| General Discussion Negative or Positive?Discuss Negative or Positive? in the Home Theater | Audio and Video forum; Negative or Positive? I have a friend whose interested in film, he's been to college for it. But when discussing film with him, ... |
Views: 318 - Replies: 11
| Negative or Positive? I have a friend whose interested in film, he's been to college for it. But when discussing film with him, he says that everyone who says "negative" when referring to film is mistaken. He says it's called a positive. I told him that ever sense I've been an avid reader of horror magazines nearly every time a new DVD comes out they usually say that they've done their restoration using the original negative. He told me that it's called a positive. I didn't see either term in the glossary. I searched the word and found some stuff that I emailed him on. I wonder why he has never heard of negatives before I said something about it...? So, is he right, or what? I'm awfully confused about all of this. I'm not expert on film, so all the help I can get to add to our next conversation on these terms would be much appriciated. He's been wrong before regarding that he thought all subwoofers had holes in them, so who knows. We recently discovered - thanks in a big part from these boards - that there are ones that aren't ported. | ||||
| | #2 | ||||
| Re: Negative or Positive? As is the case in most questions, the correct answer is "it depends." As I understand it, generally, if the original negative is available and in good condition, it is used. However, many original negatives are not available, or are in poorer condition than positve prints. Positives are sometimes used themselves or are restored and used to make a new negative. Note that we have now begun moving vendors to the new pull down option at the top of the forum pages. You will find it between "Shack Shopping" and "Glossary". This will represent a great improvement in the vendor reference database, making it easier than ever to find what you are looking for. Contact me with any suggested entries, category recommendations, or additional information about the vendors that we have. If you are a vendor and want your company listed, there is an option to provide us with the information. | ||||
| | #3 | ||||
| Re: Negative or Positive? Icaillo, Your response is correct but I'll give more details: There are numerous types of 'restorations'. There is a restoration on film alone. There is a restoration where they used digital programs to correct problems and then out-put it back to film. Finally there is a restoration where elements were corrected only for the latest DVD or Blu-Ray release but no film element was out-putted for the future which means they will have to start from scratch if they do another transfer at a later date. I'll take them case by case. FILM RESTORATION/PRESERVATION: This is a photo chemical restoration. Current movies don't require it for the time being because they are photographed on 'low fade' color negative stock (aka Eastmancolor). Distributors make back up preservation elements which includes a color interpositive (fine grain fully color corrected positive) and black and white separations of each color to restore it 50-100 years from now when or if the original color negative fades. Films shot with color negatives made between the years 1952-1982 will require restoration because that film stock was unstable and faded. The extent of which depends on the original processing and storage. To restore a faded Eastmancolor negative means to make a new color corrected print and with any luck, the original color balance can be retained. Then they make a new low fade color interpositive (fine grain) for the future. Or, they can use the black and white color separations to make a new color internegative which will contain the correct balance but be two generations removed from the camera negative. In terms of making a video master from film elements... The best quality is to master a film directly from the original camera negative, color correcting it and reversing the image to a positive. However, that is quite expensive because of the shot by shot color correction necessary which takes up many studio hours. It took 14 hours to do this for my new feature. The second best quality is to master a film from a color interpositive which is a fully color corrected fine grain color print. Not good for projection in a theater but good for a video transfer. The advantage is you only have to adjust the overall contrast and saturation since the film is already color corrected on a shot to shot and scene to scene basis. The only problem is you add a little bit more grain since film is an analog format and each generation removed from the camera negative adds some grain to the image. Not objectionable in most cases but when you see a camera negative transfer like the Connery Bond films, you do notice the difference. Camera negatives are the actual generation of what was exposed in the camera. A color interpositive is a first generation print. Mastering a movie from a color interpositive is less expensive and can be done in a few hours. In Warner Brothers 'ultra-resolution' transfers used for films like "The Searchers", what they did was the transfer the black and white separations of each color to a separate tape and then add the color and recombine them. The reason they did this was because the separations were already first generation and if they made a color internegative from them (necessarily to make prints) and tried to tape that it would be third generation. Video transfer mastered in this manner from first generation black and white separations can look very good too but once again the best quality is still