| General Discussion Digital Vs AnalogDiscuss Digital Vs Analog in the Home Theater | Audio and Video forum; Digital Vs Analog What are the pros and cons of analog and digital gear. I'll kick it off
Digital
Hard to use for ... |
| | #1 (Link) | |||
| Digital Vs Analog What are the pros and cons of analog and digital gear. I'll kick it off Digital Hard to use for beginners (sometimes) Accurate setting of parameters Non-drifting Easy to load up a completely different setting (as well as any other settings you have stored) Analog Easy to use Semi-accurate setting of parameters Components tend to drift as they get older Bad tolerences on some components (up to +-20% on some) | |||
| | #5 (Link) | |||
| Re: Digital Vs Analog I think it's the equipment stages the OP was referring to, not the storage format. The Nyquist theorem makes analog versus digital sampling irrelevant, assuming you believe in theorems. ![]() | |||
