Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > Fi Audio
Fi Audio
Need some advice. 2 fi q 18's
Discuss Need some advice. 2 fi q 18's in the DIY Speakers and Subwoofers forum; Need some advice. 2 fi q 18's A while back I bought a q18 with the intention of building a sonotube for it. Before getting the chance ...
Fi Audio
Views: 2137 - Replies: 34
Old 07-27-08, 08:37 PM   #1
Alias: vrmarkii
Loc: Northern Idaho
User: #18836
Since: Mar 2008
  vrmarkii is offline
A while back I bought a q18 with the intention of building a sonotube for it. Before getting the chance to build upgradeitus struck and I ordered another one. But I dont have room for 2 sonotubes of this size. So rather than build the sonotubes I decided to build a box in the front stage area under my screen. I'm limited to around 32 cubic feet or approximately 450 liters per driver. I'd like a little feed back or suggestions on where to go with this. Would I be better off just going with my original plan or go ahead and biuld the new box for 2 drivers?
Here is a screenshot of the 2 different subs in winisd the green plot is for a 700liter sonotube tuned to 13.6hz and the grey is the 32cubic foot dual sub enclosure also tuned to 13.6hz. I'll be using an ep2500 for an amp.
Thanks in advance, Ryan
Old 07-28-08, 08:47 PM   #2
Alias: mrogowski
Loc: Winnipeg
User: #2503
Since: Sep 2006
  mrogowski is offline
Re: Need some advice. 2 fi q 18's
Ryan, go with your second plan. Trust me, with two drivers and room gain, you would notice little difference between that and your original build.
Old 07-28-08, 09:30 PM   #3
Alias: Mike
User: #8033
Since: Apr 2007
  Mike P. is offline
I agree with Mark. If a box in the front stage area better suits your needs then go for it. Low end output will not be a problem!
We're all in this together!
Members DIY Subwoofer Database
Old 07-28-08, 11:54 PM   #4
Alias: Steve
SteveCallas's Avatar
User: #263
  SteveCallas is offline
If you go 450 liters per driver, I'm not so sure I would tune in the 13hz range. I'd take a look at something like 16hz. Not much point in more extension if it is rolled off. Should turn out pretty nice.
Old 07-29-08, 08:18 PM   #5
Alias: vrmarkii
Loc: Northern Idaho
User: #18836
Since: Mar 2008
  vrmarkii is offline
Thanks for the replies. This is my first HT sub build. I've built them years ago for cars but didnt really get into the details. So alot of this is pretty new to me.
Will it be possible to get a flat frequency response from 5-100hz with the box tuned to 16-17hz?
Is it possible to see what my room gain will be like before building?
I've modled a few more enclosures in WinISD. 4 900 liter enclosures tuned to 14-15-16 and 17hz and one 1400 liter enclosure tuned to 13.6hz. I may be able to squeeze 2 2'x3'x4' boxes into the front stage area. But will it be worth the extra space?
Both of the 18's are dual 2ohm drivers. Whats the best way to wire these? It looks like I'm stuck with either 2 or 8 ohms bridged. Or 4 ohms x2 unless I'm missing something. Any suggestions?
Thanks again
Old 07-31-08, 11:34 PM   #6
Alias: mrogowski
Loc: Winnipeg
User: #2503
Since: Sep 2006
Don't get too hung up on the curves a piece of software gives you. Remember, you are arguing over a hertz or two. The largest size edges just that much closer to infinite baffle, and on a personal note, that would be the pinnacle of low end. If you can do it, do it. If not, don't sweat it.
Regarding wiring, match the drivers to the safe output of your amp. If it is stable to 2 Ohms, do it.
Best,
Mark
Old 08-01-08, 12:28 AM   #7
Alias: vrmarkii
Loc: Northern Idaho
User: #18836
Since: Mar 2008
  vrmarkii is offline
Thanks Anything I do is going to be better than the 200 watt 10 I have now. I do believe I'm in for a shock My ep2500 came today, my other Q18 should be here monday, and I have a parts express order showing up tomarow. I still have to pick up some more mdf and the sonotube for the ports router bits etc. hopefully I'll get started this weekend. Pics to follow.
Old 08-01-08, 02:04 AM   #8
Alias: vrmarkii
Loc: Northern Idaho
User: #18836
Since: Mar 2008
  vrmarkii is offline
Thought I might get some feed back on my box design. Dimentions are 25.5 tall x 36 deep x 96 long. 4 internal braces with 2 8" x 30 5/8" ports placed on the sides 2 3/4" front baffles. Roughly 40ft^3 13.6 hz.
Old 08-02-08, 06:13 PM   #9
Alias: vrmarkii
Loc: Northern Idaho
User: #18836
Since: Mar 2008
  vrmarkii is offline
Here are a few more pics of my design after tweaking it alittle. If anything looks out of whack please let me know.
Old 08-02-08, 09:44 PM   #10
Alias: Mike
User: #8033
Since: Apr 2007
  Mike P. is offline
Looks good as far as I can tell.
Old 08-05-08, 12:35 AM   #11
Alias: vrmarkii
Loc: Northern Idaho
User: #18836
Since: Mar 2008
  vrmarkii is offline
Well went out to the garage this weekend to get to work and noticed something. The widest I can cut on my table saw is 26 1/2". And I dont trust the dude at home depot so I had to do some redesigning first.
Had to shrink the box down to 25 1/2" x 26 1/2" x 96" so I'm back to what I origianally planned. With dimentions I went back to the garrage and managed to get most of my cuts made.