from the color negative if it still exists and if it's not faded beyond usage. Unfortunately, in the case of many fifties' Eastmancolor negatives that is the case so they must go from whatever elements still exist that have the color. Master a film from black and white separations and then recombining them is very expensive. Each reel has to be transferred separtately. Then they have to be combined and then they have to be color corrected. It could take weeks of studio time. VIDEO RESTORATION: Keeping the above elements in mind and with the same quality considerations...sometimes either the camera negative or the color interpositives or the black and white separations have damage on them. Scratches, tears, printed in dust and dirt, flickering and flashing from bad lab work and other problems. So after they tape one of the three elements (camera negative, color interpositive, black and white seps) they need to do a frame by frame correction to remove the most obvious defects. It's easy to paint out dust and dirt and very difficult to fix deep scratches or breaks but it can be done...at great expense. In extreme cases like "The Robe", there was no single film element that didn't have problems so Fox had to tape the camera negative, black and white separations and color interpositive then go through the entire film on a shot by shot basis and pick the best footage for the final video master. Astronomically expensive and could take months of studio lab time. For video masters there are different resolutions available. 2K was used initially but it really wasn't good enough. Today 4K is the standard although "The Wizard of Oz" was recently done at 8K. From the new corrected digital video master they can bump it down to Blu Ray and standard definition DVDs for consumer use. The smartest distributors with long range vision will also out-put a new 35mm color internegative from the digital master for the future so they don't have to start from scratch again later. Just re-master the restored new 35mm negative which will take very little studio time. Fox did output a new restored 35mm color internegative of "The Robe" so theatrical prints could be struck and of course they could re-master the film from the new negative years from now as required. For black and white movies, two basic elements are used. If the 35mm negative still exists then that is the best element to master from although they need to do a shot by shot contrast correction. For many if not most pre-1950 movies shot on the dangerous and volatile nitrate stock, what exists now is a safety fine grain print which is good but not as razor sharp or fine grain as the original black and white original negative. The same applies regarding printed in damage and wear. They might have to tape the fine grain master (first generation fine grain print) and do digital fixes for the dust, dirt, wear and scratches. Unfortunately, this isn't as common for black and white classics as it is for color films. While titles like "A Christmas Carol" have gone through a full digital clean up, most of the Abbott and Costello movies still have printed in minor dust and scratches in sections on the fine grain masters they used for the transfers. Perhaps Universal will fix them for Blu-Ray some day, especially their best movie, "Abbott and Costello Meet Frankenstein", which has more wear than the others because it was so popular and re-issued so often. Silent films pose a real problem. Only in very rare cases do the nitrate negatives exist (i.e. "Metropolis") and even when they do, they are very worn since they had no duplicate negative stock in that era and every release copy was struck from the original which damaged them. Harold Lloyd and Charlie Chaplin made fine grain master prints from their nitrate negatives although even there, a lot of damage was printed into the preservation elements. They did a full digital clean up on some select Chaplin movies like "City Lights". In most cases all that exists on an old silent film is a very worn and splicey original nitrate print. While it's possible to clean them up and make them look good (but not great because theatrical release prints are too dark for optimum video transfers), they rarely do because most are in the public domain and there would be no way to recoup the costs. In other cases all they have is a dupe negative made from the battered old print on safety film. These look really bad because making a negative from an old scratchy print made the new copy lose details and get too contrasty and dark. Here is a simpler list of what's best for video restorations: 1) Original camera negative in color or black and white. This also applies to three strip Technicolor films where they can tape each separate color (filmed in black and white) and superimpose them on the digital master. However, they will have to have a shot to shot correction which is expensive and takes up lots of studio hours. 2) A fine grain color interpositive or fine grain black and white master. Good results but one generation removed from the camera negative. The advantage is the image has been corrected and all they have to do is an overall contrast and brightness adjustment. No shot to shot correction is required and it doesn't take up too much time in the studio. 3) A color internegative or black and white duplicate negative used for theatrical prints. These elements are second generation which will increase grain and lose some resolution so they should not be used for video master unless the other elements are missing or too damaged to use. It won't take up much studio time because it's color corrected but the added grain might be objectionable. 