| General Discussion In wall speaker wire?Discuss In wall speaker wire? in the Home Theater | Audio and Video forum; In wall speaker wire? Hello,
Anybody have any experiences with different in wall speaker wire? I know, not likely something people a/b as once ... |
Views: 187 - Replies: 7
| In wall speaker wire? Hello, Anybody have any experiences with different in wall speaker wire? I know, not likely something people a/b as once it is installed there really isn't any swapping...just curious of peoples' insight. This would be for home theatre by the way. Thanks, Mike | ||||
| | #2 | ||||
| Re: In wall speaker wire? Don't overthink it. | ||||
| | #3 | ||||
| Re: In wall speaker wire? if you run the wire inside pipe you can run normal speaker wire and this makes pulling it out and exchanging it later down the road much simpler. Costs a bit more up front for the conduit and boxes but makes up for it in the end. Home theater: Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2 Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
| | #4 | ||||
| Re: In wall speaker wire? in my existing house, I used carol in-wall rated wire from either PE or outdoorspeakerdepot, forgot which. Worked well, except the 12g for the sub has thick strands that aren't very flexible, which I didn't like, but hey, the sub doesn't get messed with much. | ||||
| | #5 | ||||
| Re: In wall speaker wire? +1 | ||||
| | #8 | ||||
| Re: In wall speaker wire? Oh, and for the subwoofer, I bought this RG6 component cable from monoprice and split it into three individual cables (pretty easy). Two were used for subwoofer runs; one in the front of the room and one in the back. The third I used as a composite run to the projector. ![]() | ||||
