Hookup setting for Sony STR DG 910 - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > System Setup and Connection
Discuss Hookup setting for Sony STR DG 910 in the Home Theater | Audio and Video forum; Hookup setting for Sony STR DG 910 Hello, I would appreciate if you could help me find the best connection setup for the following devices: TV Sony ...
Old 01-26-08, 10:50 AM   #1 (Link)
New Member
Alias: hasan
User: #16033
Since: Jan 2008
hasan is offline
Hello,
TV Sony Plasma SE P42 M1
Amplifier Sony STR DG 910
Liteon HD DVD recorder
Nokia Mediamaster Satellite receiver
I'm not sure how to connect them best together, any advice is much appreciated.
Attached is the picture of the back connections for all of the devices.
Old 01-26-08, 11:06 AM   #2 (Link)
Shack Moderator
Alias: Mark
Loc: Northern Utah
nova's Avatar
User: #278
nova is offline
Re: Hookup setting for Sony STR DG 910
I'd think your best bet, and easiest, would be a couple of DVI to HDMI adapters. Plug 'em into the Sony DG910. I'd also go with coax digital audio from the DVD and satellite to the DG910 and an optical cable from the receiver to the TV.
Mark
Old 01-26-08, 12:28 PM   #3 (Link)
New Member
Alias: hasan
User: #16033
Since: Jan 2008
hasan is offline
Thanks mark
are you sure about (couple of DVI to HDMI adapters) i have no DVI plug at all devices !
i can see where you are going with this (coax digital audio from the DVD and satellite to the DG910 )
finally what do you mean by this (optical cable from the receiver to the TV)
NOTE: i need to see all the output monitor for Sat , DVD and Rec. on one AV on the TV ( AV1 or AV2 or AV3 or AV4 ) and for sure still able to record from the Sat.
Old 01-26-08, 12:48 PM   #4 (Link)
Shack Moderator
Alias: Mark
Loc: Northern Utah
nova's Avatar
User: #278
nova is offline
Sorry, didn't look at that closely enough. Dunno anything about SCART (other than they look similar to DVI at a quick glance).
Is there such a thing as SCART to HDMI adapters? Hopefully someone more familiar with your equipment will be along soon to help you out.
Optical to TV would really only matter if you wanted to watch TV and use the TV speakers.
Mark
Old 01-26-08, 01:04 PM   #5 (Link)
Alias: mech
Loc: Empire Township, MN
mechman's Avatar
User: #6446
mechman is online now
Component out and optical audio out from Nokia to the Sony Amp. Sony Amp component out to TV component in. Do the HD recorder the same.
mech
mech
Got questions? Start a thread.
Old 01-26-08, 01:46 PM   #6 (Link)
New Member
Alias: hasan
User: #16033
Since: Jan 2008
hasan is offline
Thank you for replies
(SCART) = I AM NOT SURE BUT ITHINK ITS EUROPEAN PLUG ( I don’t think there is adapter from scart to HDMI)
Well , let me add some more info to clarify things more.
First I don’t need the Tuner because I don’t watch ground channels, so don’t worry about the RF cables,
My real problem is the Sony Amp.
My current setup is:
From Nokia Sat Scart out to the DVD scart in – then from DVD scart out to the AV3 in Sony TV
This allows me to see the Sat channels and record them , and watch any DVD movies
All this on AV3 without shifting from one AV# to another + I can monitor (setup) all
Now I need to do the same thing while connecting the sony Amp as well.
So what I need is the final output (monitor ) to be on one screen for all of them without shifting between the AV’s on the TV
If the picture of my current configuration could help I can upload it for you
Many thanks in advance
Old 01-26-08, 05:16 PM   #7 (Link)
New Member
Alias: hasan
User: #16033
Since: Jan 2008
hasan is offline
is this will work ?
Old 06-23-08, 12:53 PM   #8 (Link)
New Member
Alias: jrb1979
Loc: Missouri
User: #22314
Since: Jun 2008
brickbrack4 is offline
Question Re: Hookup setting for Sony STR DG 910
I have a sony STR-DG 910 receiver and I am having some problems adjusting me front speakers. I am getting way to much sounds out of my Fonts and not near enough out of my rear speakers. I have the rear turned up to +10 but it will not let me adjust the levels on my fronts. Could you possible help me with this?
« Home Theater Shack > Home Theater | Audio and Video > System Setup and Connection »
Similar Threads
RCA to 1/4 cables for hookup jr1414 BFD Forum 7 02-04-08 11:48 PM
Help! Recommendation for System hookup vgd1 Computers | Games | HTPC | Digital Devices 3 01-07-08 06:45 AM
Sony STR-DG510 5.1 receiver HDMI Richard W. Haines Home Theater Components 0 11-09-07 05:41 PM
Sony @ CEDIA - 1080p-enabled ES A/V receiver - STR-DA5200ES HDBeat Home Theater, Audio and Video News 0 09-13-06 11:10 PM
Review: Sony STR-DE597 Josuah Home Theater Components 2 06-01-06 12:49 AM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194
