in place and as you can see, I am in the process of playing with the BFD and I desperately need to get my component/storage cabinet made that will go under the screen and between my two main speakers and hold my center.
By the way, I am still playing/tweaking.
Old 03-29-08, 03:56 PM   #8
Alias: Bill
Loc: Missouri
User: #15949
Since: Jan 2008
  Bill 3 is offline
thxgoon wrote: View Post
I can't say that I recall hearing or feeling bass like this anywhere, even in the theater (but I don't get out much). It just seems like it's effortless. Even in music where there isn't a lot of deep bass, it is just THERE, but not ovewhelming. I haven't watched much movie wise, but tried Master and Commander and it is definately OVERWHELMING, I mean just plain AWESOME
I am now FIGHTING with Audyssey and room responses. Listening positions and on and on. Concrete floors and some half and full concrete walls and framed walls. Need to bend some ears in the REW forum when I get a chance.
Old 03-29-08, 04:43 PM   #9
Alias: Maverick
Loc: Sandnes, Norway
User: #7168
Since: Mar 2007
  atledreier is online now
That looks so totally awesome! I have dual 15" 10.7cuft@13.3. I totally get what you mean by effortless. That's how I use to describe mine. Those tubes are HUGE! Over twice the size of mine!
Old 04-01-08, 08:35 AM   #10
Alias: Matt
User: #8834
Since: May 2007
  Mattlock is offline
Bill,
Looks great..now you've got me thinking about a 2nd tube also.... I cannot remember which amp you decided to go with.....If the EP2500...have you swapped out your fan to get things quieter?
Mattlock
Old 04-01-08, 10:09 AM   #11
Alias: Bill
Loc: Missouri
User: #15949
Since: Jan 2008
  Bill 3 is offline
Mattlock wrote: View Post
Bill,
Mattlock
Ya I did the fan mod in the EP2500. I wanted to make sure it worked before swapping in the quieter fan, and it only took one day. (I already had ordered and recieved the fan). With the placement of my equipment being in the front of the room and not in a closet or hidden away somewhere, I knew I would want to quiet it down. Big difference. Now if I can make some time to work on the cabinet to hide those lights and make my screen area less distracting. Looks terrible with that suff just laying around....
Old 04-02-08, 04:33 PM   #12
Alias: Shervin
ssabripo's Avatar
Loc: Florida
User: #3688
Since: Nov 2006
  ssabripo is offline
man this looks like deja vu!
well done!
Old 04-03-08, 07:49 AM   #13
Alias: Bill
Loc: Missouri
User: #15949
Since: Jan 2008
  Bill 3 is offline
ssabripo wrote: View Post
well done!
Thanks man! I read through your entire "Lord of Bass" thread along my way. Lots of great info and a little fun.
There seems to be a lot of Sonosub builds, but not very many Twin Sonosubs
« Home Theater Shack > DIY Speakers and Subwoofers > Fi Audio »