I'll pick up some more mdf tomarrow and start glueing it together. Anybody have a source for a cheap 1"-1 1 /2" corner round bit?
Old 08-06-08, 02:47 PM   #12
Alias: thxgoon
thxgoon's Avatar
User: #6924
  thxgoon is offline
Looking good! With all of that sofware I thought you might CNC the thing
Old 08-06-08, 03:09 PM   #13
Alias: Mike
User: #8033
Since: Apr 2007
  Mike P. is offline
Nice looking bracing!
The cheapest I've seen is here:
http://www.routermania.com/product.c...7&cookietest=1
Old 08-06-08, 06:59 PM   #14
Alias: vrmarkii
Loc: Northern Idaho
User: #18836
Since: Mar 2008
  vrmarkii is offline
I would but the largest capacity machine we have at work is 20x40. Plus I think upper management might get ****** about the mdf dust in the coolant sumps.
Thanks not too bad for a jig saw and router. I started glueing stuff together but didnt get real far... Need more clamps. After I set up all the brace's in there I realized I went way overkill with the braces so the 2 port end supports arent going to be used. I'll snap a couple more pics tonight.
Old 08-06-08, 07:47 PM   #15
Alias: Mike
User: #8033
Since: Apr 2007
  Mike P. is offline
The plans don't look like overkill. We'll see when you post the pics.
Old 08-07-08, 02:39 AM   #16
Alias: Chris
Loc: Lincoln, NE, USA
User: #8712
Since: May 2007
  tenzip is offline
vrmarkii wrote: View Post
Mike P. wrote: View Post
I think I see what you're saying, the two port end supports don't really have any structural value, just hold the end of the port tube. I'm not sure how important that might be?
Maybe having them there to provide something to use as a flare would be worth keeping them.
Old 08-09-08, 03:25 PM   #17
Alias: vrmarkii
Loc: Northern Idaho
User: #18836
Since: Mar 2008
  vrmarkii is offline
What I ended up doing was moving the braces inward to eliminate the port support braces. I'm just going to use an mdf ring on either end to add more material for the port end radius. Progress has been slow to say the least. I only have 6 clamps and would rather just take my time then spend more money on harbour freight clamps. Besides UPS somehow managed to loose my other sub . So I got an extra week or so of time to kill.
All the internal braces should be glued in today and I should be able to get the front on tomarow. Has any one had problems with cutting part of the radius into the sono tube itself? I built this so I could flush trim the holes to the sonotube ports. And If I go with a 1 1/4" radius i'll be cutting 1/2" into the sonstube.
You can kinda see what I did here with the braces. I cant find the power cord for my cammera charger so no new pics for now.
Old 08-09-08, 04:06 PM   #18
Alias: Steve
User: #263
You definitely don't want to cut into the sonotube itself. Simply add more MDF rings to create some of the port length from just MDF.
Old 08-09-08, 04:36 PM   #19
Alias: vrmarkii
Loc: Northern Idaho
User: #18836
Since: Mar 2008
  vrmarkii is offline
Hmm what about going to a 3/4" Radius would that be large enough? This is what I had planned to do.
Old 08-09-08, 06:52 PM   #20
Alias: Collo
collo's Avatar
Loc: Newcastle, Australia
User: #5027
Since: Dec 2006
  collo is offline
Like Steve said, you can do your flare entirely from MDF....
Old 08-13-08, 01:52 AM   #21
Alias: vrmarkii
Loc: Northern Idaho
User: #18836
Since: Mar 2008
  vrmarkii is offline
Those are pretty nice looking collo . I took your guys advice and got off my **** and made a circle jig for my router. After making the first cut I've been kicking myself for ever touching the jigsaw. Ohwell It'll all be on the inside anyway.
So Quite a bit more progress since the last pictures. I'm just waiting on the 1 1/4" corner radius cutter. Once I get the radius on the inside of the port tubes I can put the top on, flush trim the edges, get the final front baffle on, and get it prepped.
Anyway here's the pics.
Old 08-13-08, 03:51 AM   #22
Alias: Mike
User: #8033
Since: Apr 2007
  Mike P. is offline
It looks well built. Definitely one of the biggest subs I've seen. I can imagine what it'll be like to move around!
Old 08-13-08, 04:27 AM   #23
Alias: Collo
collo's Avatar
User: #5027
Since: Dec 2006
  collo is offline
Nice job!
A bit of damping material on the faces that are furthest apart wouldn't hurt.
Old 08-13-08, 07:23 PM   #24
Alias: Steve
User: #263
Looks great
Yeah, I'd say so, just a little bit
Old 08-13-08, 07:39 PM   #25
Alias: vrmarkii
Loc: Northern Idaho
User: #18836
Since: Mar 2008
  vrmarkii is offline
Thanks guys.
Mike its not bad to move around now. But there is still a full sheet to be added. Deffinately have to have some help to get it in to place. But hopefully I wont have to move it for a long time.
Collo I was thinking about that. Would just using r13 work? The widest unsupported section is about 18.5" where the driver cutouts are.I might add another brace behind the driver so it bolts through 1.5" of mdf, and have a 3/4" front baffle with the drivers flush mounted. Right now my plan was to just bolt them through 3/4" of material and have them flush mounted in the front baffle. I really want this cabinet to be dead solid, no noises. But I dont want to sacrafice internal volume if I dont have to.
« Home Theater Shack > DIY Speakers and Subwoofers > Fi Audio »
18's, advice.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
