Scott,
Can you have a look at my graphs in the link below and give me your thoughts. I am not getting any tones from frequencies 10 and 20hz at all. I have purchased a BFD but don't have it yet. I am a bit concerned with what I am seeing. I haven't added the fiberfill but will do to see if it makes a difference.
I do have a couple of massive peaks which I can fix with the BFD but its the low stuff that I am not getting.
http://www.avforums.com/forums/diy-subwoofer-build/1080811-gperkins-diy-sub-build-27.html
cheers
Graham
