Something has to give -- speaker or display height? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > General Discussion
General Discussion
Discuss Something has to give -- speaker or display height? in the Home Theater | Audio and Video forum; Something has to give -- speaker or display height? Being well aware of the ideal set-up consisting of all speakers' tweeters at the same height and at ear level, ...
Old 04-16-08, 12:33 PM   #1 (Link)
Alias: Matt
Loc: Allentown, PA
User: #11567
Since: Sep 2007
E-A-G-L-E-S is online now
Being well aware of the ideal set-up consisting of all speakers' tweeters at the same height and at ear level, I have an issue.
Displays centered at eye level are the ideal as well.(I'm wall mounting my plasma)
......so which one should I sacrifice?
Old 04-16-08, 12:47 PM   #2 (Link)
Alias: Wayne
Loc: Katy, Texas
Wayne A. Pflughaupt's Avatar
User: #8
Re: Something has to give -- speaker or display height?
Assuming you're referring to the center channel speaker, I'd defer to screen placement at or slightly above eye level (I think the standard is it should be centered at no more than 15 degrees above eye level). The speaker can be angled towards the seating area and you'll be fine; once you get engrossed in the program you won't even noticed that it's not ear level. IMO the "tweeters at ear level" thing refers more to the L/R for music listening.
Old 04-16-08, 01:06 PM   #3 (Link)
Alias: Matt
Loc: Allentown, PA
User: #11567
Since: Sep 2007
So does this sound like a good option?
Three identical height stands placing the speakers below the display and angle them upwards accordingly, with the plasma just above eye level tilted slightly forward and down.
I cannot/do not want to wall mount my front speakers, so I must use stands. So a center channel above the plasma is out of the question with a stand.
« Home Theater Shack > Home Theater | Audio and Video > General Discussion »
Similar Threads
Linacoustic Height? allredp Home Audio Acoustics 7 04-01-08 04:11 PM
Ok, I give raw23062 General Discussion 4 02-07-08 05:04 PM
Increasing the sense of height in a vertically challenged HT:) Tristanc1 Home Theater Design and Construction 7 12-15-07 10:55 PM
Now what? Please give comments angryht REW Forum 66 08-17-07 11:21 AM
What would an upgrade give me? PhilB35 SVSound 19 02-17-07 10:41 PM
Mach 5 Audio
