| Fi Audio Fi Audio Q18 Giveaway!Discuss Fi Audio Q18 Giveaway! in the DIY Speakers and Subwoofers forum; Fi Audio Q18 Giveaway! Fi Audio and the Shack announce the Fi Audio Q18 Giveaway!
Want an opportunity to win one of two customized ... |
| | #1 (Link) | |||
| | Fi Audio Q18 Giveaway! Fi Audio and the Shack announce the Fi Audio Q18 Giveaway! Want an opportunity to win one of two customized Q18 drivers? ![]() The Q Series of subwoofers is Fi Audio's sound quality reference line. Featuring a hefty double stack motor structure with a heavily bumped t-yoke, the 27mm of Xmax allows for incredibly detailed, tight, and powerful bass. Dual progressive spiders keep the incredible linear excursion of this sub under control, while the extra heavy lead wire feeds the giant voice coil. Working well in several different applications, the Q18 is the new bottom octave benchmark. Q Series: 12”, 15”, and 18” Dual 1, 2, 4, or 8 Ohm Cast basket Wrap around gasket Kraft pulp fiber reinforced cone Single layer wide foam surround Push terminals Extra heavy lead wire FEA optimized motor 3” diameter 4 layer coil Double stack magnets Dual progressive spiders Q18 DUAL 1, 2, 4, or 8 Ohm Fs: 24.5 Hz | 23.8 Hz Re: 0.7 Ohms/coil | 1.4 Ohms/coil Qms: 5.66 | 5.73 Qes: .64 | .63 Qts: .58 | .57 Mms: 322g | 342g Cms: 0.13mm/N | 0.13mm/N Sd: 1210cm^2 | 1210cm^2 Vas: 268 l | 268 l Spl: 89.7dB 1W/1m | 89.4dB 1W/1m Bl: 10.4 N/A | 15.1 N/A Xmax: 27mm Rms: 1000W Sub OD: 18.500” Cut ID: 16.750” Mounting depth: 10.000” Displacement: 0.24cuft Price: $309.00 FREE! For two lucky winners! *shipping is included to U.S. and Canadian addresses only. These drivers will be customized to meet your install application! IB, Sealed or Ported... obviously within the physical limits of the motor and parts. This may delay shipment a few days, but you will have a driver to meet your needs. What will it take to be qualified for a chance to win one of these two drivers?
Shipping outside of the U.S. or Canada will be the responsibility of the winner. NOTE: Qualifying members must be registered by February 15, 2008 in order to qualify. Qualifications are subject to amendment with notice posted here. Questions and comments may be posted in this thread. Best of luck to all qualified entrants... ![]() | |||
| | #3 (Link) | |||
| Re: Fi Audio Q18 Giveaway! We can tweak them within the laws of physics and the strength of the motor quite a bit. IB, sealed, ported, Dual 1 or 2, single 2, 4, or 8 Ohm as well. So to whoever wins one of them, let me know what you are wanting to do with it and we can tweak things from there to try and get the most out of it for your application. Thanks to HTS and Sonnie for the support and the contest... Scott | |||
| | #5 (Link) | ||||
| Re: Fi Audio Q18 Giveaway! Quote:
![]() Neil If you're Canadian, please join us at SoundGround.ca! Audio Junkies - Editor | ||||
| | #6 (Link) | |||
| Re: Fi Audio Q18 Giveaway! Hmmm... not enough top plate height to really get the same Xmax from it. Need about a 1" TP to do it. Along the same lines as XBL, the coil wind height would greatly be reduced as would moving mass and inductance. But, as I find to a larger detriment in the car audio and higher power home world... a big loss in thermal power handling. But Im preaching to the choir as it is ![]() | |||
| | #7 (Link) | ||||
| Quote:
| | #16 (Link) | ||||
Tweak it again for IB just like my earlier two 18" drivers. ![]() Thanks. ![]() Neil | ||||
