Changed set-up....o.k. to plug plasma straight into socket? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > System Setup and Connection
Discuss Changed set-up....o.k. to plug plasma straight into socket? in the Home Theater | Audio and Video forum; Changed set-up....o.k. to plug plasma straight into socket? I am moving all my gear to a rack in a closet for a clean look. So I will be ...
Old 04-18-08, 07:33 PM   #1 (Link)
Alias: Matt
Loc: Allentown, PA
User: #11567
Since: Sep 2007
E-A-G-L-E-S is offline
So I will be moving the power line conditioner I have used for over the past two years.
*Can/should I plug my 1150HD straight into a wall socket?
Old 04-18-08, 07:52 PM   #2 (Link)
Alias: superchad
Loc: ohio
User: #17760
Since: Mar 2008
superchad is offline
Re: Changed set-up....o.k. to plug plasma straight into socket?
You can and many do but if you run across a budget solution I would add one in time. Have you ever A/B tested your conditioner to confirm any benefit in picture quality?
Old 04-18-08, 07:59 PM   #3 (Link)
Alias: Matt
Loc: Allentown, PA
User: #11567
Since: Sep 2007
You know what, I haven't. I bought it along with my first HDTV over two years ago before I really knew anything at all and have used it since.
What would be a temporary good enough budget option for now?
Old 04-18-08, 08:22 PM   #4 (Link)
Alias: superchad
Loc: ohio
User: #17760
Since: Mar 2008
Older Panamax units work good and are cheap
Old 04-18-08, 08:25 PM   #5 (Link)
Shack Service Mod
Alias: Leonard Caillouet
Loc: Gainesville, FL, USA
lcaillo's Avatar
User: #328
lcaillo is online now
No need to do anything temporary. This is all the protection that you need.
http://www.newegg.com/Product/Produc...82E16812102407
"It is better to debate a question without settling it than to settle a question without debating it."
-Joseph Joubert
Raise the bar.
Old 04-19-08, 12:23 AM   #6 (Link)
Alias: superchad
Loc: ohio
User: #17760
Since: Mar 2008
That is a surge protector not a conditioner like poster was reffering to.
Old 04-19-08, 01:20 AM   #7 (Link)
Alias: Joe Tama
joetama's Avatar
User: #9288
Since: May 2007
joetama is offline
Do you NEED a conditioner? Maybe.
Would I plug it directly to the wall? NO.
But, a simple surge protector would suffice if you don't want to spend money on the conditioner.
Rotel/B&W/Arcam/Rega/Pioneer Elite
Old 04-19-08, 06:33 AM   #8 (Link)
Shack Service Mod
lcaillo's Avatar
User: #328
There is little need for a power conditioner unless you have a specific noise problem that cannot be solved with proper electrical system and signal system design and installation. Power conditioners will not improve the image on a PDP or other display in nearly all cases. I have experimented with measurements of line noise and filtering for years and have never been able to confirm any improvement due to line conditioners. I do not suggest that it is not possible but with hundreds of installations and hundreds more sets serviced, I have never been able to see nor measure such improvements.
Ground problems can create disturbances, but proper system design and installation almost always relieves these issues. Just the installation of a surge suppressor that protects all of the signal lines and ties all of the grounds together has often solved many problems. The point that most proponents miss is that the $20 product mentioned above does the same thing in this regard as the products that cost hundreds, so the improvements that they see could often have been accomplished with a fraction of the cost by properly gounding the system or even just by co-location of power to the same outlet.
-Joseph Joubert
Raise the bar.
Old 04-19-08, 10:42 AM   #9 (Link)
Alias: Matt
Loc: Allentown, PA
User: #11567
Since: Sep 2007
Thanks guys!
So, is that cheap surge protector the type I need, or should I look at something more?
I don't think I'll need the conditioner, but if I notice a negative change in PQ(not likely), I can move it to the plasma wall.
Old 04-19-08, 10:46 AM   #10 (Link)
Alias: Matt
Loc: Allentown, PA
User: #11567
Since: Sep 2007
Is this enough? Or look for something else?
http://www.tripplite.com/products/pr...m?productID=94
Old 04-20-08, 11:45 AM   #11 (Link)
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
tonyvdb is offline
I would go with this one It has a better design and is rated for 2200 joules. It also has isolated noise filters built in. I have 3 of them hooked up to my system.
