Go Back   Home Theater Shack > Home Theater | Audio and Video > General Discussion
Register
General Discussion
Simple Question
Discuss Simple Question in the Home Theater | Audio and Video forum; Simple Question Just a simple question is all. If you have HDMI can you use it just for video and then use ...
Old 03-16-08, 01:50 PM   #1 (Link)
New Member
Alias: chemical1
Loc: ontario, canada
User: #17123
Since: Feb 2008
chemical1 is offline
Simple Question
Just a simple question is all. If you have HDMI can you use it just for video and then use component cables for sound? I have an older receiver and don't really want to upgrade. For starters I am just going to use a Rogers HD box with hdmi cable and hopefully component sound. Also I plan on using an HDMI upconverting DVD player with HDMI but again component for sound.
Thanks
cHeM
Old 03-16-08, 03:09 PM   #2 (Link)
Alias: Randy
Loc: Minnesota, USA
User: #12896
Since: Oct 2007
yourgrandma is offline
Re: Simple Question
I'm not sure exactly what you mean by using component for sound. Component is for video. You could certainly bypass your receiver for video and run HDMI directly into the display, but you'd then want to use optical or digital coax for the audio.
Onkyo 805 | Denon DVD-1920 | Sony 400 disc | Definitive Technology ProTower 400s | ProCenter 100 and PCC2 | BP2x | ProMonitor 100s | Klipsch RSW-10 subwoofer| Otoma HD70 | Play Station 3 | Toshiba HD-A3
Old 03-16-08, 04:12 PM   #3 (Link)
Alias: superchad
Loc: ohio
User: #17760
Since: Mar 2008
superchad is offline
Re: Simple Question
Component Video cables wil work fine for Audio as they are sheilded but in time I would replace, in short............
Yes you can use Component cables 2 ways for audio, you can go L&R from the RCA jacks for analog or you can use just one into Coax digital input for Digital Audio (best bet). Seeing how you have 3 wires you can do both at same time, digital for movies and Analog for 2 channel cd playback or music from cable box for example.
I dont run audio via HDMI I use Coax Digital.
Old 03-16-08, 06:18 PM   #4 (Link)
Alias: Don aka hyghwayman
Loc: Miamisburg, Ohio
hyghwayman's Avatar
User: #15542
Since: Jan 2008
hyghwayman is offline
Re: Simple Question
superchad wrote: View Post
Great answer SC
Old 03-17-08, 08:51 AM   #5 (Link)
Alias: Mike
User: #18068
Since: Mar 2008
Mr. Mike is offline
Re: Simple Question
You can use a component cable, but the componet output is only video.
I route 4 HDMI sources through an outboard switcher and then directly to my projector. The switcher I use also switches digital audio (toslink) and so my pre-amp can remain on one input for all my video viewing. Makes my macros a lot easier to program.
I can change the pre-amp input to listen to lossless movie audio, when that is something I want to do. Usually, I don't bother.
So, the answer to your question is yes, you can use the cable...but not the component output (or input), which supports no audio signal.
Mike
Old 03-17-08, 09:35 AM   #6 (Link)
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
tonyvdb is offline
Re: Simple Question
chemical1 wrote: View Post
cHeM
Hi cHeM,
As everyone has said, (and I am sure you are just confused and you meant using the 5.1 analog audio outputs of the DVD player). Yes you can do this. You will probably need to tell the DVD player in the menu to do so but this will work fine. You would be better off using a digital send like the Coax or Optical but if your receiver does not have them for inputs then thats the best you can do.
Now if your receiver does not have the 5.1 external processor inputs then you have an issue as you wont be able to receive any of the Dolby Digital or DTS audio streams as it wont send these over the Stereo analog outputs of the DVD player.
Home theater: Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2, 2-Mission 765 Mains, 4-762i's Rears,
SVS PB13 Ultra, AR center PSC25, 2 Audio control C131 EQ's
Toshiba HD A2 & Samsung BDP1400 DVD players, Sanyo Z2 projector
Two Channel system: Yamaha RX-V995, Mission 764i towers, & A/D/S MS3u sub
Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer,
LG DV7832NXC DVD player, Motorola HD-PVR,
Sony KP-53HS30 rear projection HDTV, turntable PS-T20
Old 03-17-08, 10:06 AM   #7 (Link)
Alias: Zip
Loc: London, Ontario, Canada
MatrixDweller's Avatar
User: #10408
Since: Jul 2007
MatrixDweller is offline
Re: Simple Question
For a year I ran my HDMI cable to my TV from my Rogers cable box and used the optical output on the Rogers box to go to my A/V receiver.
Two things that you will notice are:
1) You'll need to turn off the volume on your TV, since HDMI carries both audio and video, when listening to audio through your A/V receiver.
2) Some Scientific Atlanta boxes are weird in that you have to specify "Dolby Digital" in the "Audio: Digital Out" settings to pass sound via optical. Otherwise it goes through the RCA R/L only. My 8300HD is that way.
