| Fi Audio Questions About 4 FI18 IB SetupDiscuss Questions About 4 FI18 IB Setup in the DIY Speakers and Subwoofers forum; Questions About 4 FI18 IB Setup I am currently building a home theater and have decided to do an IB with four of the Fi 18" ... |
Views: 1084 - Replies: 27
| Questions About 4 Fi 18" IB Setup I am currently building a home theater and have decided to do an IB with four of the Fi 18" IB subs. They will be in an array facing towards the seating below the screen. I have a false wall built for the screen, and was planning on building a faceplate that was mechanically isolated from the screen wall. The real walls behind are concrete 12" thick and 9' tall as the theater was built below the 3-car garage. I am contemplating using the EP2500 for the sub amp. My question is what would be the best way to run the subs. Should I wire two 2 ohm in series on each channel for a 4ohm load? Or two 4 ohm in parallel for a 2 ohm load? I am not familiar enough with the amps to know what they prefer and/or are capable of. Last edited by seattle_ice; 12-17-08 at 06:19 PM.. | ||||
| | #2 | ||||
| Re: Questions About 4 FI18 IB Setup I just checked the FI thread for their IBs and they say 500-600 watts for the 18s to hith excursion limits at 20Hz. You'd probably need to do the pair of 4 ohm drivers in parallel and put each channel of the amp into 2ohm load. | ||||
| | #3 | ||||
| Re: Questions About 4 FI18 IB Setup And then go easy on the gain knob... you will have serious power. Be sure to take some photo's and keep up posted on your progress. Sounds like it will be a very nice setup. ![]() | ||||
| | #4 | ||||
| Re: Questions About 4 FI18 IB Setup I would do 4-4 ohm drivers, wired series/parallel, and present the amp with a 4 ohm mono load. Each driver should get a little over 400 watts each (real world testing, not manufacturer's specs). | ||||
| | #5 | |||||
| Re: Questions About 4 FI18 IB Setup Quote:
Darryn | |||||
| | #6 | ||||
| Re: Questions About 4 FI18 IB Setup the amp can't do a mono bridged 2ohm. Your options are 4ohm mono brigdged or 2ohm stereo. If you go with the bridged, then you don't need to split the signal and feed it to two channels. If you go with stereo, then you have the option to EQ each channel differently since it is a possibility that the left and right subs may cause different peaks and nulls. I believe the total power output would be the same between the two options. | ||||
| | #7 | |||||
If i did stereo, would that mean I would need two EQ units (BFD type) or do they handle seperate channel EQ duties in one unit? | |||||
| | #8 | ||||
| Re: Questions About 4 FI18 IB Setup Yeah, if you want a single 4 ohm load, or a pair of 2 ohm loads, you get four 4 ohm drivers. The BFD will EQ two channels independently at the same time. -- Otto | ||||
| | #9 | ||||
| Re: Questions About 4 FI18 IB Setup Most do the (4)single 4 Ohm versions in a series/parallel combination for a single 4 Ohm load to run mono to the amp (bridged). Seems to be a solid match with 4 of the subs power wise. Thanks, Scott | ||||
| | #10 | ||||
| Re: Questions About 4 FI18 IB Setup Most do the (4)single 4 Ohm versions in a series/parallel combination for a single 4 Ohm load to run mono to the amp (bridged). Seems to be a solid match with 4 of the subs power wise. Scott - this is the same wiring that you recommended to me. Does anyone have a diagram of this? Thanks, Steve | ||||
| | #11 | ||||
| Re: Questions About 4 FI18 IB Setup | ||||
| | #12 | ||||
| Re: Questions About 4 FI18 IB Setup My four subs showed up this morning, so I went ahead and installed them. I wont have them hooked to a source for a couple weeks, but they look great. Front view: Back view: If the women don't find you handsome, they should at least find you handy - Red Green My Theater Build | ||||
| | #13 | ||||
| Re: Questions About 4 FI18 IB Setup They look intimidating, it's definitely going to be worth the wait! ![]() | ||||
| | #14 | ||||
| Re: Questions About 4 FI18 IB Setup Darryn, that's a very nice looking setup you have there. Is there a build thread for the theatre and your front speakers? They look familiar, and I want to say Nat P's, but I have a feeling they're not. What are you using for the screen? Can't wait to see how the IB turns out. | ||||
| | #15 | |||||