Home theater: Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2,
2-Mission 765 Mains, 4-762i's Rears, SVS PB13 Ultra, AR center PSC25,
2 Audio control C131 EQ's, Toshiba HD AX2 & Samsung BDP1400 DVD players, Sanyo Z2 projector
Two Channel system: Yamaha RX-V995, Mission 764i's & A/D/S MS3u sub
Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer,
LG DV7832NXC DVD player, Motorola HD-PVR,
Sony KP-53HS30 rear projection HDTV, turntable PS-T20
Nintendo Wii
Old 04-20-08, 03:18 PM   #12 (Link)
Shack Service Mod
lcaillo's Avatar
User: #328
Neither has any signal line suppression. If you are using the set as a monitor this is not an issue. Tripplite makes fine equipment.
-Joseph Joubert
Raise the bar.
Old 04-20-08, 03:35 PM   #13 (Link)
Alias: David
Loc: Fontana, CA
salvasol's Avatar
User: #3627
Since: Oct 2006
salvasol is offline
I have one of this for all my equipment (except subs) http://www.tripplite.com/products/pr...productID=3071 ... What I like is that is a battery back up... so I have some time to turn the TV off in case of power failure.
I think the most important thing is to protect the equipment for power changes with a voltage regulator.
Old 04-20-08, 03:47 PM   #14 (Link)
Alias: Matt
Loc: Allentown, PA
User: #11567
Since: Sep 2007
Voltage regulator?
As for the surge protector, instead of the block by Tripplite reccomended by tonyvdb how about this for just a few dollars more?
http://www.amazon.com/exec/obidos/tg...07A9F&v=glance
Old 04-20-08, 06:12 PM   #15 (Link)
Shack Service Mod
lcaillo's Avatar
User: #328
salvasol wrote: View Post
If that is what you think is important, then this is fine. In my experience, this is not very important. Most modern video equipment uses very robust switching power supplies that do not pass noise and can regulate perfectly from under 100 vac to over 130vac. It is a common misconception that there is value in external voltage regulation. There is convenience in a UPS, perhaps, but most of these units trade quality of protection for these features. The unit ou link above has a relatively low joule rating and no specs for current for surges, nor specs for the signal line clamping.
In my opinion yhou could get better protection for under $50 but with no UPS or voltage regulation.
-Joseph Joubert
Raise the bar.
Old 04-20-08, 06:14 PM   #16 (Link)
Shack Service Mod
lcaillo's Avatar
User: #328
E-A-G-L-E-S wrote: View Post
Voltage regulator?
This looks like much better protection and is reasonably priced. I wish they would give more specs, however. One of the things I like about Panamax is that they give specs on just about everything.
-Joseph Joubert
Raise the bar.
Old 04-29-08, 07:52 PM   #17 (Link)
Alias: Zip
Loc: London, Ontario, Canada
MatrixDweller's Avatar
User: #10408
Since: Jul 2007
MatrixDweller is offline
That one's perfect. I was looking at Monsters a while back and they are 3 or more times the price. I need one for my projector and black is beautiful. There's only one plug going into that outlet so a 4 gang module is a waste. I never knew Tripplite made these...that's awesome!
Old 04-29-08, 09:00 PM   #18 (Link)
Alias: Matt
Loc: Allentown, PA
User: #11567
Since: Sep 2007
It is nice.
The Joules rating was a little too low for my 50" plasma and subwoofer so I went with the Tripp Lite Isobar 6 DBS.
« Home Theater Shack > Home Theater | Audio and Video > System Setup and Connection »
Similar Threads
Samsung HCL4715W - Convergence Lines not straight slkness77 Manufacturers Service and Support 3 03-06-08 08:15 AM
Curious have you changed reciever just for HDMI? enrique Home Theater Components 11 02-19-08 12:09 AM
Straight Wire lcaillo Manufacturer and Vendor Reference Information 0 05-04-07 08:30 PM
Changing receivers changed my sub phase - normal? lovingdvd REW Forum 2 02-27-07 06:32 PM
Plasma TV sales up 87%, Plasma detractor?s carry on undaunted Roger Home Theater, Audio and Video News 0 06-08-06 08:16 PM
Mach 5 Audio
