EQ 4 Mains... - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > General Discussion
General Discussion
EQ 4 Mains...
Discuss EQ 4 Mains... in the Home Theater | Audio and Video forum; EQ 4 Mains... I'll like to EQ my mains and want to know what you guys think. I'm big on EQing car stereos ...
Old 11-22-06, 08:30 PM   #1 (Link)
Alias: Rodny
Loc: Millbrook AL
Rodny Alvarez's Avatar
User: #158
Rodny Alvarez is offline
EQ 4 Mains...
I'm big on EQing car stereos it makes a big difference, when is done right!!
Do you think this one will work ?
(only $130)
Enjoy the limelight with the Ultragraph Pro FBQ3102, a professional 31-band stereo graphic equalizer for both live and studio applications. Its amazing patent-pending FBQ Feedback Detection System instantly detects feedback frequencies and can also be used as an audio analyzer, making the FBQ3102 a welcome addition to every touring setup. Adding some extra oomph to your music is made easy with the dedicated mono subwoofer output with adjustable crossover frequency. You can effortlessly remove unwanted frequencies such as floor rumble by using the switchable low cut filters for each channel, and level setting is easy with the 4-digit LED output metering and input gain control.
The FBQ3102 features uncompromising components such as the ultra low-noise audio operational amplifiers that provide outstanding sound performance, and servo balanced inputs and outputs with 1/4" TRS and gold-plated XLR connectors. You can expect unmatched reliability and longevity because high-quality illuminated faders, detent ALPS® potentiometers and illuminated switches were designed for the rigors of every-day use.
* Professional 31-band stereo Graphic Equalizer for both live and studio applications
* Revolutionary FBQ Feedback Detection System instantly reveals critical frequencies
* FBQ System can also be used as an Audio Analyzer!
* Dedicated mono subwoofer output with adjustable crossover frequency
* Low cut filters for each channel remove unwanted rumble
* Shielded toroidal power transformer for ultra low-noise performance
* Ultra low-noise audio operational amplifiers offer outstanding sound performance
* 4-segment LED output level display per channel
* Servo-balanced inputs and outputs with 1/4" TRS and gold-plated XLR connectors
* Illuminated faders, detent ALPS® potentiometers, and illuminated switches
* Rugged all-metal chassis ensures long life even under the most demanding conditions
* Designed in Germany. Manufactured under ISO9000 certified management system
Old 11-22-06, 09:00 PM   #2 (Link)
Alias: Wayne
Loc: Katy, Texas
Wayne A. Pflughaupt's Avatar
User: #8
Re: EQ 4 Mains...
Frankly I’d be scared to use any equalizer as cheap as that in a hi-fi application, Rodny. The +/- 3 dB variable in the frequency response spec would be enough to scare me off.
Can’t hurt to try, though – just make sure you have a generous return policy.
A couple of things to check for: Noise and fidelity.
You can check for noise with nothing playing on the system. Turn the receiver up until you can hear some residual noise from the speakers when you’re up close. Set all the EQ bands and other functions to flat, and switch it in and out. There should be no noise added when it’s engaged.
For fidelity, with all controls flat, play pink noise through the speakers and switch the EQ in and out. There should be no change in the timbre of the sound.
If possible, check with an old receiver that has a tape monitor loop, to fully switch the EQ in and out, totally bypassing it.
After that, judge for yourself with listening tests. As with auditioning speakers, simple, uncluttered program sources are typically best – acoustic jazz ensemble with vocal, etc.
Even if it passes the above tests, there can be other issues with cheap EQs, like the filters being inaccurate or overly broad. I found this out once when I did a head-to-head with a pair of Yamaha and Ashly EQs.
As I said, experimenting never hurts. Be interested to see what you find.
Old 11-22-06, 11:08 PM   #3 (Link)
Loc: Lower Alabama
Re: EQ 4 Mains...
Audyssey
Old 11-22-06, 11:08 PM   #4 (Link)
Alias: Rodny
Loc: Millbrook AL
User: #158
Re: EQ 4 Mains...
Thanks Wayne!!
The guys at the store told me I can bring it back if it doesn't work, they have more EQs so I'm going to check then out this weekend.
What brand you think I should look for?
Old 11-22-06, 11:12 PM   #5 (Link)
Alias: Rodny
Loc: Millbrook AL
User: #158
Re: EQ 4 Mains...
Sonnie wrote: View Post
I need 7, one for each speaker....
Old 11-23-06, 12:04 AM   #6 (Link)
Loc: Lower Alabama
Re: EQ 4 Mains...
The Audyssey is 8 channel, so you have one extra channel to spare.
Old 11-23-06, 09:49 AM   #7 (Link)
Alias: Wayne
Loc: Katy, Texas
User: #8
Re: EQ 4 Mains...
Get us a list of the brands they have.
