Room adjustments for optimum audio - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > General Discussion
General Discussion
Discuss Room adjustments for optimum audio in the Home Theater | Audio and Video forum; Room adjustments for optimum audio Hi. I have a basic understanding of room acoustics (Reflection, absorbtion, standing waves etc) and am seeking a source for ...
Old 03-26-08, 12:18 PM   #1 (Link)
Alias: Zerock
Loc: Georgia
Zerock's Avatar
User: #18429
Since: Mar 2008
Zerock is offline
Hi.
I have a basic understanding of room acoustics (Reflection, absorbtion, standing waves etc) and am seeking a source for more information.
Our HT is a converted 20x24x8 garage.
Sony projector
Onkyo 5:1 processor/amp combo
Koss (I think) front speakers, JBL surround, Home made center speaker.
Two home made subs driven by an older Yamaha natural sound amp.
The cement floor is covered by a thick,dense carpet ontop of an oversize padding. A large sectional fabric couch and I've done some basic wall treatments (bookshelves etc).
Front speakers are placed half way up the wall L/R of the 10x6 screen, surrounds near the ceiling in the back, and I've used the older Radio Shack SPL to place the subs.
(I temporarily put the sub in the main listening position and roamed the SPL around the floor at sub height while playing a 100hz sine wave and noted the highest reading)
Standing waves are terrible, but not sure where to find information about what to do about it. Can anyone suggest a reference to basic DIY room treatment for someone with limited knowledge?
For example:
* I understand bass traps are used to eliminate low Hz energy, especially in room corners. Why eliminate the low Hz?
* I just learned here at Hometheatershack that a goal for Sub EQ is flat. I always just thought max output at lowest Hz was desirable.
Now I'm curious to know if a flat response is desirable for the entire system.
Anywhere I can get basic knowledge such as that?
Thanks in advance
-Steve
Old 03-27-08, 09:17 AM   #2 (Link)
Shack Podcaster
Alias: Marshall
Loc: Hudson Valley, NY 12569
eugovector's Avatar
User: #2411
Since: Sep 2006
eugovector is offline
Re: Room adjustments for optimum audio
http://www.realtraps.com/info.htm
Old 03-27-08, 04:01 PM   #3 (Link)
Alias: Zerock
Loc: Georgia
Zerock's Avatar
User: #18429
Since: Mar 2008
Zerock is offline
This is EXACTLY what I was looking for. Lots of info to digest.
Thank you very much.
-Steve
Old 03-27-08, 06:04 PM   #4 (Link)
Shack Podcaster
Alias: Marshall
eugovector's Avatar
User: #2411
Since: Sep 2006
You're welcome. Happy reading.
« Home Theater Shack > Home Theater | Audio and Video > General Discussion »
Similar Threads
RL-p15 in optimum enclosure Mongrel714 SoundSplinter 15 07-16-08 08:27 AM
Room-in-room and acoustics atledreier Home Theater Design and Construction 5 12-09-07 03:50 PM
Calculating Room Modes - Odd Shaped Room Bob in St. Louis Home Theater Design and Construction 25 02-20-07 12:15 PM
Mach 5 Audio