If you don't have an optical input on your A/V receiver then you can run the RCA L/R to it instead (just ignore the 2nd point). I'd also say you're far over due for an upgrade if your A/V receiver doesn't have optical.
Old 03-17-08, 10:14 AM   #8 (Link)
New Member
Alias: chemical1
User: #17123
Since: Feb 2008
Re: Simple Question
Yes I see that I am due for an upgrade
Old 03-17-08, 12:05 PM   #9 (Link)
Alias: Zip
User: #10408
Since: Jul 2007
Re: Simple Question
Seeing that most receivers started including optical inputs in the late 90's...you are way overdue.
Old 03-17-08, 04:06 PM   #10 (Link)
Tech'y Shackster
Alias: Bob
Loc: Shueyville, Iowa
User: #25
bobgpsr is offline
Re: Simple Question
The 5.1 (or 7.1) analog outputs of a player that can decode a multichannel lossless format (DVD-A, TrueHD, SACD, multichannel linear PCM) would be a superior choice over using S/PDIF (coax or optical Toslink). That is if you really care about lossless audio over perceptual lossless (lossy legacy DD/AC-3 or dts codecs) and are willing to go through the effort of doing a correct LFE (subwoofer) audio calibration.
For just two channel stereo S/PDIF is just fine since it can do two channels of lossless linear PCM.
Old 03-17-08, 04:26 PM   #11 (Link)
Alias: Zip
User: #10408
Since: Jul 2007
Re: Simple Question
Do you think that his receiver would have 5.1 inputs if it doesn't even have optical???
Rogers cable boxes do not have 5.1 out. Only higher end DVD upconverting players have 5.1 outs as far as I know. I don't think that is an option here.
Old 03-17-08, 05:36 PM   #12 (Link)
Alias: superchad
Loc: ohio
User: #17760
Since: Mar 2008
Re: Simple Question
MatrixDweller wrote: View Post
I doubt it will have analog multi channel inputs as those are on more higher end models, Optical and Coax are standard in even the crap budget gear.
Old 03-17-08, 07:10 PM   #13 (Link)
Alias: Zip
User: #10408
Since: Jul 2007
Re: Simple Question
I assumed that it was either a stereo receiver or an AVR that predated Dolby Digital. If a receiver had multichannel inputs it would definitely have at least one optical and/or coaxial input.
Old 03-17-08, 11:09 PM   #14 (Link)
New Member
Alias: chemical1
User: #17123
Since: Feb 2008
Re: Simple Question
Ok so I know I need to upgrade. I was thinking of the Sony STR-DG520 because it has the HDMI built in, or would the strG510 be ok for now. I want one with HDMI pass through so I don't need a switch.
Thanks again all
Old 03-17-08, 11:50 PM   #15 (Link)
Alias: Zip
User: #10408
Since: Jul 2007
Re: Simple Question
hmmmm...yes...the WAF comes into play for all of us that have wives I think. Maybe waiting until your birthday...or Easter...will be best. Why can't the Easter Bunny leave receivers and plasma TVs hidden around the house.
Old 03-18-08, 11:44 AM   #16 (Link)
Tech'y Shackster
Alias: Bob
User: #25
bobgpsr is offline
Re: Simple Question
It looks like that low cost model does not pick off the audio on the HDMI. So no lossless audio connection to the AVR. Not even simple 5.1 multichannel linear PCM via HDMI to the AVR.
The next higher up Sony AVR models seem to pick off (input) the audio on HDMI.
Old 03-18-08, 12:13 PM   #17 (Link)
Alias: David
Loc: Fontana, CA
salvasol's Avatar
User: #3627
Since: Oct 2006
salvasol is offline
Re: Simple Question
Ok so I know I need to upgrade. I was thinking of the Sony STR-DG520 because it has the HDMI built in, or would the strG510 be ok for now. I want one with HDMI pass through so I don't need a switch.Thanks again all
Here is another option for you ... http://www.hometheatershack.com/elec..._Receiver.html
You can get it here at the forum
« Home Theater Shack > Home Theater | Audio and Video > General Discussion »
BB code is On, Smilies are On, [IMG] code is On, but HTML is not allowed!
Similar Threads
Simple DIY Screen Question rawlaw79 Projector Screens | DIY Screens 10 01-22-08 02:18 PM
Need opinions on reciever (might be a simple question) mr_sparkelo Home Theater Components 8 12-09-07 04:56 AM
Neutral Grays and Simple Off the Shelf Solutions wbassett Projector Screens | DIY Screens 125 12-01-07 12:35 PM
Simple Substrate Screens wbassett Projector Screens | DIY Screens 1 08-09-07 10:21 AM
Simple Admin Tip Phil M General Discussion 7 07-08-06 09:35 PM
Mach 5 Audio
Electronics Retailer   Home Theater HDMI Receivers   HD-DVD   Blu-ray
Parts Express: 10,000 Audio & Video Products
