Axiom Audio M100 Floorstanding Speaker Giveaway Winner Announcement - Page 6 - Home Theater Forum and Systems - HomeTheaterShack.com
post #51 of 56 Old 04-13-15, 08:40 AM
Blacklightning's Avatar
Re: Axiom Audio M100 Floorstanding Speaker Giveaway Winner Announcement
Can you describe the noise? Is this noise only when you turn the Crown up or is it all the time even with low level music like soft classical?
Blacklightning is offline
post #52 of 56 Old 04-13-15, 08:47 AM
Andre's Avatar
Andre
buzzing. noise is present when no music is playing (it may still be there when playing I just don't hear it, or at least I have not thought of turning the gains way up to see if I can hear it with music).
I have tried different RCA input cables, switching the sensitivity on the amp (it was two), moving the power plug from the powerbar to the wall none of those helped. My next step is to try and move the amp further way from the reciever since the manual said it should be at least 8 inches from the pre-amp because of its magnetic field
Andre is offline
post #53 of 56 Old 04-13-15, 12:46 PM
brwsaw's Avatar
No noise was indicated during the review...
Try running them from your receiver direct but watch the top end volume, they'll play cleaner than you'd think and likely won't sound "too loud" until they start to distort from lack of power.
brwsaw is offline
post #54 of 56 Old 04-13-15, 12:59 PM
tonyvdb's Avatar
Tony
Just so we are all on the same page here, Ive contacted Andre and suggested he try disconnecting any ethernet and cable from his system as well as try running a dedicated ground wire from the chassis of the amp to the ground screw on the plugin. If that does not help we are going to try a spare Samson amp that I have to see if that has the same issue as I know it works fine at my house.
Home theater:
Living room system:
tonyvdb is offline
post #55 of 56 Old 04-30-15, 11:49 PM
brwsaw's Avatar
tonyvdb wrote: View Post
Did it work itself out?
Time to play
brwsaw is offline
post #56 of 56 Old 05-01-15, 08:16 AM
Andre's Avatar
Andre
The noice is coming from the CATV Cable connection. I have ordered an RCA type ground loop isolator to install between the receiver and the amp. I am also in the process of purchaseing a Jesen Transformers CATV isolator, supposedly there is a distributor in Surry BC. I will report back once I have tested both
Andre is offline
announcement , audio , axiom , floorstanding , giveaway , m100 , speaker , winner
You may not post new threads