here. The front speakers are the in-wall versions of the NatalieP's. They are going to be behind my DIY screen using the new acoustically transparent material from SeymourAV. If the women don't find you handsome, they should at least find you handy - Red Green My Theater Build | |||||
| | #16 | ||||
| Re: Questions About 4 FI18 IB Setup Looks awesome . I'd put some heavy duty braces running front to back between each sub (so 3 total). That will help hold the quasi manifold/array more steady without restricting air flow. | ||||
| | #17 | ||||
| Re: Questions About 4 FI18 IB Setup Good idea, that was the plan. I was actually going to brace them all the way back to the concrete wall. If the women don't find you handsome, they should at least find you handy - Red Green My Theater Build | ||||
| | #18 | ||||
| Re: Questions About 4 FI18 IB Setup I have a two Avalanche 18" drivers that I've had in an IB but disassembled it due to moving. I am strongly considering selling the two Avalanche's and getting four IB3 18's instead. I love the Ave's, but the new HT is in an open loft (approximately 15k cubic feet), so I need more displacement. When up and running, please talk about your experience. I would appreciate you paying attention to driver excursion with sub 20Hz material. Since you went with four 4 Ohm drivers, you are at risk for bottoming them with loud effects below 20Hz (max excursion occurs at 20 Hz with your wattage when the amp is driven completely). Of course that is theory and often times drivers accept a lot more power than they should theoretically... especially since we rarely drive our amps to nearly clipping. I am contemplating going with four 2 Ohm drivers wired in series for a stereo 4 Ohm load... this gives about 325 watts per driver which means they would hit max excursion at about 9 Hz when the amp is fully driven. Max SPL (above 25Hz) would be decreased by about 4dB, but there would be no risk of bottoming the drivers with the really low stuff so common (yet hard to predict) in today's blockbuster movies. Basically, I'd give up a little max SPL for piece of mind. | ||||
| | #19 | |||||
I have never believed in having my systems amp-limited. Goes against my grain. I will let you know how it goes when I get to hooking them up. I just got the projector mounted on the ceiling today. ![]() If the women don't find you handsome, they should at least find you handy - Red Green My Theater Build | |||||
| | #20 | ||||
| Re: Questions About 4 FI18 IB Setup Ah, good to hear I wasn't losing my stuff after not visiting the Shack for a while. ...Just checked the link for your theatre, and wow. What an incredible project, starting from designing and building your own house. Looks like it's going to be a killer theatre, and I can't wait to see it finished. | ||||
| | #21 | |||||
First I ran some upright braces between each driver: Then I ran some 2" x 10"s from the back of the brace to the outside wall along the floor. These are nailed and glued with PL400 heavy duty construction adhesive. I then drilled a 1/2" hole 24" off the floor in 4 locations on the outside wall. After inserting anchor bolts, I used a coupler to attach some lenghs of 1/2" Allthread. The other end I used some angle pieces I had to fab up some connectors. I lagged those to the LVL beam that holds the wall over the subwoofers and connects to the top of the subwoofer baffle with (2) 3/8" x 2" lag screws each. The other end of the Allthread was then bolted to them and tensioned with a lot of force. When that step was finished, it looked a little like this: If the women don't find you handsome, they should at least find you handy - Red Green My Theater Build | |||||
| | #23 | ||||
| Re: Questions About 4 FI18 IB Setup Wow... sturdy! That's the kind of beefy overbuilding that I love. Kudos. | ||||
| | #24 | ||||
| Re: Questions About 4 FI18 IB Setup Then you will like it now - I added even more bracing in the form of 4" x 6"s next to the Allthread. So the Allthread is torqued down very tightly, squeezing against the 4" x 6", all of which is holding the lvl beam. I think it is solid. ![]() Here is the overall picture of behind the screen: If the women don't find you handsome, they should at least find you handy - Red Green My Theater Build | ||||
| | #25 | ||||
| Re: Questions About 4 FI18 IB Setup I'd have a slide show of your build process you can show on that PJ for those who are interested. That way people who are impressed with your subs will be doubley impressed . Most probably won't care but I'm sure some will. | ||||
