| Fi Audio Q18 sealed with LT?Discuss Q18 sealed with LT? in the DIY Speakers and Subwoofers forum; Q18 sealed with LT? Alright, I'm still procrastinating on any kind of build, but I am also still very curious about going from a ... |
| | #1 (Link) | |||
| Q18 sealed with LT? Alright, I'm still procrastinating on any kind of build, but I am also still very curious about going from a ported 15" Tempest to a larger sealed Linkwitz Transform sub. So my question is this: How will the Q18 fare in this type of application? It should have plenty of power handling and excursion to deal with the juice needed, but do any of the experts have suggestions or comments? I don't have a specific size restriction, but I'd like to keep it no larger (smaller if possible) than my Tempest, which is about 210L (around 7.5 cu. ft.). I'd like it to play louder and lower, and I'm hoping that the sealed design will get rid of some of the boominess I have now. This will still be a mostly HT sub. We have to stated parameters below, but I don't think I've been able to find the Le of the driver, does anyone have that? Q18 Parameters Fs: 24.5 Hz | 23.8 Hz Re: 0.7 Ohms/coil | 1.4 Ohms/coil Qms: 5.66 | 5.73 Qes: .64 | .63 Qts: .58 | .57 Mms: 322g | 342g Cms: 0.13mm/N | 0.13mm/N Sd: 1210cm^2 | 1210cm^2 Vas: 268 l | 268 l Spl: 89.7dB 1W/1m | 89.4dB 1W/1m Bl: 10.4 N/A | 15.1 N/A Xmax: 27mm Rms: 1000W Sub OD: 18.500” Cut ID: 16.750” Mounting depth: 10.000” Displacement: 0.24cuft | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Fi Audio Q18 Giveaway Qualification Thread | Sonnie | Fi Audio | 22 | 05-05-08 08:10 PM |
| Fi Audio Q18 Giveaway! | Sonnie | Fi Audio | 19 | 03-27-08 08:03 AM |
| Install application for my Q18! | Sonnie | Fi Audio | 12 | 03-10-08 09:51 AM |
| 2 'Splinters sealed | Prozakk | SoundSplinter | 25 | 12-21-07 12:44 PM |
| Fi Audio Q18 Giveaway Announcement | Sonnie | Forum Announcements | News | 0 | 12-01-07 11:35 AM |
