SPL and Screen Size Calcs - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Home Theater Equipment Reviews.
Emotiva is your Home Theater Component Source for Audiophile Quality Home Theater Equipment at Factory Direct Prices.
Exodus Audio
    Home Register         Shack Shopping Glossary     Enclosure Calculators Forum Help/FAQ
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > General Discussion
General Discussion
Discuss SPL and Screen Size Calcs in the Home Theater | Audio and Video forum; SPL and Screen Size Calcs Check out the cool calculators (and the little quiz) on this enthusiast's site. Collins' Cinema My SPL calc was good ...
Old 11-09-06, 02:42 PM   #1 (Link)
Moderator Emeritus
Alias: Naut
Loc: Richmond, VA
Ayreonaut's Avatar
User: #203
  Ayreonaut is offline
Collins' Cinema
My SPL calc was good news. Looks like I can do reference level with no fear of clipping.
We are the Shack. Existence as you know it is over.
We will add your biological and technological distinctiveness to our own.
You will be mapped. Resistance is futile.
Old 11-09-06, 03:38 PM   #2 (Link)
Alias: Josuah
Loc: San Jose, CA
User: #182
  Josuah is offline
Re: SPL and Screen Size Calcs
Well, if the sound is only coming from one speaker (e.g. center channel) you have to take away 3dB. And if the sound is of a higher frequency, you have to take away another 3dB. Also, your speaker's sensitivity of 91.5dB@1W@1m may not be the actual value; I've seen many speakers that are 1-2dB lower than their spec'ed value.
:-S
Old 11-09-06, 04:36 PM   #3 (Link)
Moderator Emeritus
Alias: Naut
Loc: Richmond, VA
Ayreonaut's Avatar
User: #203
Yes, you are right those are some variables, and there are others.
I don't use a center channel. Stereophile measured the Ikon 6 at 90.5dB(B)/2.83V/m. The Denon's 115 W +115 W into two 6 ohms loads may be rated conservatively as Denon tends to do. The Ikons are a nominal 6 ohm load, but through much of their range its closer to 4.5 ohms. The higher frequencies are tipped up a bit.
Suffice it to say, that even though there are a lot of variables, I just wanted to point out that the SPL calculator is cool. Just plug in the specified values and interpret the result with a grain of salt.
Old 11-10-06, 02:03 AM   #4 (Link)
Alias: Josuah
Loc: San Jose, CA
User: #182
  Josuah is offline
Yeah, I use it often too. Just for rough guesswork.
« Home Theater Shack > Home Theater | Audio and Video > General Discussion »
Similar Threads
What Screen to use?????? James Broccoli Projector Screens | DIY Screens 7 04-11-07 02:54 PM
Screen Rodny Alvarez Projector Screens | DIY Screens 6 10-25-06 08:07 PM
What would be the perfect size and shape of a new HT room? Sonnie Home Theater Design and Construction 18 05-13-06 06:40 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228
