| | #102 (Link) | ||||
| Re: The Dave's Fi IB Quad 18" Build Thread Quote:
blah blah. Well, that and soon we are mounting the plasma so we would have to move them anyways <---point I used to not mount them. I am sure having the rears hooked up would have been so much better but hey...I can watch it again!Can do! I moved it to the bottom of netflix waiting for the bluray version seeing how hd-dvd is and Michael Bay loves bluray but I guess that will probably be a bit. On that topic, someone yell at Peter Jackson to get off his butt and transfer LOTR's to bluray!!! Last edited by Avus_M3; 04-13-08 at 07:09 PM. | ||||
| | #103 (Link) | ||||
![]() Anyways, have fun! ![]() | ||||
| | #104 (Link) | ||||
| Re: The Dave's Fi IB Quad 18" Build Thread Dave, I posted this at your avsforum thread. ![]() Quote:
| | #105 (Link) | |||
| Re: The Dave's Fi IB Quad 18" Build Thread Trying to get the demo disc now. Well, I got the ladder out and ran some near field measurements as promised. I held the mic in the manifold. I tried not to have my body be in front of the manifold as much as possible. I ran 4 sweeps with the mic in between the top 2 subs, 4 in between the bottom 2, and 4 with the mic about 4" in front of the manifold centered for the most part. Top measurement ![]() Bottom measurement ![]() Front measurement ![]() Averaged measurement ![]() Last edited by Avus_M3; 04-14-08 at 12:45 PM. | |||
| | #106 (Link) | |||
| Re: The Dave's Fi IB Quad 18" Build Thread I heard some feedback from some (Thomas W) that the low end rise seems pretty weird and it's a measurement artifact. Well, I ran a loop back test WITH the mic cal loaded and all looks good to me? ![]() What do you guys think? | |||
| | #107 (Link) | |||
| Re: The Dave's Fi IB Quad 18" Build Thread Thanks Neil! I 100% agree with you about Blade II! I remember watching Blade I on VHS in a Pro Logic setup with big Cerwin Vega mains and thinking how incredible some of it sounded. The Dave, I thought you'd have a little more low end extension with that setup (not that I really know how to read too much into the graph). Don't get me wrong, it still looks great, and I'm sure it SOUNDS incredible, which is the most important thing. Then again, when I graphed my Tempest, I couldn't believe how early it rolled off on paper considering what I was hearing... I thought it was going to bring my house down at some points! ![]() | |||
| | #109 (Link) | |||
| Re: The Dave's Fi IB Quad 18" Build Thread Awwww man! What happened to this thread??? It died. Dave, I'm working up a design for a pair of the Fi IB 18" and I'm a little constrained on space. I'm trying to find out the dimensions of these bad boys. From your thread I see that you used a 16.75" hole for one boad and an 18.5" hole for the other. The dimension I really need is now long they are. Do you have something that came with them that gives the length of the motor? Of course if anybody else that has the info, I would much appreciate! | |||
| | #110 (Link) | |||
| Re: The Dave's Fi IB Quad 18" Build Thread I was actually about to update it in a little while ![]() I have installed attic insulation and upgraded my wires AND finally hooked up my surrounds!! So I am excited. Anyways, off the top of my head I believe it was 9.75" but I will measure them later and post it. | |||
| | #111 (Link) | |||
| Re: The Dave's Fi IB Quad 18" Build Thread Doh...forgot they were in my email. Here are the dimensions: The subs are 18.500" in OD, the cut ID is 16.750", the flange is approximately .8250" and the depth of the subs from the back mounting flange is 9.500". Hope that helps! Good luck with the build!! It really helps to measure everything in sketchup and TRIPLE check everything. I changed my design numerous times before I actually cut a single piece of wood. | |||
| | #112 (Link) | |||
| Re: The Dave's Fi IB Quad 18" Build Thread Dave: I'm thinking about doing a similar manifold, and I wonder if you wouldn't share your Sketchup file with me? I'm doing 4 x AE 15". I'm particularly interested in how/if you generated the cut sheets from the models, or what the relationship is there. You can IM me here, or on the cult's board - I have a build thread there. I can't IM here since I haven't posted enough. Thank you kindly! | |||
| | #113 (Link) | ||||
| | #114 (Link) | ||||
email is kjgarrison@hotmail.com | ||||
| | #115 (Link) | |||
| Re: The Dave's Fi IB Quad 18" Build Thread Dave, have you dialed everything in yet? Any new listening impressions, or tricks you've used to get it sounding how you want? I'm glad you got the surrounds hooked up! Has the attic insulation made much of a difference? | |||
| | #117 (Link) | |||||
Quote: ![]() I believe it is the correct file. I had made a few changed through the projects timeline. Let me know if there are any issues I can help with. | |||||
