| General Discussion How can I eliminate my stand in my set-up?Discuss How can I eliminate my stand in my set-up? in the Home Theater | Audio and Video forum; How can I eliminate my stand in my set-up? So I have finally ordered a wall mount for my Pioneer 11550 50".
I have been trying to figure out ... |
| | #1 (Link) | |||
| How can I eliminate my stand in my set-up? So I have finally ordered a wall mount for my Pioneer 11550 50". I have been trying to figure out how I can eliminate the stand entirely from my set-up, if possible. My system is small and consists of: Yamaha RX-V661 AVR(soon to be replaced by Yamaha 663) PS3 D* HR21-700 HD-DVR Pioneer 1150HD 3 - Onix Xl-s front stage So I was thinking of ordering three identical height(18"-24") stands for my front stage with the 1150 on the wall above. But I have always had my soundstage below my display or at best ~1/3 up my screen. And I hear alot about how placing the center ch. above the display "opens" up the sound, is that true? So what can I do with my three pieces of gear to eliminate the stand? | |||
| | #2 (Link) | |||
| Re: How can I eliminate my stand in my set-up? It is always best to keep the front speakers tweeters even with your ear at the listening position. Mounting a center channel above the display can cause some strange issues with sound panning across the front if it is not at the same level (or close to it) as your right and left channels. Home theater: Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2, 2-Mission 765 Mains, 4-762i's Rears, SVS PB13 Ultra, AR center PSC25, 2 Audio control C131 EQ's, Toshiba HD AX2 & Samsung BDP1400 DVD players, Sanyo Z2 projector Two Channel system: Yamaha RX-V995, Mission 764i's & A/D/S MS3u sub Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer, LG DV7832NXC DVD player, Motorola HD-PVR, Sony KP-53HS30 rear projection HDTV, turntable PS-T20 Nintendo Wii | |||
| | #4 (Link) | |||
| Re: How can I eliminate my stand in my set-up? I have my center channel about 18" off the floor but it has an angle built in so it fires directly at my listening position. All you need to do is put something under the front to give it the desired angle. I wouldn't put it too low but anything above 12" should be fine. Home theater: Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2, 2-Mission 765 Mains, 4-762i's Rears, SVS PB13 Ultra, AR center PSC25, 2 Audio control C131 EQ's, Toshiba HD AX2 & Samsung BDP1400 DVD players, Sanyo Z2 projector Two Channel system: Yamaha RX-V995, Mission 764i's & A/D/S MS3u sub Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer, LG DV7832NXC DVD player, Motorola HD-PVR, Sony KP-53HS30 rear projection HDTV, turntable PS-T20 Nintendo Wii | |||
| | #5 (Link) | |||
| Re: How can I eliminate my stand in my set-up? Sounds good. I am thinking of putting a rack in my closet near the display.(~8' away) I could open it when using the set-up and close it when I'm not. At least until I get an IR set-up. | |||
| | #6 (Link) | |||
| Re: How can I eliminate my stand in my set-up? Rubber Door stopper, or if you like to spend real money, Auralex mopads (or foam cut to shape). Listen to the Real HT Info Podcast at http://realht.info, or on iTunes. Also, listen right here on The Home Theater Shack. Just use the web applet on the front page. | |||
| | #8 (Link) | |||
| Re: How can I eliminate my stand in my set-up? I find myself really playing with angles to get the center blending well with the front sound stage. You may start with the door stoppers, moving them in and out to give you different angles, then measure, and make some foam instead (keeping in mind, the foam ma compress, reducing the angle). My 2 cents. Listen to the Real HT Info Podcast at http://realht.info, or on iTunes. Also, listen right here on The Home Theater Shack. Just use the web applet on the front page. | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| What does your user name stand for? | jvc | Chat Box | 27 | 03-10-08 11:24 PM |
| Will a BFD eliminate port resonance problems? | Leonardo | DIY Subwoofers - Sealed and Ported | 8 | 01-21-08 10:21 AM |
| X-Men: The Last Stand | Sonnie | Movies | TV Shows | Hollywood | 6 | 11-20-06 08:03 AM |
| Episode 17: United We Stand! | Roger | Movies | TV Shows | Hollywood | 0 | 09-22-06 01:10 PM |
| Mini Marquee: X-Men The Last Stand | Roger | Movies | TV Shows | Hollywood | 0 | 06-03-06 08:13 AM |