Old 11-24-06, 08:09 PM   #8 (Link)
Alias: Rodny
Loc: Millbrook AL
User: #158
Re: EQ 4 Mains...
Hey Wayne!!
I found this one......
http://www.behringer.com/DSP8024/index.cfm?lang=ENG
Old 11-25-06, 09:41 PM   #9 (Link)
Alias: Dan
Loc: Australia
User: #359
Danny is offline
Re: EQ 4 Mains...
I personally prefer digital EQ's, you will need a few of them though. Another thing to check is whether when you pull a high frequency whether it introduces more high frequency noise into the signal.
Old 11-25-06, 09:46 PM   #10 (Link)
Loc: Lower Alabama
Re: EQ 4 Mains...
That 8024 is a heavy duty machine... it does an aweful lot and I believe it has auto eq.
Thinking about this, if you are only wanting to eq your mains, then this is not for movies, it's for music, otherwise I don't think you'd really benefit much eq'ing the mains only, would you?
Old 11-25-06, 10:10 PM   #11 (Link)
Alias: Wayne
Loc: Katy, Texas
User: #8
Re: EQ 4 Mains...
Hey Wayne!!
Well, it’s a digital equalizer, which means another AD/DA conversion in your signal chain. No big deal with the BFD for the subs, but for the mains – not so sure.
The same guidelines I posted above apply – make sure it’s neutral and quiet before you give it the thumbs up.
Old 11-25-06, 10:11 PM   #12 (Link)
Alias: Rodny
Loc: Millbrook AL
User: #158
Re: EQ 4 Mains...
Yep!!
Yes is for music!, but I will think the it will help for movies to...... or NOT
Old 11-26-06, 11:34 PM   #13 (Link)
Alias: Bob
Loc: Pittsburgh, PA
khellandros66's Avatar
User: #962
Since: Jun 2006
khellandros66 is offline
Re: EQ 4 Mains...
Actually guys there is a $499 8ch one from these guys..
http://www.alesis.com/product.php?id=45
I would love nothing more then to see a new REW with 7.1ch setup and measurement capabilities. Esp if the REW gave you a choice of selecting each channel and what medium such as Dolby Digital 5.1/6.1 or DTS 5.1/6.1 so that you can have two presets depending on the type of audio track that is being played..
~Bobby
Old 11-27-06, 07:57 AM   #14 (Link)
Alias: terry
Loc: bathurst nsw australia
User: #1819
terry j is offline
Re: EQ 4 Mains...
hi guys
I can't explain why the 8024 is still showing on the Behrinhger website, but I am pretty sure that that model has been supereceded....???... by the DEQ 2496.
Another example, I think the UB 802 may still be listed, but again am certain it is no longer manufactured and has been replaced by the Xenyx 802.
Maybe they stay on the site for a while after discontinuation??
Anyway I have mucked about with it and yes it does make a nice change to the sound. There is a very nice write up on how to use it on Audio Review Forums, a guy called Mike Anderson did a write up that was very helpful titled 'Thoughts on using the behringer DEQ 2496 for room correction'.
What I really liked about it was that in addition to a 31 band graphic, it also has 12 parametrics on each channel and does RTA correction on your system. After using the GEQ to get a flat FR on your mains, switch to the PEQ and use an absolutely fantastic program called REW to get as flat a response in your room as you'd like.
Perhaps some of you have heard of that program?...
I am using a DEQX in my own system, but if I was not lucky enough to be able to afford that I would with no hesitation use the DEQ in it's place.
I have posted in the BFD forum about using it and REW, and plenty of pics that may help you get a handle on it
lots of love
terry
I also have a couple of reviews on the 8024 and it's successor, will have to dig them out to be able to let you know. Thought they were in my bookmarks but...
Let me know if you want the 'links' and I'll dig them out
Old 11-29-06, 12:19 PM   #15 (Link)
JCD
Golden Bear Mod
Alias: Jacen
Loc: Bay Area, California
JCD's Avatar
User: #53
JCD is offline
Re: EQ 4 Mains...
With a good return policy at your store, I'd start off small and work your way up to the more expensive products until you get the results you want. That or buy the cheaper one and the expensive one at the same time and see if you can tell a difference.
I don't have it, but I'm a believer in using a little judicious eq'ing to squeeze a little more performance out of a system.
As for the AD/DA issue, I know I'm in the minority (probably) on this one, but I don't think with today's converters that this is such an issue anymore. Again, i realize I'm probably not speaking for most folks on this issue.
Good luck and I look forward to hearing about your tests.
JCD
Old 11-30-06, 03:16 AM   #16 (Link)
drf
Alias: drf
Loc: Somewhere else.
drf's Avatar
User: #3282
Since: Oct 2006
drf is offline
Re: EQ 4 Mains...
JCD wrote: View Post
..snip...
