Install application for my Q18! - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > Fi Audio
Fi Audio
Discuss Install application for my Q18! in the DIY Speakers and Subwoofers forum; Install application for my Q18! This thread is for the Fi Audio Q18 Giveaway entries only. Tell us in detail the install application in which ...
Fi Audio
Old 12-01-07, 11:28 AM   #1 (Link)
Loc: Lower Alabama
Tell us in detail the install application in which you will use your Q18.
Old 12-17-07, 07:56 AM   #2 (Link)
Alias: jokers10
Loc: Altus, OK
User: #3011
Since: Oct 2006
jokers10 is offline
Re: Install application for my Q18!
Since I am a car audio nut it would definatley have to go in my truck. I have been missing the sound form a big speaker for a long time. Ever since I went away from two 15s to save space I have been regretting it. I will probably build both a giant ported enclosure and a smaller sealed one, and see which reacts better to my interior.
Old 02-26-08, 01:21 PM   #3 (Link)
Alias: sepi6
Loc: Paimio, Finland
User: #11725
Since: Sep 2007
sepi6 is offline
Sure I'd make LLT-sonosub, I just have one extra 356 l tube lying on my garage floor...leftover from 90 l sealed with 15" training piece.
Old 02-26-08, 04:33 PM   #4 (Link)
Alias: Brian
Loc: Oklahoma City
User: #5872
Since: Jan 2007
bonehead848 is offline
Because I move often Im hoping for a lightly modded standard q18 for IB use. This would help out when it is an ib but still allow it to go ported if I move to a house that wont support an ib. This would be powered by my ep2500 that I got for $250 thanks to the shack!
Old 02-26-08, 04:45 PM   #5 (Link)
Alias: Derek
Loc: Virginia
User: #2958
Since: Oct 2006
derekbannatyne is offline
I'd modify the existing ~7 cubic feet enclosure (it's ported as of now with a 15 inch Dayton DVC), seal it off, and put the 18" in there. It only has a 250w amplifier in there right now so I may need to upgrade that! I'd then move the 15 to my car. I may also just put the 18" in my car but that would be a huge box for my 99 Passat!
Old 02-26-08, 09:59 PM   #6 (Link)
Fi Audio Mod
Alias: Fi Audio
Loc: Hades, NV
User: #10608
Since: Aug 2007
Fi Audio is offline
7 cuft with about 5 lbs of polyfill should work well. What amp is it? Wondering if it has a modifiable boost circuit... a little at 25 Hz would work well.
Thanks,
Scott
Old 02-27-08, 10:45 AM   #7 (Link)
Alias: Justin
User: #15025
Since: Jan 2008
justin.kerr is offline
If I could get mine modified to work well in a small sealed enclosure, around 5-6 cubes. I would use it, along with the other 31 drivers, in my new theater.
Power, maybe a Crest Audio cc4000, running stereo, 2 subs per channel, @2 ohms, should give an honest 750-800 watts per sub.
Old 02-27-08, 11:26 AM   #8 (Link)
Alias: Neil
User: #14216
Since: Dec 2007
v1rtu0s1ty is offline
Hi Sonnie,
I saw the giveaway thread last night. I would like to join. How do I know if I have met the requirements?
Anyways, I saw one requirement and that is to post our installation plan here on this thread.
So, about the install, I will add the FiCar driver giveaway to my existing FiCar subwoofer but on a separate manifold. Or I build a new wicked sub using this giveway FiCar 18" driver for my family room.
This is my plan. I photoshop it to duplicate it.
http://restricted.dyndns.org/ibsubwo...re_ib_plan.jpg
More pictures at
http://restricted.dyndns.org/ibsubwoofer
Then my latest pic which is last night at
http://img172.imageshack.us/img172/2...ulf4qk6rj2.jpg
So the manifold will be installed on a false wall. The false wall will be installed where you see the screen now.
Thanks.
Old 02-27-08, 04:18 PM   #9 (Link)
Alias: Josh
Loc: Louisville, KY
Ricci's Avatar
User: #9132
Since: May 2007
Ricci is offline
Not real sure what I would do with it if I won. Giant Bose Acoustimass rip off? Rubbermaid garbage can sub? Maybe plain Jane EBS?
I wonder if the weight of a big vented Q18 based sub would exceed the axle rating on a moped?
Old 02-27-08, 06:52 PM   #10 (Link)
Alias: Derek
Loc: Virginia
User: #2958
Since: Oct 2006
Fi Audio wrote: View Post
Thanks,
Scott
It's the Rythmik Audio 250w plate amp, unfortunately without any boost. Maybe one of those Behringer EQs would come in handy...
Old 03-03-08, 10:54 AM   #11 (Link)
Alias: Zip
Loc: Canada
MatrixDweller's Avatar
User: #10408
Since: Jul 2007
MatrixDweller is offline
I would either consider making a passive radiator type sub and would want to work with Fi to get a PR driver to match. It would be my first time building a sub, but I'm handy and have built many other things. It would be a very fun project.
Old 03-03-08, 09:59 PM   #12 (Link)
Alias: mrstampe
Loc: Pearland, TX
mrstampe's Avatar
User: #13368
Since: Nov 2007
mrstampe is offline
I like the idea of a space-saving PR model, too. I'd build this one for my brother's home theater.
Mark
Pearland, TX (Houston)
Old 03-10-08, 09:51 AM   #13 (Link)
Alias: OJ
Loc: Toronto, Ontario
Owen Bartley's Avatar
User: #3144
Since: Oct 2006
Owen Bartley is offline
Sealed and LT'ed. I'd have to work with the guys at Fi on the specifics, but I'm thinking fairly small, Justin's 5-6 cubes sounds good. A pro amp with 1,000 watts or better to give some headroom after the equalization, and a double thick, super strong box, stained and urethaned to a nice deep gloss. Front firing I think, unless there would be a significant sonic advantage to downfiring.
e: looking at the specs again, 4 - 5 cubes would be awesome if we could model it right.
« Home Theater Shack > DIY Speakers and Subwoofers > Fi Audio »
Similar Threads
Fi Audio Q18 Giveaway! Sonnie Fi Audio 19 03-27-08 08:03 AM
Sealed Box, Plate Amp, how to install? sherlocktk DIY Subwoofers - Sealed and Ported 8 06-15-07 12:49 PM
DIY car stereo install? basementjack DIY Subwoofers 5 01-26-07 10:36 PM
Live Application stevestudio REW Forum 6 01-25-07 09:24 AM
flush fit sub install bobgenie Home Audio Acoustics 7 07-29-06 11:55 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200