4) A color or black and white release prints does not generate good video masters and should be avoided unless that's the only thing that exists on the movie. A theatrical release print is high contrast which works fine with a projector but is not good for video which requires low contrast materials that can be adjusted so they have the proper contrast and brightness for video. Too much detail is lost when videotaping theatrical prints. Moviefanatic, Not sure what your friend meant other than whatever you watch will always be a positive image whether it's on video or in a theater. However in the case of some DVDs, while the image is positive it was mastered directly from the camera negative. When they did the transfer they reversed the negative image to a positive. You can joke with him that sometimes a 'double negative' isn't bad grammer since that's what you watch when you see a 3-D film which has two separate images superimposed on screen. Last edited by Richard W. Haines; 10-03-09 at 08:23 AM.. | ||||
| | #4 | ||||
| Re: Negative or Positive? Thank you Richard, as always very good information. I learn a lot reading your posts. Home theater: Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2 Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
| | #5 | ||||
| Re: Negative or Positive? Tony, You're quite welcome. I enjoy sharing information with readers so they have a better understanding and appreciation for what they see in their home theaters. I can't wait until the Blu-Ray of "The Wizard of Oz" arrives which I pre-ordered on Amazon a month ago. It will be fascinating to watch was actually exposed in the three strip camera back in 1939. I'm sure we'll see more detail that was ever in the Technicolor prints. Apparently they removed up some artifacts like the wire that wagged Burt Lahr's tail too which some purists might object to but I'm in favor of. The most astounding thing is that the nitrate three strip negatives still exist and are in good shape. Technicolor obviously processed and stored the film better than other labs at the time. Warners/MGM out-putted new 35mm restored negatives from the 8K restoration too for the long run. They should be applauded for their efforts. I wish all distributors were as dilligent and understood the cultural and financial importance of restoring and preserving their libraries. | ||||
| | #6 | |||||
| Re: Negative or Positive? Quote:
Home theater: Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2 Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | |||||
| | #7 | ||||
| Re: Negative or Positive? You should be getting it soon, Richard. There has been discussion about it on the opendtv listserve, so some seem to have received it. Note that we have now begun moving vendors to the new pull down option at the top of the forum pages. You will find it between "Shack Shopping" and "Glossary". This will represent a great improvement in the vendor reference database, making it easier than ever to find what you are looking for. Contact me with any suggested entries, category recommendations, or additional information about the vendors that we have. If you are a vendor and want your company listed, there is an option to provide us with the information. | ||||
| | #8 | ||||
| Re: Negative or Positive? Serendipity. A knock on the door and it was just delivered. It's really something. A huge box with the movies, cardboard pictures, a watch, program book, budget, script and so on. It won't fit on my shelf. I'll screen the Blu-Ray on Saturday but it will take some time to go through all the rest. | ||||
| | #9 | ||||
| Re: Negative or Positive? I forgot to mention the most expensive film and video restoration to date, "How the West Was Won". Warner/MGM first mastered the original 35mm color negatives of each panel (3 of them) on a separate digital tape. Each roll of color negative was A & B rolled for first generation fades and dissolves. So that's six rolls per 20 minutes transferred into three separate images on videotape. Then the three separate digital videotape panels had to be color corrected so they all matched. Then the color corrected panels had to be joined together and 'morphed' into a single wide screen image removing the join lines that were there in the Cinerama theatrical presentations. Then they out-putted a new 35mm anamorphic color internegative for the future and made the blu ray discs. Quite a job and I think it took over six months to complete. Can you imagine what a challenge it was for the transfer technicians and colorist? The panels never had consistent color in the original prints and the separate negatives had faded to different degrees. It makes my head spin thinking about what they had to deal with. Miraculously, they made them match and it looked better than the three panel Technicolor Cinerama print(s) I saw in Ohio in the nineties. I don't know what the final cost was but it must've have been greater than any other video release. Regarding my above post, remember that the profit potential always has to be factored into the budget for film restorations. While it's obvious that the time and money spent on the new "Wizard of Oz" restoration will be worth it, minor movies don't always receive the same treatment even though all the technology exists to make them look brand new. I really like the Abbott and Costello and Marx Brothers movies but so far they haven't received full restorations and still have wear on the image. The Roger Corman "Poe" movies also need a digital clean up. We should be thankful that there are some companies like Criterion which has 'adopted' some obscure titles to do restorations on like "Carnival of Souls" and "The Blob" which otherwise would've been forgotten about. Last edited by Richard W. Haines; 10-01-09 at 01:38 PM.. | ||||
