Fi Q15s & Q18s... user opinions? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > Fi Audio
Fi Audio
Discuss Fi Q15s & Q18s... user opinions? in the DIY Speakers and Subwoofers forum; Fi Q15s & Q18s... user opinions? Hi all, The IB system is well into the planning stages, but now I'm deciding whether I should go with ...
Fi Audio
Old 06-15-07, 08:48 PM   #1 (Link)
Australian Contingent
Alias: John Simpson
Loc: Hobart, Tasmania
John Simpson's Avatar
User: #8852
Since: May 2007
John Simpson is offline
Hi all,
The IB system is well into the planning stages, but now I'm deciding whether I should go with 4-8 locally (Australian) drivers (Venoms), or splash out and buy a bunch of Fi Q15s or Q18s.
The excursion certainly outranks the Venoms (27mm vs 15mm), but as a mate pointed out, with enough drivers it doesn't matter that much.
I'm more interested in the *musicality* of the Qs. Are they accurate? Punchy? The IB will be used equally for home theatre and music.
Thanks!
Old 06-17-07, 04:59 PM   #2 (Link)
Alias: Steve
Loc: Shoreview Minnesota
User: #5693
Since: Jan 2007
ccdoggy is offline
Re: Fi Q15s & Q18s... user opinions?
My LLT is using a FI Q 15" dual 1Ohm. I really like this sub, performs excellent and just how i like it. I personally have only really had experience with really highend pre made subs (fathom, James) and then the crappy ones my friends have, and my LLT. I may not be the best judge but i really really like this sub, allot. excursion seems limitless and is definetly punchy once you get a few watts goin to it.
From what i hear and read about FI is that the Q is the most musical of their subs, but not as musical as say some of the TC sounds drivers. the Q has a bit of spl built into it making it waver a little from being totally musical but alas its exactly what i was lookin for.
Old 09-17-07, 09:10 AM   #3 (Link)
ebr
Alias: ebr
Loc: NC
User: #3405
Since: Oct 2006
ebr is offline
I never really auditioned any other drivers (except the ones in my SVS PB12+/2) but I am very happy with the Q18s I'm using.
-ebr
My Theater
Old 10-16-07, 08:03 AM   #4 (Link)
Alias: norpus
Loc: Melbourne
norpus's Avatar
User: #3037
Since: Oct 2006
norpus is offline
I think the Q18s look fine John
I'd use them over multiple venoms myself (about 4 to 1) and they don't need so much work to manifold either
Cheers
Norpus
Old 10-19-07, 07:34 PM   #5 (Link)
Alias: Andrew
User: #10399
Since: Jul 2007
photocrazy8 is offline
The q's are the most musical from Fi.
« Home Theater Shack > DIY Speakers and Subwoofers > Fi Audio »
Similar Threads
first user in TW with 2 SVSes!!! lienly SVSound 4 04-26-07 08:36 PM
first SVS user in TW lienly SVSound 9 04-17-07 08:56 AM
Opinions on the Carver TFM-42 Two Channel Amp 11B2P HiFi Audio Components 4 04-01-07 10:43 PM
Another new REW user bcrawfo2 REW Forum 18 07-29-06 02:15 PM
Mach 5 Audio
