Go Back   Home Theater Forum and Systems - HomeTheaterShack.com > Home Theater | Audio | Video > General Discussion
General Discussion
  Discuss Could AVR's cause any TV Display blackouts? in the Home Theater | Audio | Video forum; Could AVR's cause any TV Display blackouts? Anyone have 665 AVR issues with HDMI causing TV blackouts? I have uploaded the latest firmware patch for this TV ...
Views: 469 - Replies: 4
Old 06-16-09, 09:24 PM   #1
Alias: jimbo
Loc: Anaheim, Ca.
User: #29178
Since: Nov 2008
  bozobytes is offline
I have uploaded the latest firmware patch for this TV to help the issues of this problem, but it still does it.
First I thought I could be having issues with the Samsung 46A750 TV which the display shuts off from 5-10 seconds, but sound is still playing, then I thought it could be the Cable Box, Time-Warner came over today to tell me that the signal was good, but they are having software problems with the OCAP HD-DVR boxes, but that is not one of the issues.
Samsung wanted me to do some troubleshooting steps to make sure it's the TV, before they come over to fix.
The TW tech told me it (maybe) just a possibility that if the HDMI cable goes from TV into the AVR, and everything else goes into the AVR including the TIME WARNER Box,
Bluray Player, then there might be a problem with the AVR. Something to do with the chain of components.
I did not buy Monster Cables, I bought them from Monoprice, which I have heard good things about, but he said maybe I'm getting half the signal since Audio and Video make up the HDMI, and maybe I got some bad cables. I checked them and they are in tight.
SOOOooo, has anyone had problems with the TV display going completely black, out as a result of something wrong with the Yamaha RX-V665?
Thank you for any replies!
Old 06-16-09, 09:56 PM   #2
Alias: Mike
Mike P.'s Avatar
User: #8033
Since: Apr 2007
  Mike P. is offline
Re: Could AVR's cause any TV Display blackouts?
I have seen issues tracked down to a bad HDMI cable in the past. I suggest you swap out the HDMI cable first and take it from there.
Old 06-17-09, 07:00 AM   #3
Alias: Leonard Caillouet
lcaillo's Avatar
Loc: Gainesville, FL, USA
User: #328
  lcaillo is offline
Bypass the receiver and connect directly to the TV. This will allow you to determine if one component is bad, the TV is bad, or the problem is in the receiver.
Also, please keep the discussion of a problem in one thread in the future.
...the soulshine, it's better than sunshine. It's better than moonshine. It's sure better than rain.
Old 06-17-09, 08:59 AM   #4
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
Dropouts of the video can also be caused by a handshake (HDCP) issues. Receivers are hit and miss with this problem due to being another device in the loop. Going directly to the display may be the best choice.
Home theater:
Onkyo TXSR805, Samson Servo 300 amp
Mission 765 Mains, 4-762i's Surrounds, AR center PSC25, SVS PB13 Ultra & A/D/S MS3u sub
2 Audio control C131 EQ's, Toshiba XA2, Panasonic BD60, Pioneer LD
Sanyo Z4 pj, Viewsonic N3235w 32" HDTV
Two Channel system:
Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub
Yamaha KX-393 Tape deck, CDC 805 CD changer, Samsung BDP1400, Sony turntable PS-T20, Nintendo Wii
Sony KP-53HS30 HDTV, Motorola HD-PVR
My Webpage
Old 06-19-09, 08:10 AM   #5
Silver Supporter
Alias: Ray
cavchameleon's Avatar
Loc: Albuquerque, NM
User: #15210
Since: Jan 2008
  cavchameleon is offline
tonyvdb wrote: View Post
Yes, and also if the resolutions of everything in the chain do not match. Make sure that everything is setup (sources and AVR-if it's not just a pass-through of HDMI signal) to the resolution of the display.
Ray
Ray
Happy Listening!!! Listen with an open mind and heart!!!
« Home Theater Shack > Home Theater | Audio | Video > General Discussion »
avr's, blackouts?, display
Bookmark and Share
Dish Network
