Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > General Discussion
General Discussion
Ohms?
Discuss Ohms? in the Home Theater | Audio and Video forum; Ohms? What exactly does ohms mean? I looked it up in the glossary but couldn't make heads nor tails of it....
Views: 467 - Replies: 7
Old 08-27-09, 02:30 AM   #1
Alias: moviefanatic
User: #39214
Since: Jul 2009
  Moviefanatic is offline
Ohms?
Old 08-27-09, 02:34 AM   #2
Alias: Intelonetwo
Loc: Sacramento, Ca
User: #6751
  HionHiFi is offline
Re: Ohms?
Moviefanatic wrote: View Post
Moviefanatic,
Here is the definition from the Princeton wordnet website....
# S: (n) ohm (a unit of electrical resistance equal to the resistance between two points on a conductor when a potential difference of one volt between them produces a current of one ampere)
# S: (n) Ohm, Georg Simon Ohm (German physicist who formulated Ohm's law (1787-185
My2Cents
Old 08-27-09, 01:40 PM   #3
Alias: Greg
Loc: Denver, CO
User: #55
  GregBe is offline
Re: Ohms?
I am not sure if you are asking for this reason, but as the Ohm rating of a speaker gets lower, it is more difficult to drive. 8 Ohms are much easier for your receiver to drive than 4 Ohm speakers.
Old 08-29-09, 12:06 AM   #4
Alias: Steve
Loc: Shoreview Minnesota
User: #5693
Since: Jan 2007
  ccdoggy is offline
Re: Ohms?
GregBe wrote: View Post
Also worth noting is that you should never connect a speaker or a combination of speakers that presents a load that is too low for an amp/receiver. Doing so will cause too much stress on the amp/receiver. it may work just fine for a while but turn it up and the amp will die. So always be careful when combining loads to an amp.
Old 08-29-09, 11:40 PM   #5
Alias: moviefanatic
User: #39214
Since: Jul 2009
Re: Ohms?
Would you say then that if you were to hook up an 8 ohm subwoofer up to a receiver that has a mediocre subwoofer, you think that wouldn't work?
Old 08-30-09, 03:41 PM   #6
Alias: Greg
Loc: Denver, CO
User: #55
  GregBe is offline
Re: Ohms?
I am not sure what you are asking, but most subwoofers are powered. Which ones are you looking at? If it is self powered, the ohm rating or quality of the sub has no relation to the amps in the receiver at all. It only receives the signal from the receiver, and doesn't pull any power from the receiver.
Old 11-03-09, 07:48 PM   #7
Alias: moviefanatic
User: #39214
Since: Jul 2009
Re: Ohms?
I was saying, would it hurt the replacement subwoofer with 8 ohms if the one that came with the receiver was anything less than 8? Or, could it possibly ruin the receiver putting out that much electricity/energy?
Old 11-03-09, 08:13 PM   #8
Alias: David
salvasol's Avatar
Loc: Fontana, CA
User: #3627
Since: Oct 2006
  salvasol is offline
Re: Ohms?
... would it hurt the replacement subwoofer with 8 ohms if the one that came with the receiver was anything less than 8? Or, could it possibly ruin the receiver putting out that much electricity/energy?
Did you get an HTIB??? ....that's the only reason I can think that you will get a Sub with the receiver
Can you post the models???? (receiver and sub).
I think that if the receiver was powering a 4 or 6 ohm sub and now it will power a 8 ohm sub, his job will be easier (by the way, I'm not an expert ).
I suggest you to start a new thread on the DIY subwoofer section if you want to replace the sub driver with something different than the original driver
« Home Theater Shack > Home Theater | Audio and Video > General Discussion »
ohms?
