| Fi Audio Starting to build sonosub for my Ficaraudio Q15Discuss Starting to build sonosub for my Ficaraudio Q15 in the DIY Speakers and Subwoofers forum; Starting to build sonosub for my Ficaraudio Q15 Can you guys help be build the best sonosub for my Q15. Willd over at avsforum come up with these ... |
| | #1 (Link) | |||
| Starting to build sonosub for my Ficaraudio Q15 Can you guys help be build the best sonosub for my Q15. Willd over at avsforum come up with these # http://www.avsforum.com/avs-vb/showthread.php?t=728542 I just want the best form this sub. Not looking for SPL. Just the low bass that you can feel. Don't want it to bottom out. If you guys think these numbers are good....hopefully this weekend I can start on it. Here the T/S parameters. Re 2.8Ohms per coil (5.6 in series) Fs 22.9 Hz Qms 5.34 Qes .46 Qts .41 Mms 270 g Vas 164.1 l Sd 810cm^2 Bl 21.86 N/A Spl 88.2 1W/1m Thanks Soloxp | |||
| | #4 (Link) | |||
| Re: Starting to build sonosub for my Ficaraudio Q15 Thanks Exocer. I just wanted to be sure that this would be a good setup. Now I feel good. Hopefully in two weeks i'll have it done and post pic's. I only have time on the weekend to work on it. | |||
| | #6 (Link) | |||
| Re: Starting to build sonosub for my Ficaraudio Q15 What I did was to cut a long tube in half then make one about 200L and the other 400L and play them both in an A/B comparison, and then tweaked it until I got the sound I liked. You’d be surprised how much different the bass can sound in different sized enclosures and none of the WinISD modeling revealed this. If your really serious about any speaker project always make two or more prototypes and listen to them, I never build anything without several prototypes and it has served me well. My Sonosub project http://kingdaddy.linaeum.com/Sonosub/ | |||
| | #8 (Link) | |||
| Re: Starting to build sonosub for my Ficaraudio Q15 THANKS A LOT KINGDADDY!!! Just finished my 300L Sono.Took months. Mine looks like a 1940's war torn Jeep compared to your Hummer. Great job. Need more info on port as to sound changes. The best I do is an easy changeable port length, and sealed which is good for late night listening. Cannot wait to do some TrueRTA testing. Zene | |||
| | #9 (Link) | |||
| Re: Starting to build sonosub for my Ficaraudio Q15 Wow... that is one heck of a build. Absolutely amazed by the craftsmanship for both the sub and the MTMs. Zene... are you using an aeroport with yours? | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| ficaraudio | mcwhorter | Fi Audio | 15 | 10-09-06 12:52 AM |
| SIM2 Unveils Suite of 1080P DLP Projectors Starting at $9995 | Chris Boylan | Home Theater, Audio and Video News | 0 | 10-07-06 09:40 PM |
| How To Build Jon Rischs DIY Acoustic Panels | geekwithfamily | Home Theater, Audio and Video News | 0 | 09-22-06 12:41 PM |
| Tokyo Game Show and X06 footage on Xbox Live Marketplace starting tomorrow | HDBeat | HD Programming | 0 | 09-20-06 05:49 AM |
