| General Discussion LCD Screen replacementDiscuss LCD Screen replacement in the Home Theater | Audio and Video forum; LCD Screen replacement Can anyone tell me where I can get replacements for LCD screens? I have a friend that has a Sharp ... |
Views: 136 - Replies: 5
| LCD Screen replacement Can anyone tell me where I can get replacements for LCD screens? I have a friend that has a Sharp 42" LCD HDTV. The bad thing is that its screen is cracked. He said it turns on and everything works fine but its just cracked really bad. I cannot find any place online that sells LCD replacements besides for laptops. Hitachi CLU-436U1 Big screen TV : Yamaha RX-V663 Receiver : Motorola GI-2000 Cable Box : Philips DVP-5960 Dvd Player : Acoustech HT-85 Center : Acoustech HT-88 Towers : Sony Towers (12 years and don't know the model) : Venturi DV32 Surrounds : Edead eQ.2 Processor (subsonic filter) : Behringer EP1500 Amplifer : Mach 5 MJ18-M Subwoofer (11 ft^3 tuned to 20hz) : Logitech Harmony 880 Advanced Remote | ||||
| | #2 | ||||
| Re: LCD Screen replacement You might have better luck in the repair sections here: http://www.hometheatershack.com/forums/service-support/ | ||||
| | #3 | ||||
| Re: LCD Screen replacement A replacement LCD would most likely cost quite a bit depending on the model. I could actually cost more than the TV if special ordered from the manufacturer. That's because typically TVs are loss leaders in big box stores and tend to sell at or below cost. That cost is also reduced due to large volume orders and special deals between the manufacturer and the retailer. Decent 42" LCD's can be had for under $1000 these days and more price drops are around the corner during the Xmas season. A viable option is to search around for a used or damaged LCD with the same model LCD panel. Often times the ballast or back-light will go and people just ditch and buy new thinking the TV is dead. Salvage the parts from the one to repair the other. It can be pretty hard to find a replacement that way however and you have to be diligent. You could try Ebay, kijiji.com, a local electronics recycler, a local TV shop or contact the manufacturer. | ||||
| | #4 | ||||
| Re: LCD Screen replacement Thanks. Ebay was no help. I'll try the other places. Hitachi CLU-436U1 Big screen TV : Yamaha RX-V663 Receiver : Motorola GI-2000 Cable Box : Philips DVP-5960 Dvd Player : Acoustech HT-85 Center : Acoustech HT-88 Towers : Sony Towers (12 years and don't know the model) : Venturi DV32 Surrounds : Edead eQ.2 Processor (subsonic filter) : Behringer EP1500 Amplifer : Mach 5 MJ18-M Subwoofer (11 ft^3 tuned to 20hz) : Logitech Harmony 880 Advanced Remote | ||||
| | #5 | |||||
| Re: LCD Screen replacement Quote:
I believe that Encompass and Andrews are Sharp parts distributors. Note that we have now begun moving vendors to the new pull down option at the top of the forum pages. You will find it between "Shack Shopping" and "Glossary". This will represent a great improvement in the vendor reference database, making it easier than ever to find what you are looking for. Contact me with any suggested entries, category recommendations, or additional information about the vendors that we have. If you are a vendor and want your company listed, there is an option to provide us with the information. | |||||
| | #6 | ||||
| Re: LCD Screen replacement Thanks. I am looking through them now. Hitachi CLU-436U1 Big screen TV : Yamaha RX-V663 Receiver : Motorola GI-2000 Cable Box : Philips DVP-5960 Dvd Player : Acoustech HT-85 Center : Acoustech HT-88 Towers : Sony Towers (12 years and don't know the model) : Venturi DV32 Surrounds : Edead eQ.2 Processor (subsonic filter) : Behringer EP1500 Amplifer : Mach 5 MJ18-M Subwoofer (11 ft^3 tuned to 20hz) : Logitech Harmony 880 Advanced Remote | ||||
| Bookmarks |
| Tags |
| replacement, screen |
| Thread Tools | |
