Custom LMS4000 - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Manufactured Speakers and Subwoofers > Funky Waves
Funky Waves
Custom LMS4000
Discuss Custom LMS4000 in the Manufactured Speakers and Subwoofers forum; Custom LMS4000 Here is a custom TC Sounds 10" LMS4000 subwoofer we built a while ago, we are selling it on clearance ...
Old 01-12-08, 11:25 AM   #1 (Link)
Alias: Funky Waves
User: #9943
Since: Jul 2007
funky_waves is online now
Custom LMS4000
Here is a custom TC Sounds 10" LMS4000 subwoofer we built a while ago, we are selling it on clearance as the customer has upgraded.
The enclosure is 35Lnet, and made from solid 6061-T6 7/8" Thick Aluminum plate. Bolted together, and clear lacquered. It weighs in at 130lbs
Nathan Funk
Funky Waves Audio
www.funkywaves.net
Old 01-12-08, 06:58 PM   #2 (Link)
Loc: Lower Alabama
Re: Custom LMS4000
Any response graphs?
Old 01-12-08, 08:21 PM   #3 (Link)
Alias: Funky Waves
User: #9943
Since: Jul 2007
Re: Custom LMS4000
Here is a a graph, green line, at listening position(11"away) before any eq, 1/3 octave smoothing, lowpass at 70hz, highpass at 10hz. In a 950 square foot room with 8-11 foot ceilings. And a nearfield graph, blue line, same settings.
Nathan Funk
Funky Waves Audio
www.funkywaves.net
Old 01-15-08, 11:09 AM   #4 (Link)
Alias: AC
Loc: WICHITA, KS
ACGREEN's Avatar
User: #6917
ACGREEN is offline
Re: Custom LMS4000
Do you see any advantages/disadvantages to building a sub with a metal enclosure as opposed to wood?
Old 01-15-08, 12:14 PM   #5 (Link)
Alias: Funky Waves
User: #9943
Since: Jul 2007
Re: Custom LMS4000
The advantages are, very very solid, strong and heavy, at full power you cannot feel any vibrations in the walls. Its weight also keeps it from moving around the room. And it looks really nice, but we can also do laminated thin aluminum over MDF, for the look without the weight.
The disadvantages are weight again, its hard to move and expensive to ship. Cost to build is higher than average but not any more than the FW10.3 in high gloss for example. For that size enclosure, much bigger and materials cost and weight rises fast.
Nathan Funk
Funky Waves Audio
www.funkywaves.net
Old 02-16-08, 04:32 PM   #6 (Link)
Alias: Funky Waves
User: #9943
Since: Jul 2007
Re: Custom LMS4000
Here are a couple graphs without any eq, highpass or lowpass. At LP and Nearfield
Nathan Funk
Funky Waves Audio
www.funkywaves.net
Old 04-14-08, 09:35 PM   #7 (Link)
Alias: Binger
Loc: Omaha
User: #18424
Since: Mar 2008
SQCherokee is offline
Re: Custom LMS4000
wow...that is cool.
« Home Theater Shack > Manufactured Speakers and Subwoofers > Funky Waves »
Similar Threads
Custom LMS5400 funky_waves Funky Waves 28 06-29-08 09:14 AM
Custom In Ear Monitors yourgrandma Computers | Games | HTPC | Digital Devices 2 12-01-07 11:59 AM
Next Level AV is now a Triad custom dealer Adz Home Audio Speakers 1 05-03-07 05:13 PM
custom build/design scott Home Theater Design and Construction 0 01-21-07 11:22 AM
TC-2000 custom modified? rhino2 DIY Subwoofers 10 12-03-06 12:06 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202
