Buzz Hum Problem - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > General Discussion
General Discussion
Buzz Hum Problem
Discuss Buzz Hum Problem in the Home Theater | Audio and Video forum; Buzz Hum Problem Hi, I was wondering if you could give me some input to a slight problem I have been having? The ...
 Closed Thread     Post New Thread
Old 02-09-07, 04:56 AM   #1 (Link)
Alias: Anthony
Loc: orlando
User: #5890
Since: Jan 2007
Tony3d is offline
Buzz Hum Problem
Hi, I was wondering if you could give me some input to a slight problem I have been having? The other day I still noticed the very slightest kinda hum buzz going on in both of my channels. It can only be heard at all if the amp gains are past half way up. If you were not listening for it most people wouldn't hear it. I noticed it after playing my Nakamichi cd player, and switching over to my Harman Kardon CDR-26. The Nakamichi is dead silent. All I have to do is turn on the H/K and I get the noise! I don't even half to be on the H/K's input, just turn it on. I'm sure this is some kind of ground loop, but I don't want to put any signal degrading isolation transformer on the H/K outputs. Any suggestion? I was thinking of grounding the Chassis directly to the my Crown IC-150's chassis. The connecting cables between the H/K and Ic-150 are quite old, but then again so are the one's between the Nakamichi and the IC-150. This is the only component giving my a noise issue. Everything else is dead quite! I tried moving the H/K's power cord to a different outlet with no improvement. My Ic-150 is connected to a Crown XTI-2000 power amp.
Forum Rules
Old 02-09-07, 04:57 PM   #2 (Link)
Alias: jack
Loc: Chicago Suburbs, IL USA
basementjack's Avatar
User: #2649
Since: Sep 2006
basementjack is offline
Re: Buzz Hum Problem
ground hum loops are usually not too hard to track down...
a few thoughts...
- plug everthing into the same power strip - does the problem go away?
- if you have a 3 prong plug on the amp- try a 'floater' (the 3 to 2 prong adapter) - does the hum go away?
- confirm that the problem only exists when the HK is on (ie no hum when connected with power off)
- Jack
Forum Rules
Old 02-10-07, 04:56 PM   #3 (Link)
Alias: Wayne
Loc: Katy, Texas
Wayne A. Pflughaupt's Avatar
User: #8
Closing this duplicate thread, leaving the other one open.
Forum Rules
« Home Theater Shack > Home Theater | Audio and Video > General Discussion »
Similar Threads
Please help with hum in IB with BFD howburger BFD Forum 23 12-04-07 12:18 PM
Hum from speakers?? Hakka General Discussion 7 10-24-06 04:08 AM
Ground loop hum? jeffbridges BFD Forum 3 09-15-06 05:03 PM
The hum of frustration Snookboy BFD Forum 7 08-11-06 08:35 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195