...snip...
I don't think its so much the AD/DA chips, although there are definately good and bad ones, but more the pre/post circuitry. Behringer seem to have a hum/buzz issue which could easily be to do with the
op-amps and how they are implemented to drive/buffer the AD/DA converters. If this makes sense?
my rambling thoughts anyway
"Until mankind is peaceful enough not to have violence on the news, there's no point in taking it out of shows that need it for entertainment value." - Clueless
The imperative is to make a subjective study an objective fact.
Old 11-30-06, 05:18 PM   #17 (Link)
Alias: Warner
User: #4451
Since: Nov 2006
warnerwh is online now
Re: EQ 4 Mains...
I personally like the Behringer DEQ 2496. This piece is super versatile and transparent. It even has a decent dac built in although I use a Bel Canto.
It's the ticket you want. For under 300 with the ECM 8000 microphone it's impossible to beat. Numerous audiophiles these days are using them. It has autoeq and it allows you to set your own curve.
It's also got a 31 band stereo equalizer as well as a 10 band stereo parametric equalizer. It's also got the BFD built in among other features. I know one guy who sold his 5,000 dollar Z systems after he bought the Behringer.
This is the best deal in equalization in the world as far as I'm concerned. I have a custom built and fully treated listening room and this little piece helped me improve my sonics considerably. If it ever dies I'll head straight to a pro audio shop and buy one and pay full retail if I have to.
Old 01-01-07, 11:46 AM   #18 (Link)
Alias: Mike
Loc: Tampa FL
mdrums's Avatar
User: #5239
Since: Jan 2007
mdrums is offline
Re: EQ 4 Mains...
I hope I do not burst anyones bubble here or come across as throwing flames but in my profession as a musical instrument rep I need to tell you all that Behringer is NOT mid level or high end products in the musical instrument/pro audio industry. Behringer is built as a low cost product to meet a certain price point for low end PA installs. These products will add noise to your system and smear the true and natural audiophile sound you are after.
Old 01-01-07, 04:47 PM   #19 (Link)
Alias: Wayne
Loc: Katy, Texas
User: #8
Re: EQ 4 Mains...
Mike,
Most folks here are aware that Behringer is a low-end pro brand. However, home applications are less demanding than pro applications, and some of their gear seems to work well for certain home theater applications. For instance it turns out that their 1124 Feedback Destroyer makes for an excellent subwoofer equalizer (since we have to deal with something most pro users don't - room modes).
Aside from that, quite a few audiophiles have been impressed with the 2496.
http://www.enjoythemusic.com/magazin...acurve2496.htm
http://forum.audiogon.com/cgi-bin/fr...5&openfrom&1&4
On the downside, some people have reported reliability problems – a standing complaint with pro applications.
http://www.eham.net/reviews/detail/3796
Old 01-01-07, 05:33 PM   #20 (Link)
Alias: Mike
Loc: Tampa FL
mdrums's Avatar
User: #5239
Since: Jan 2007
mdrums is offline
Re: EQ 4 Mains...
Hi Wayne, like I said not trying to throw flames here and make enemy's but just give some truthful insight since I am in probably 15 pro music instrument stores each week. Actually pro's have to deal with room modes a lot. The live concert hall has room modes too. I have heard about a lot of people useing the feedback destroyer as a parametric to eq the subs. actually I'd love to try that our on my system just to see. However, I'd NEVER stick a Behringer EQ in line for my mains.
Old 01-04-07, 04:57 AM   #21 (Link)
drf
Alias: drf
drf's Avatar
User: #3282
Since: Oct 2006
drf is offline
Re: EQ 4 Mains...
Hi guys, I think Mike and Wayne are on the same wavelength. I think what Wayne means about home applications being less demanding is that there are no mics so feedback is not an issue. Getting good coverage is heavily reliant on speaker design and placement, and due to the size of the room each speakers gain structure has to be more precise. This then means that any equipment in the audio path has to have a good S/N ratio and have a certain degree of accuracy to its performance. I personal think room modes are more noticable (and thus harder to deal with) in a small room than a larger, why else would there be so much effort in designing studios.
my thoughts anyhow, correct me if I am wrong.
dr f
Old 01-04-07, 12:41 PM   #22 (Link)
Alias: Josuah
Loc: San Jose, CA
User: #182
Josuah is offline
Re: EQ 4 Mains...
Um, well, except that I'm going to go completely with Mike here. Doesn't matter about less demanding or feedback. Sticking a lower quality EQ unit into your mains is going to introduce NOISE. And lots of it. The only reason that's okay in a pro venue is because you're running super big speakers at super high volumes so there's already noise/hiss and you're just playing over it.
But for home theater, you will need really expensive (in my opinion) EQ gear, or go all digital.
Old 01-04-07, 03:33 PM   #
