Ground - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > General Discussion
General Discussion
Ground
Discuss Ground in the Home Theater | Audio and Video forum; Ground I realize this isn't a car audio forum, but I guess a bad ground can happen in the home too. ...
Old 03-14-08, 02:42 PM   #1 (Link)
Alias: Derek
Loc: Virginia
User: #2958
Since: Oct 2006
derekbannatyne is offline
Ground
I realize this isn't a car audio forum, but I guess a bad ground can happen in the home too. I recently installed a new head unit that seems to have a bad ground when using the internal amplifiers. To remedy this, I purchased a 4 channel amp, with 4 gauge wire for the battery and ground (it's grounded to the sheet metal in the trunk). When the car is off, I can hear a slight buzzing, the kind that someone probably wouldn't notice, but would drive you crazy just because you know it's there. My question is, if there's a bad ground, is it an all or nothing (meaning either the amp will or won't turn on) reaction, or can a bad ground cause a little buzzing?
Old 03-14-08, 03:14 PM   #2 (Link)
Alias: Wayne
Loc: Katy, Texas
Wayne A. Pflughaupt's Avatar
User: #8
Re: Ground
Moving this to the General Forum...
I guess you’d followed all the usual remedies, i.e., grounding all components at the same location? Even if you do that, sometimes the antenna connection can cause a ground loop. Try unplugging it. There are also ground loop isolators you can plug in-line with the RCA connections.
Old 03-14-08, 04:05 PM   #3 (Link)
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
tonyvdb is offline
Re: Ground
This buzzing you hear is caused by a bad alternator in the cars charging circuit. There are noise filters that you hook up the the Negative of the Head unit or amp that should get rid of it.
Home theater: Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2,
2-Mission 765 Mains, 4-762i's Rears, SVS PB13 Ultra, AR center PSC25,
2 Audio control C131 EQ's, Toshiba HD AX2 & Samsung BDP1400 DVD players, Sanyo Z2 projector
Two Channel system: Yamaha RX-V995, Mission 764i's & A/D/S MS3u sub
Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer,
LG DV7832NXC DVD player, Motorola HD-PVR,
Sony KP-53HS30 rear projection HDTV, turntable PS-T20
Nintendo Wii
Old 03-14-08, 06:07 PM   #4 (Link)
Loc: Lower Alabama
Sonnie is offline
Re: Ground
You say when the car is off you hear a slight buzzing? Generally noise would be when the car is running. If this is correct, it seems you are still getting power to the amps in some way or another... a short most likely. You will need to re-check your wiring. If it is when the car is on... make sure everything is grounded in the same location and make sure all the paint it scraped away and you are getting a good connection. Do the same thing for the ground wire from the battery to the car chassis... scrape the paint and try replacing it with a heavier gauge wire... minimum 4ga.
Old 03-14-08, 06:39 PM   #5 (Link)
Alias: Rodny
Loc: Millbrook AL
Rodny Alvarez's Avatar
User: #158
Rodny Alvarez is offline
Re: Ground
What you hearing is system noise, you probably have the gains on the amp to high, turn the gains down and see if the noise still there
What brand radio do you have??
« Home Theater Shack > Home Theater | Audio and Video > General Discussion »
Similar Threads
Hello from ground zero... GLP Welcome | Member Introduction 6 02-27-08 04:56 PM
DIY ground up 2 ch. preamp/xover?? drf HiFi Audio Components 1 01-08-08 08:35 AM
HD DVD Losing More Ground? SteveCallas High Definition | HD-DVD | Blu-ray 75 08-23-07 10:38 PM
BFD output hum -not ground loop associated bbgsdad BFD Forum 1 02-19-07 08:37 PM
Ground loop hum? jeffbridges BFD Forum 3 09-15-06 05:03 PM
Mach 5 Audio
