| Forum Announcements | News Fi Audio Q18 Giveaway AnnouncementDiscuss Fi Audio Q18 Giveaway Announcement in the General Shack Area forum; Fi Audio Q18 Giveaway Announcement Fi Audio and the Shack announce the Fi Audio Q18 Giveaway!
Want an opportunity to win one of two customized ... |
Views: 2117 - Replies: 0
| Fi Audio Q18 Giveaway Announcement Fi Audio and the Shack announce the Fi Audio Q18 Giveaway! Want an opportunity to win one of two customized Q18 drivers? ![]() The Q Series of subwoofers is Fi Audio's sound quality reference line. Featuring a hefty double stack motor structure with a heavily bumped t-yoke, the 27mm of Xmax allows for incredibly detailed, tight, and powerful bass. Dual progressive spiders keep the incredible linear excursion of this sub under control, while the extra heavy lead wire feeds the giant voice coil. Working well in several different applications, the Q18 is the new bottom octave benchmark. Q Series: 12”, 15”, and 18” Dual 1 and Dual 2 Ohm Cast basket Wrap around gasket Kraft pulp fiber reinforced cone Single layer wide foam surround Push terminals Extra heavy lead wire FEA optimized motor 3” diameter 4 layer coil Double stack magnets Dual progressive spiders Q18 DUAL 1 | DUAL 2 Fs: 24.5 Hz | 23.8 Hz Re: 0.7 Ohms/coil | 1.4 Ohms/coil Qms: 5.66 | 5.73 Qes: .64 | .63 Qts: .58 | .57 Mms: 322g | 342g Cms: 0.13mm/N | 0.13mm/N Sd: 1210cm^2 | 1210cm^2 Vas: 268 l | 268 l Spl: 89.7dB 1W/1m | 89.4dB 1W/1m Bl: 10.4 N/A | 15.1 N/A Xmax: 27mm Rms: 1000W Sub OD: 18.500” Cut ID: 16.750” Mounting depth: 10.000” Displacement: 0.24cuft Price: $309.00 FREE! For two lucky winners! *shipping is included to U.S. and Canadian addresses only. These drivers will be customized to meet your install application! What will it take to be qualified for a chance to win one of these two drivers? See all the details in the Fi Audio Q18 Giveaway thread! Good luck! ![]() | ||||
