What is a DAC? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > General Discussion
General Discussion
What is a DAC?
Discuss What is a DAC? in the Home Theater | Audio and Video forum; What is a DAC? I've seen alot of posts about DACs lately but it's not clear to me what a DAK is, what it's ...
Old 05-18-07, 07:40 PM   #1 (Link)
Alias: Mike
Loc: San Jose, CA
User: #4721
Since: Dec 2006
mikie is offline
Question What is a DAC?
I've seen alot of posts about DACs lately but it's not clear to me what a DAK is, what it's used for, or why I'd want to own one. Can someone enlighten me - in simple english? Am I missing something that every audio hobbiest needs to have? --Mikie
Old 05-18-07, 08:20 PM   #2 (Link)
Shack Service Mod
Alias: Leonard Caillouet
Loc: Gainesville, FL, USA
lcaillo's Avatar
User: #328
lcaillo is online now
Re: What is a DAC?
DAC = digital to analog converter. You already have several, probably, in your digital sources, such as CD players and DVD players, and perhaps in A/V recievers or Pre/Pros. Whether you need a unit that specifically does that task or not depends on whether you prefer the sound of a particular DAC over the ones in your digital devices, such as your CD player.
"It is better to debate a question without settling it than to settle a question without debating it."
-Joseph Joubert
Raise the bar.
Old 05-19-07, 08:10 AM   #3 (Link)
Friend of the Shack
Alias: Otto
Loc: Beautiful Colorado
Otto's Avatar
User: #625
Otto is offline
Re: What is a DAC?
Hi Mikie,
A DAC is the device that takes the digital data and restores it into an analog audio signal that you can hear. Devices that use a digital storage medium (such as CDs, DVDs, etc.) must be converted back to analog before it makes any sense for a human to listen to them. This data is read from the meduim, potentially manipulated by the system (while the signal is still digital) and then those discrete, numerical values are translated into a fully continuous analog signal. That signal is then fed through your preamp, power amp and, finally, your speakers.
In general, a digital to analog converter must exist somewhere in your system. In a stand-alone CD player that feeds an analog signal to your preamp, the DAC is in the CD player. If you send a digital signal to your preamp (or receiver, as the case may be), the DAC is in your preamp, and it's doing the conversion.
You can also buy outboard DACs that take a digital signal in (usually via optical or coax, and sometimes AES/EBU or USB), and output an analog signal to your preamp. These range in price from <$100 to $10,000+++. The reason you might want one is for its audio sound quality. There are different things that can be done during the conversion stages that can affect the sound, which you may or may not like. One example of an implementation that will create a "different" sound is the use of vacuum tubes in the signal path.
Anyway, that's kind of the basics.
-- Otto
Old 05-23-07, 02:46 PM   #4 (Link)
Alias: Mike
Loc: San Jose, CA
User: #4721
Since: Dec 2006
mikie is offline
Re: What is a DAC?
Thanks Otto, that helps. --Mikie
Old 05-23-07, 05:47 PM   #5 (Link)
Tech'y Shackster
Alias: Bob
Loc: Shueyville, Iowa
User: #25
bobgpsr is offline
Re: What is a DAC?
Any AVR or Pre-Pro that has any type of digital input (coax or optical Toslink S/PDIF), HDMI audio, or iLink then it has to have DACs. One for each audio channel.
« Home Theater Shack > Home Theater | Audio and Video > General Discussion »
Similar Threads
Benchmark DAC-1 Review Otto HiFi Audio Components 1 12-16-07 02:43 PM
To DAC or not to DAC, that is the question. supervsl Home Theater Components 6 04-15-07 01:19 PM
im in ur dac, clippin ur t00nz geekwithfamily Home Theater, Audio and Video News 0 12-29-06 04:30 PM
DIY Paradise - Monica 2 DAC in a Jewelry Box geekwithfamily Home Theater, Audio and Video News 0 12-28-06 09:45 PM
Help me decide if I really need a DAC? pearsall001 HiFi Audio Components 14 09-17-06 11:38 AM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202
